0008493 | ParaView | (No Category) | public | 2009-02-10 09:15 | 2009-08-26 22:27 | ||||
Reporter | Zhanping Liu | ||||||||
Assigned To | Zhanping Liu | ||||||||
Summary | 0008493: grouped spcth files invisible in open file dialog | ||||||||
Description | Grouped 'spcth' files (with digits-based extensions) are now invisible in open file dialog even the '*.spcth *.0' filter is chosen. | ||||||||
Attached Files | test.zip [^] (414 bytes) 2009-02-10 09:15 Patch8493.txt [^] (1,692 bytes) 2009-02-10 09:40 [Show Content] | ||||||||
(0014881) Zhanping Liu (developer) 2009-02-10 09:18 |
The attached zip file (test.zip) contains two invalid spcth files. They are just used, with digits-based extensiions, to test the visibility of grouped spcth files in open file dialog and may not be actually opened. |
(0014883) Zhanping Liu (developer) 2009-02-10 09:39 |
This bug has been fixed. Now grouped spcth files (with digits-based extensions) are visible in open file dialog when the '*.spcth *.0' filter is chosen. The fix was achieved by providing the full name of the first of the grouped spcth files, i.e., '*.0', against the wildcards / filters such that the grouped files, if they are really spcth files in terms of the extension part, are able to pass the check. Changes were made to ParaView3/Qt/Core/pqFileDialogFilter.cxx. Please see the attached patch file (patch8493) for more info. new revision: 1.5; previous revision: 1.4 |
(0015169) Alan Scott (manager) 2009-02-18 15:45 |
I tried using the test case you gave, and it is a good test case. The results are close, but not right. When I try to open file group "test", I see "test" with a + to it's left. This is correct. When I click the +, I only see test.0. I should see test.0 and test.0. Wrong: test test.0 Right: test test.0 test.1 |
(0017216) Utkarsh Ayachit (administrator) 2009-08-25 18:40 |
The last I tried this on my linux box, it did the correct thing (look at Alan's example). |
(0017225) Alan Scott (manager) 2009-08-26 22:27 |
Looks fixed to me! Tested remote server. |
2009-02-10 09:15 | Zhanping Liu | New Issue | |
2009-02-10 09:15 | Zhanping Liu | File Added: test.zip | |
2009-02-10 09:16 | Zhanping Liu | Assigned To | => Zhanping Liu |
2009-02-10 09:16 | Zhanping Liu | Status | backlog => tabled |
2009-02-10 09:18 | Zhanping Liu | Note Added: 0014881 | |
2009-02-10 09:39 | Zhanping Liu | Note Added: 0014883 | |
2009-02-10 09:40 | Zhanping Liu | File Added: Patch8493.txt | |
2009-02-10 09:41 | Zhanping Liu | Status | tabled => @80@ |
2009-02-18 15:45 | Alan Scott | Note Added: 0015169 | |
2009-02-18 15:45 | Alan Scott | Status | @80@ => @20@ |
2009-02-18 15:45 | Alan Scott | Resolution | open => reopened |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-08-25 18:40 | Utkarsh Ayachit | Note Added: 0017216 | |
2009-08-25 18:40 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-08-25 18:40 | Utkarsh Ayachit | Resolution | reopened => fixed |
2009-08-26 22:27 | Alan Scott | Note Added: 0017225 | |
2009-08-26 22:27 | Alan Scott | Status | @80@ => closed |
