0008487 | ParaView | (No Category) | public | 2009-02-09 10:09 | 2009-05-13 13:47 | ||||
Assigned To | Yumin Yuan | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0008487: Hit p to pick probe location not obvious | ||||||||
Description | There is no clear way to know that if you have a probe location filter selected that you can pick the point in a 3D view by positioning the mouse and hitting 'p'. There should be something to lead the user to do that. A simple label in the object inspector should be sufficient. | ||||||||
(0016144) Yumin Yuan (developer) 2009-04-22 14:54 |
A label is added to both pqPointSourceWidget and pqLineSourceWidget. |
(0016209) Alan Scott (manager) 2009-04-27 21:50 |
I am being dense, but I don't see a label. Open can.exo. Sources/ ruler. This ruler has it's ends set through the 'p' key, but I don't see any hints that this can be done. |
(0016213) Yumin Yuan (developer) 2009-04-28 10:08 |
The pqDistanceWidget is missed from last fix. |
(0016217) Alan Scott (manager) 2009-04-28 12:56 |
Ruler is still missing. I talked with Utkarsh, and he understands where the ruler code should be modified. |
(0016218) Utkarsh Ayachit (administrator) 2009-04-28 13:23 |
verified that it's fixed in CVS. May be an update issue. |
(0016257) Alan Scott (manager) 2009-04-29 19:43 |
Tested client/ remote server. |
2009-02-09 10:09 | Ken Moreland | New Issue | |
2009-02-17 16:47 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-17 16:47 | Utkarsh Ayachit | Assigned To | => Burlen |
2009-04-20 14:48 | Utkarsh Ayachit | Assigned To | Burlen => Yumin Yuan |
2009-04-22 14:54 | Yumin Yuan | Note Added: 0016144 | |
2009-04-22 14:54 | Yumin Yuan | Status | tabled => @80@ |
2009-04-22 14:54 | Yumin Yuan | Resolution | open => fixed |
2009-04-27 21:50 | Alan Scott | Note Added: 0016209 | |
2009-04-27 21:50 | Alan Scott | Status | @80@ => @20@ |
2009-04-27 21:50 | Alan Scott | Resolution | fixed => reopened |
2009-04-28 10:08 | Yumin Yuan | Note Added: 0016213 | |
2009-04-28 10:08 | Yumin Yuan | Status | @20@ => @80@ |
2009-04-28 10:08 | Yumin Yuan | Resolution | reopened => fixed |
2009-04-28 12:56 | Alan Scott | Note Added: 0016217 | |
2009-04-28 12:56 | Alan Scott | Status | @80@ => @20@ |
2009-04-28 12:56 | Alan Scott | Resolution | fixed => reopened |
2009-04-28 13:23 | Utkarsh Ayachit | Note Added: 0016218 | |
2009-04-28 13:23 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-04-28 13:23 | Utkarsh Ayachit | Resolution | reopened => unable to reproduce |
2009-04-29 19:43 | Alan Scott | Note Added: 0016257 | |
2009-04-29 19:43 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
