0008334 | ParaView | Bug | public | 2008-12-29 15:43 | 2011-03-21 21:51 | ||||
Reporter | Berk Geveci | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0008334: ParaView crashes with cell data + triangle strips | ||||||||
Description | To reproduce this bug, make sure to turn on triangle strips. (1) Open the vtk file. (2) Change "Outline" to "Surface". (3) Drag the object. Then I get the error message. (4) Change "Solid Color" to "dens", which is a scalar data. Then paraview suddenly crashes. | ||||||||
Attached Files | trianglestripbug.vtk [^] (718,527 bytes) 2008-12-29 15:43 | ||||||||
Relationships | ||||||
(0014487) Utkarsh Ayachit (administrator) 2009-01-08 10:05 |
The problem appears to be in vtkDataSetSurfaceFilter. Typically, for polydata input when TStrips is on we use vtkStripper which ensures that the cell data is passed through as field data and then scalar coloring with cell arrays works just fine. In case of RectilinearGrid input, the vtkDataSetSurfaceFilter does not use vtkStripper nor does it take any effort to pass cell data as field data so that cell array coloring can still work. This needs to be fixed. |
(0025819) Utkarsh Ayachit (administrator) 2011-03-18 14:08 |
TStrips mode is no longer supported. |
(0025855) Alan Scott (manager) 2011-03-21 21:51 |
Tested trunk, local server, Windows. Used directions above. |
2008-12-29 15:43 | Berk Geveci | New Issue | |
2008-12-29 15:43 | Berk Geveci | File Added: trianglestripbug.vtk | |
2009-01-08 10:05 | Utkarsh Ayachit | Note Added: 0014487 | |
2009-01-08 10:17 | Utkarsh Ayachit | Relationship added | has duplicate 0008300 |
2009-02-17 16:01 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-17 16:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-17 16:01 | Utkarsh Ayachit | Priority | normal => low |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-08-25 18:40 | Utkarsh Ayachit | Category | => Bug |
2009-08-25 18:40 | Utkarsh Ayachit | Target Version | 3.6 => 3.8 |
2011-03-18 14:08 | Utkarsh Ayachit | Note Added: 0025819 | |
2011-03-18 14:08 | Utkarsh Ayachit | Status | tabled => @80@ |
2011-03-18 14:08 | Utkarsh Ayachit | Resolution | open => no change required |
2011-03-21 21:51 | Alan Scott | Note Added: 0025855 | |
2011-03-21 21:51 | Alan Scott | Status | @80@ => closed |
