0008167 | ParaView | (No Category) | public | 2008-11-25 10:37 | 2009-05-13 13:47 | ||||
Assigned To | Zhanping Liu | ||||||||
Summary | 0008167: Selecting in spreadsheet when only showing selected element | ||||||||
Description | The selection behavior in the spreadsheet view is undesirable when the "Show only selected elements" feature is on. When this option is on and you select a row by clicking on it, suddenly all rows except the one just clicked on disappear because the selection has immediately changed. This behavior is both annoying (because it is easy to loose the current selection set) and unhelpful (because it is impossible to select more than one element). There are many potential behaviors that are better than this. An acceptable solution is to simply disable selection in the spreadsheet view when showing only selected elements. A better behavior would be to allow selection, but to not change the rows viewed when they are selected from within the spreadsheet (only change them when the selection occurs within a different view or the selection inspector). | ||||||||
Attached Files | Patch.txt [^] (3,589 bytes) 2008-12-03 12:07 [Show Content] | ||||||||
(0014276) Zhanping Liu (developer) 2008-12-03 12:05 |
The bug was fixed and now the user is disallowed to make further (embedded / recursive) selections once checkbox "Show Only Selected Elements" is checked via the object inspector. The fix was made by adding a pair of signal (in class pqSpreadSheetViewModel) and slot (in class pqSpreadSheetView) and therefore changes were made to the following four files: pqSpreadSheetView.h (new revision: 1.13; previous revision: 1.12) pqSpreadSheetView.cxx (new revision: 1.19; previous revision: 1.18) pqSpreadSheetViewModel.h (new revision: 1.12; previous revision: 1.11) pqSpreadSheetViewModel.cxx (new revision: 1.30; previous revision: 1.29) Please see the attached patch file for diff info. |
(0014299) Alan Scott (manager) 2008-12-04 22:11 |
Tested local server, since there is now a hang client/server (which will be a new bug report) |
2008-11-25 10:37 | Ken Moreland | New Issue | |
2008-12-01 15:11 | Utkarsh Ayachit | Status | backlog => tabled |
2008-12-01 15:11 | Utkarsh Ayachit | Assigned To | => Zhanping Liu |
2008-12-03 12:05 | Zhanping Liu | Note Added: 0014276 | |
2008-12-03 12:05 | Zhanping Liu | File Added: Patch.txt | |
2008-12-03 12:07 | Zhanping Liu | File Deleted: Patch.txt | |
2008-12-03 12:07 | Zhanping Liu | File Added: Patch.txt | |
2008-12-03 12:08 | Zhanping Liu | Status | tabled => @80@ |
2008-12-04 22:11 | Alan Scott | Note Added: 0014299 | |
2008-12-04 22:11 | Alan Scott | Status | @80@ => closed |
2008-12-04 22:11 | Alan Scott | Resolution | open => fixed |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
