0008596ParaView(No Category)public2009-02-24 13:252016-08-12 09:57
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PrioritynormalSeverityfeatureReproducibilityalways
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0008596: (Venus - Medium) Ability to set time series plots with data from all time steps
DescriptionHere is a request from a user:
"Here's another feature request. When setting the y-axis there is the option to hard-set the limits. There's another option to auto-set the limits. Unfortunately, the 'auto-set' resets the limit every timestep for a time series. It would be better if 'auto-set' found the min and max over the entire time series and used that for a single unchanging set of limits. Right now, I go into every xy plot and manually hard-set the limits.
Matt
p.s. I hope you can imagine how sore my clicking finger is getting considering the seg faulting...
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
parent of 0008683closedMarcus D. Hanwell Axes in charts rescale by default when animating over time
parent of 0008684closedMarcus D. Hanwell Too many button clicks to adjust axes in plots
parent of 0008687closed Reset range for chart axes
  Notes
(0015437)
Alan Scott (manager)
2009-02-26 17:50
This is a request we hear all the time for numerous filters. For instance,try using Can.exo, glyph filter, vectors - accl. Animate. It is junk. Furthermore, the user has to go through every single frame to find ranges. Worse, some datasets don't have the min/max on one frame, thus lots of manual steps and notes...
(0023213)
Dave DeMarle (administrator)
2010-11-12 13:58
calculating range over time is expensive
(0023226)
2010-11-12 14:47
We should co-opt the infrastructure that colormaps use to do this when the user explicitly asks for it.
(0035619)
2015-12-23 22:22
Changing to backlog, since I think it still isn't a bad idea. I probably need to look more carefully.
(0037627)
Kitware Robot (administrator)
2016-08-12 09:57
Resolving issue as `moved`.
 Issue History
2009-02-24 13:25 Alan Scott New Issue
2009-02-26 17:50 Alan Scott Note Added: 0015437
2009-02-26 17:50 Alan Scott Summary Ability to set time series plots with data from all time steps => (Venus - Medium) Ability to set time series plots with data from all time steps
2009-03-06 11:23 Ken Moreland Relationship added parent of 0008683
2009-03-06 11:28 Ken Moreland Relationship added parent of 0008684
2009-03-06 11:34 Ken Moreland Relationship added parent of 0008687
2009-05-13 13:39 Utkarsh Ayachit Target Version => 3.8
2010-11-12 13:58 Dave DeMarle Note Added: 0023213
2010-11-12 13:58 Dave DeMarle Status backlog => closed
2010-11-12 13:58 Dave DeMarle Resolution open => won't fix
2010-11-12 14:47 Dave DeMarle Assigned To => Utkarsh Ayachit
2010-11-12 14:47 Dave DeMarle Note Added: 0023226
2010-11-12 14:47 Dave DeMarle Status closed => @20@
2010-11-12 14:47 Dave DeMarle Resolution won't fix => reopened
2015-12-23 22:22 Alan Scott Note Added: 0035619
2015-12-23 22:22 Alan Scott Status expired => backlog
2016-08-12 09:57 Kitware Robot Note Added: 0037627
2016-08-12 09:57 Kitware Robot Status backlog => closed
2016-08-12 09:57 Kitware Robot Resolution reopened => moved
