0008658 | ParaView | (No Category) | public | 2009-03-03 09:58 | 2009-05-13 13:45 | ||||
Reporter | Robert Maynard | ||||||||
Summary | 0008658: Slice Representation slider broken on state reload | ||||||||
Description | If when you save a state if any object has slice representation as the active representation the slide bar on reload will not work. This problem is only shows up on the active axis that you saved too. Looking through the state file the proper min and max are saved in the file, but are not loaded into paraview since inspection while debugging shows both min and max being set to zero. | ||||||||
Steps To Reproduce | Create a Wavelet. Switch to Slice Representation. Save State. Load State. Try to move the slice slide bar. | ||||||||
(0015896) Utkarsh Ayachit (administrator) 2009-04-03 09:48 |
In ParaView, we are using a vtkPVSliceFilter to slice the input image data. Now this filter was requesting only the extent for the requested slice from the input. So when state file was loaded, the input extent would simply be that of the slice (not the whole extent for the data that could be produced by the source). Hence the slider was not movable. Fixed that by making this vtkPVSliceFilter always request the complete piece from the input. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVImageSlicer.cxx,v <-- Servers/Filters/vtkPVImageSlicer.cxx new revision: 1.6; previous revision: 1.5 |
(0016034) Alan Scott (manager) 2009-04-15 16:27 |
Tested local server. |
2009-03-03 09:58 | Robert Maynard | New Issue | |
2009-03-03 10:09 | Utkarsh Ayachit | Status | backlog => tabled |
2009-03-03 10:09 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-03-03 10:09 | Utkarsh Ayachit | Category | 3.4 => 3.6 |
2009-04-03 09:48 | Utkarsh Ayachit | Note Added: 0015896 | |
2009-04-03 09:48 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-04-03 09:48 | Utkarsh Ayachit | Resolution | open => fixed |
2009-04-15 16:27 | Alan Scott | Note Added: 0016034 | |
2009-04-15 16:27 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
