0008637 | ParaView | (No Category) | public | 2009-02-27 07:27 | 2010-01-21 18:13 | ||||
Reporter | pdavid | ||||||||
Target Version | Fixed in Version | 3.8 | |||||||
Summary | 0008637: ruler distance computation | ||||||||
Description | the distance shown by the ruler filter is computed as the distance^2. Seems that it misses the square root operator in the computation. | ||||||||
(0019223) Utkarsh Ayachit (administrator) 2010-01-20 13:54 |
This was fixed on 12/15/2008. Reporter may be using an older version of ParaView. |
(0019254) Alan Scott (manager) 2010-01-21 18:13 |
Tested XP, local server, trunk. I used the sources/cube, added a cube axis, and then used the ruler on this cube. It looks correct. Closed. |
2009-02-27 07:27 | pdavid | New Issue | |
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView |
2010-01-20 13:54 | Utkarsh Ayachit | Note Added: 0019223 | |
2010-01-20 13:54 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-01-20 13:54 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-01-20 13:54 | Utkarsh Ayachit | Resolution | open => no change required |
2010-01-20 13:54 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-01-21 18:13 | Alan Scott | Note Added: 0019254 | |
2010-01-21 18:13 | Alan Scott | Status | @80@ => closed |
