| 0008091 | ParaView | Bug | public | 2008-11-13 10:13 | 2016-08-12 09:57 | ||||
| Assigned To | Yumin Yuan | ||||||||
| Priority | low | Severity | minor | Reproducibility | have not tried | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Summary | 0008091: 3D widgets segfault on large data bounds | ||||||||
| Description | Create a Box with X,Y,Z lengths set to 15e18. Apply Cut/Clip Interact with the 3D widget. This segfaults somewhere in the implicit plane representation rendering code. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0014101) Utkarsh Ayachit (administrator) 2008-11-13 11:07 |
Jean Favre reports that he experiences the segfault immediately after creating the filter (even before the interaction with the 3D widget). Since the segfault I see in the Render() code for the 3D widget it may still be the same issue. |
(0037606) Kitware Robot (administrator) 2016-08-12 09:57 |
| Notes |
| Issue History | |||
| 2008-11-13 10:13 | Utkarsh Ayachit | New Issue | |
| 2008-11-13 11:07 | Utkarsh Ayachit | Note Added: 0014101 | |
| 2009-02-17 15:03 | Utkarsh Ayachit | Status | backlog => tabled |
| 2009-02-17 15:03 | Utkarsh Ayachit | Assigned To | => Burlen |
| 2009-04-20 14:50 | Utkarsh Ayachit | Assigned To | Burlen => Yumin Yuan |
| 2009-04-22 15:00 | Utkarsh Ayachit | Priority | normal => low |
| 2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
| 2009-08-25 18:54 | Utkarsh Ayachit | Category | => Bug |
| 2009-08-25 18:54 | Utkarsh Ayachit | Target Version | 3.6 => 3.8 |
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037606 | |
| 2016-08-12 09:57 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved |
| Issue History |
