0008747 | ParaView | Bug | public | 2009-03-16 19:09 | 2011-01-13 17:00 | ||||
Target Version | 3.6 | Fixed in Version | 3.6 | ||||||
Summary | 0008747: Wrong or very confusing output with plot global variables | ||||||||
Description | ParaView trunk, XP, local server. Open lapjoint_hex.e (Ask Berk for this file if you are at Kitware, ask Alan if you are at Sandia) Turn on all variables, apply. Filters/ Data Analysis/ Plot Global Variables over time. Apply. There will be lots of print statements saying the following: ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkDataArray.cxx, line 951 vtkDoubleArray (0B447B80): Specified component 1 in 'to' array is not in [0, 1) ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkDataArray.cxx, line 951 vtkDoubleArray (0B447B80): Specified component 2 in 'to' array is not in [0, 1) If this is a statement to the user, it should be clearer, if it is for debug, it should be turned off. | ||||||||
(0016460) Utkarsh Ayachit (administrator) 2009-05-14 21:23 |
vtkExtractTemporalFieldData was not taking into consideration the number of components in the input (not sure why). Fixed that. /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractTemporalFieldData.cxx,v <-- VTK/Graphics/vtkExtractTemporalFieldData.cxx new revision: 1.6; previous revision: 1.5 |
(0016492) Alan Scott (manager) 2009-05-15 19:01 |
Tested local server. |
2009-03-16 19:09 | Alan Scott | New Issue | |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-05-14 21:22 | Utkarsh Ayachit | Status | backlog => tabled |
2009-05-14 21:22 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-05-14 21:23 | Utkarsh Ayachit | Note Added: 0016460 | |
2009-05-14 21:23 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-05-14 21:23 | Utkarsh Ayachit | Resolution | open => fixed |
2009-05-14 21:23 | Utkarsh Ayachit | Category | => Bug |
2009-05-14 21:23 | Utkarsh Ayachit | Fixed in Version | => 3.6 |
2009-05-15 19:01 | Alan Scott | Note Added: 0016492 | |
2009-05-15 19:01 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 |
