0008072 | ParaView | (No Category) | public | 2008-11-10 06:44 | 2009-05-13 13:45 | ||||
Reporter | dh | ||||||||
Priority | low | Severity | major | Reproducibility | have not tried | ||||
Summary | 0008072: when reading STL files. points are not displayed, surfaces ignored | ||||||||
Description | In Information: Number of Cells: 0 Number fo Points: 7627 (points are not displayable, even when setting representation to points). Shells/triangles do not appear at all. | ||||||||
Attached Files | Explorer.k.small.stl.gz [^] (658,251 bytes) 2008-11-10 06:44 vtkSTLReader.cxx [^] (10,956 bytes) 2008-11-17 11:50 | ||||||||
(0014107) Francesco (reporter) 2008-11-14 04:12 |
I've noticed that if you remove all the lines containing the keyword "color" the file is correctly displayed. I guess it should be enough to skip those lines when reading the ascii STL file to resolve the bug. I.e. -----------------8<------------------------------- solid bw-a-pillar-bottom-LEFT color 0.98824 0.13333 0.49804 facet normal 0.065777868 -0.994380057 0.0829555467 outer loop vertex -1236.36243 709.844604 755.906372 vertex -1235.98022 708.72937 742.235107 vertex -1243.3512 708.230164 742.095825 endloop endfacet facet normal 0.0584581681 -0.994519949 0.086676009 outer loop vertex -1236.36243 709.844604 755.906372 vertex -1243.3512 708.230164 742.095825 vertex -1244.53064 709.432861 756.69104 endloop endfacet [...] -----------------8<------------------------------- becomes: -----------------8<------------------------------- solid bw-a-pillar-bottom-LEFT facet normal 0.065777868 -0.994380057 0.0829555467 outer loop vertex -1236.36243 709.844604 755.906372 vertex -1235.98022 708.72937 742.235107 vertex -1243.3512 708.230164 742.095825 endloop endfacet facet normal 0.0584581681 -0.994519949 0.086676009 outer loop vertex -1236.36243 709.844604 755.906372 vertex -1243.3512 708.230164 742.095825 vertex -1244.53064 709.432861 756.69104 endloop endfacet [...] -----------------8<------------------------------- Hope this helps some developer to write a quick fix to this issue. |
(0014126) Francesco (reporter) 2008-11-17 11:48 edited on: 2008-11-17 11:51 |
I've written a quick fix to this problem. Here it is the result from the diff command against the official 3.4.0 release: -----------------8<------------------------------- [ParaView-3.4.0]$ diff VTK/IO/vtkSTLReader.cxx ../ParaView-3.4.0-release/VTK/IO/ 313,316d312 < if ((strcmp(line, "COLOR") == 0) || (strcmp(line, "color") == 0)) < { < done = (fscanf(fp,"%s %*s %f %f %f\n", line, x, x+1, x+2)==EOF); < } 361,365d356 < if ((strstr(line, "COLOR") == 0) || (strstr(line, "color") == 0)) < { < done = (fscanf(fp,"%f %f %f\n", x,x+1,x+2)==EOF); < done = (fscanf(fp,"%s", line)==EOF); < } -----------------8<------------------------------- Basically, the only routine changed is vtkSTLReader::ReadASCIISTL, adding the check on a possible "color" line just after every time the parsing of a solid block starts. The proposed modification can read STL ascii files with and without the "color" line. The modified file is attached. I hope this helps and the fix, or a better version, could be eventually included in the next release. Francesco |
(0015788) Utkarsh Ayachit (administrator) 2009-03-24 12:09 |
Committing reporter's patch to handle stl ascii files containing "color" lines. /cvsroot/ParaView3/ParaView3/VTK/IO/vtkSTLReader.cxx,v <-- VTK/IO/vtkSTLReader.cxx new revision: 1.75; previous revision: 1.74 |
(0015821) Alan Scott (manager) 2009-03-27 19:46 |
Looks fixed to me. Tested local client, XP. |
2008-11-10 06:44 | dh | New Issue | |
2008-11-10 06:44 | dh | File Added: Explorer.k.small.stl.gz | |
2008-11-14 04:12 | Francesco | Note Added: 0014107 | |
2008-11-17 11:48 | Francesco | Note Added: 0014126 | |
2008-11-17 11:50 | Francesco | File Added: vtkSTLReader.cxx | |
2008-11-17 11:51 | Francesco | Note Edited: 0014126 | |
2009-02-17 14:57 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-17 14:57 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-17 14:57 | Utkarsh Ayachit | Priority | normal => low |
2009-02-17 14:57 | Utkarsh Ayachit | Category | 3.4 => 3.6 |
2009-03-24 12:09 | Utkarsh Ayachit | Note Added: 0015788 | |
2009-03-24 12:09 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-03-24 12:09 | Utkarsh Ayachit | Resolution | open => fixed |
2009-03-27 19:46 | Alan Scott | Note Added: 0015821 | |
2009-03-27 19:46 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
