0008283 | ParaView | (No Category) | public | 2008-12-10 22:14 | 2009-05-13 13:47 | ||||
Summary | 0008283: Animations of multiple windows with histogram don't work. | ||||||||
Description | I want to have multiple windows open, and make an animation of only one of them. Open can.exo. apply. Split horizontal, split virtical. Top right, turn eyeball on. Bottom right, filters/ data analysis/ histogram Make the left window full screen. File/ Save Animation. Notice that the histogram is still drawing, right on top of the full screen window. | ||||||||
(0014370) Utkarsh Ayachit (administrator) 2008-12-16 10:54 |
In general fullscreen mode needs to be handled a bit better. I don't think fullscreen information gets saved in state files either (not saying that we want it to be saved, but we may want to decide on that). If fullscreen gets saved in state then we may want to be able to support undo/redo for it as well. |
(0015070) Utkarsh Ayachit (administrator) 2009-02-17 15:40 |
Note to self: fix saving animation when a view is maximized. |
(0016182) Utkarsh Ayachit (administrator) 2009-04-24 11:38 |
Ensure that GUISize is set correctly on all visible as well as non-visible views. Since the GUISize from first view is used when saving animations as the total image size. This was resulting in using incorrect size when saving animations with one of the views maximized. /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- Qt/Components/pqViewManager.cxx new revision: 1.70; previous revision: 1.69 |
(0016198) Alan Scott (manager) 2009-04-27 20:45 |
Nope, not fixed. As we are creating the animation, it looks fine. But, if you play the animation back, the histogram is still in the lower right corner. |
(0016230) Utkarsh Ayachit (administrator) 2009-04-28 16:52 |
Tried on windows/linux. I can't seem to reproduce. Feel free to call as I may be misunderstanding this bug. |
(0016271) Alan Scott (manager) 2009-04-30 14:16 |
back to you :-) |
(0016277) Utkarsh Ayachit (administrator) 2009-05-02 19:17 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqAnimationSceneImageWriter.cxx,v <-- Qt/Core/pqAnimationSceneImageWriter.cxx new revision: 1.5; previous revision: 1.4 |
(0016320) Alan Scott (manager) 2009-05-06 16:52 |
That's the ticket. Tested local client. |
2008-12-10 22:14 | Alan Scott | New Issue | |
2008-12-16 10:54 | Utkarsh Ayachit | Note Added: 0014370 | |
2008-12-16 15:42 | Utkarsh Ayachit | Note View State: 14370: public | |
2009-02-17 15:39 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-17 15:39 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-17 15:40 | Utkarsh Ayachit | Note Added: 0015070 | |
2009-04-24 11:38 | Utkarsh Ayachit | Note Added: 0016182 | |
2009-04-24 11:38 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-04-24 11:38 | Utkarsh Ayachit | Resolution | open => fixed |
2009-04-27 20:45 | Alan Scott | Note Added: 0016198 | |
2009-04-27 20:45 | Alan Scott | Status | @80@ => @20@ |
2009-04-27 20:45 | Alan Scott | Resolution | fixed => reopened |
2009-04-28 16:52 | Utkarsh Ayachit | Note Added: 0016230 | |
2009-04-28 16:52 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-04-28 16:52 | Utkarsh Ayachit | Resolution | reopened => unable to reproduce |
2009-04-30 14:16 | Alan Scott | Note Added: 0016271 | |
2009-04-30 14:16 | Alan Scott | Status | @80@ => @20@ |
2009-04-30 14:16 | Alan Scott | Resolution | unable to reproduce => reopened |
2009-05-02 19:17 | Utkarsh Ayachit | Note Added: 0016277 | |
2009-05-02 19:17 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-05-02 19:17 | Utkarsh Ayachit | Resolution | reopened => fixed |
2009-05-06 16:52 | Alan Scott | Note Added: 0016320 | |
2009-05-06 16:52 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
