0008301 | ParaView | (No Category) | public | 2008-12-16 12:16 | 2009-05-13 13:45 | ||||
Assigned To | Yumin Yuan | ||||||||
Summary | 0008301: Need ability to tab or select between waypoints on color scale editor | ||||||||
Description | We need the ability to change between the "buttons" or waypoints on the color scale line without needing to use the mouse. For instance, if a user has two points, and they are at the end, and are on top of each other, it is difficult to select the point that isn't totally at the end. Would it be possible to tab between each of them? The need for this feature goes away when we finally implement a specific color for variable data that is in error, outside of the data range. | ||||||||
(0016173) Yumin Yuan (developer) 2009-04-23 17:10 |
Added ability to use tab or shift+tab to navigate among points. |
(0016200) Alan Scott (manager) 2009-04-27 20:50 |
Excellent. Tested client/remote server. |
2008-12-16 12:16 | Alan Scott | New Issue | |
2009-02-17 15:49 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-17 15:49 | Utkarsh Ayachit | Assigned To | => Burlen |
2009-02-17 15:49 | Utkarsh Ayachit | Assigned To | Burlen => Utkarsh Ayachit |
2009-04-20 14:52 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Yumin Yuan |
2009-04-22 14:58 | Utkarsh Ayachit | Priority | normal => high |
2009-04-23 17:10 | Yumin Yuan | Note Added: 0016173 | |
2009-04-23 17:10 | Yumin Yuan | Status | tabled => @80@ |
2009-04-23 17:10 | Yumin Yuan | Resolution | open => fixed |
2009-04-27 20:50 | Alan Scott | Note Added: 0016200 | |
2009-04-27 20:50 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
