0008773 | ParaView | (No Category) | public | 2009-03-20 15:08 | 2009-06-09 19:45 | ||||
Summary | 0008773: Outline, point, and line coloring should NOT follow default surface color | ||||||||
Description | Right now representations color outline, point, and line representations by the global surface color by default. Oddly, this is the wrong thing to do. The reason surfaces have their own color is because you usually want it very light, even when the background is also very light, so that you may see the shading. However, if you draw a light, unlit line or point on a light background, it is very difficult to see or invisible. Thus, the default color for these unlit features should follow a different default color. Which one? I don't know. Maybe foreground. There is also some oddness where the color could change when you change representations. I don't know how that should be handled. | ||||||||
Relationships | |||||||||||
(0016670) Utkarsh Ayachit (administrator) 2009-06-09 13:34 |
Now, the AmbientColor is changed when the representation type is set to Wireframe/Outline/Points. Otherwise the the DiffuseColor is set using the GUI. AmbientColor is linked to Foreground Color while DiffuseColor is linked to SurfaceColor. This implies that when user changes representation type from surface to wireframe, there may be a color change, but that's a side effect we have to live with with make the palettes behave correctly for non-shaded and shaded geometry. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- Qt/Components/pqDisplayProxyEditor.cxx new revision: 1.75; previous revision: 1.74 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqDisplayProxyEditor.ui,v <-- Qt/Components/Resources/UI/pqDisplayProxyEditor.ui new revision: 1.42; previous revision: 1.41 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx new revision: 1.46; previous revision: 1.45 |
(0016672) Utkarsh Ayachit (administrator) 2009-06-09 13:38 |
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.352; previous revision: 1.351 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMOutlineRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMOutlineRepresentationProxy.cxx new revision: 1.16; previous revision: 1.15 |
(0016676) Alan Scott (manager) 2009-06-09 19:45 |
Tested local server. Lets put this in the 3.6 branch. |
2009-03-20 15:08 | Ken Moreland | New Issue | |
2009-03-20 15:08 | Ken Moreland | Status | backlog => tabled |
2009-03-20 15:08 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2009-03-26 13:05 | Ken Moreland | Relationship added | parent of 0008791 |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-06-09 09:04 | Utkarsh Ayachit | Relationship added | parent of 0009121 |
2009-06-09 13:34 | Utkarsh Ayachit | Note Added: 0016670 | |
2009-06-09 13:34 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-06-09 13:34 | Utkarsh Ayachit | Resolution | open => fixed |
2009-06-09 13:38 | Utkarsh Ayachit | Note Added: 0016672 | |
2009-06-09 19:45 | Alan Scott | Note Added: 0016676 | |
2009-06-09 19:45 | Alan Scott | Status | @80@ => closed |
