0008239 | ParaView | (No Category) | public | 2008-12-05 10:59 | 2009-06-03 19:54 | ||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0008239: Lookmark Cleanup | ||||||||
Description | * It must be possible to load lookmarks from python. This entails that the lookmark state loader moves to server manager. * When Lookmarks are saved the XML has <CustomProxyDefinitions/> saved multiple times, that needs to be fixed. * Lookmarks with custom filters cannot be loaded correctly on systems where the custom filter is not already defined. * If lookmark loading fails, no cleanup ensues, consequently it's possible to have a lookmark half-loaded. | ||||||||
(0016560) Utkarsh Ayachit (administrator) 2009-05-22 14:42 |
Lookmarks are to be deprecated in future releases. |
(0016620) Alan Scott (manager) 2009-06-03 19:54 |
Sounds like a good solution to us. Closed. |
2008-12-05 10:59 | Utkarsh Ayachit | New Issue | |
2009-02-17 15:20 | Utkarsh Ayachit | Category | 3.6 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2009-05-22 14:42 | Utkarsh Ayachit | Note Added: 0016560 | |
2009-05-22 14:42 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-05-22 14:42 | Utkarsh Ayachit | Resolution | open => won't fix |
2009-05-22 14:42 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-06-03 19:54 | Alan Scott | Note Added: 0016620 | |
2009-06-03 19:54 | Alan Scott | Status | @80@ => closed |
