0008827 | ParaView | (No Category) | public | 2009-03-31 15:22 | 2016-08-12 09:57 | ||||
Summary | 0008827: Large cell selections on images can crash ParaView | ||||||||
Description | When you do a selection on an image that selects a large amount of cells, it has a tendency to crash ParaView. A large part of the problem is probably the extraction of the cell edges on the selected cells. This is basically a conversion from structured to unstructured and can take up a lot more memory than the original data. Is there some way to limit the amount of geometry already created? To reproduce, create a wavelet source with large extents (e.g. -100 to 100 in each direction) and then do a select cells through for the whole data set. | ||||||||
(0037637) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-03-31 15:22 | Ken Moreland | New Issue | |
2009-05-13 13:39 | Utkarsh Ayachit | Target Version | => 3.8 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037637 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
