0008309 | ParaView | Bug | public | 2008-12-17 10:42 | 2016-08-12 09:57 | ||||
Reporter | Berk Geveci | ||||||||
Assigned To | Robert Maynard | ||||||||
Summary | 0008309: When adding threshold selection, it shouldn't automatically extract | ||||||||
Description | When adding threshold selection in the selection panel, it should not immediately extract (0,0). Instead, maybe it should bring to cursor into the next entry and have the user type values. Selection should be performed after the user tabs/enters out of the second box. Something similar should be done for when the user is changing values. Maybe extract the selection after all of the entry boxes loose focus? So if the user tabs from one value to another or adds new values, they should not be extracted until the user hits enter or clicks somewhere? Maybe we need an apply button? | ||||||||
(0016453) Ken Moreland (manager) 2009-05-14 18:07 |
IMHO, the threshold should not actually be extracted at all. This is dangerous when applied to a large structured data set. Instead, there should be a special filter that extracts all the faces that have an included cell on one side and not on the other. That is, the result should be the same as threshold then extract surface but without actually creating the intermediate data between the two filters. |
(0025817) Utkarsh Ayachit (administrator) 2011-03-18 14:06 |
Also currently, it seems like the array choosing combo-box is broken (no scalars show up). |
(0037619) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-12-17 10:42 | Berk Geveci | New Issue | |
2008-12-17 10:42 | Berk Geveci | Status | backlog => tabled |
2008-12-17 10:42 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2009-04-27 12:49 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Yumin Yuan |
2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-05-14 18:07 | Ken Moreland | Note Added: 0016453 | |
2009-08-25 18:29 | Utkarsh Ayachit | Category | => Bug |
2009-08-25 18:29 | Utkarsh Ayachit | Target Version | 3.6 => 3.8 |
2011-03-18 14:06 | Utkarsh Ayachit | Note Added: 0025817 | |
2011-03-18 14:06 | Utkarsh Ayachit | Assigned To | Yumin Yuan => Robert Maynard |
2011-03-18 14:07 | Utkarsh Ayachit | Target Version | 3.8 => 4.0 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037619 | |
2016-08-12 09:57 | Kitware Robot | Status | backlog => closed |
