0008410 | ParaView | (No Category) | public | 2009-01-20 20:08 | 2009-10-02 14:05 | ||||
Reporter | Joel Martin | ||||||||
Target Version | Someday | Fixed in Version | 3.6.2 | ||||||
Summary | 0008410: pvsc files are parsed incorrectly | ||||||||
Description | When two variables are on the same line of a pvsc file, the entire argument appears to get deleted when the command is created. I've attached a sample file where this happens. <Argument value="$SERVER_PORT$:127.0.0.1:$PV_SERVER_PORT$"/> is the line of interest. If $PV_SERVER_PORT$ is replaced with '12345', everything works correctly. | ||||||||
Attached Files | ![]() | ||||||||
(0017880) Utkarsh Ayachit (administrator) 2009-10-01 14:53 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqCommandServerStartup.cxx,v <-- Qt/Core/pqCommandServerStartup.cxx new revision: 1.20.4.1; previous revision: 1.20 |
(0017910) Alan Scott (manager) 2009-10-02 14:05 |
Tested local server, XP, 3.6.2, using the attached file. |
2009-01-20 20:08 | Joel Martin | New Issue | |
2009-01-20 20:08 | Joel Martin | File Added: SSH_Test.pvsc | |
2009-01-21 16:54 | Dave DeMarle | Status | backlog => tabled |
2009-01-21 16:54 | Dave DeMarle | Assigned To | => Dave DeMarle |
2009-02-17 16:44 | Utkarsh Ayachit | Category | 3.4 => Someday |
2009-05-13 13:50 | Utkarsh Ayachit | Target Version | => Someday |
2009-10-01 14:53 | Utkarsh Ayachit | Assigned To | Dave DeMarle => Utkarsh Ayachit |
2009-10-01 14:53 | Utkarsh Ayachit | Note Added: 0017880 | |
2009-10-01 14:53 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-10-01 14:53 | Utkarsh Ayachit | Fixed in Version | => 3.6.2 |
2009-10-01 14:53 | Utkarsh Ayachit | Resolution | open => fixed |
2009-10-02 14:05 | Alan Scott | Note Added: 0017910 | |
2009-10-02 14:05 | Alan Scott | Status | @80@ => closed |
