0008908 | ParaView | (No Category) | public | 2009-04-20 08:52 | 2009-05-26 21:09 | ||||
Target Version | 3.6 | Fixed in Version | 3.8 | ||||||
Summary | 0008908: Save temporal datasets as file series | ||||||||
Description | It must be possible to save temporal datasets as a file series. | ||||||||
Attached Files | ![]() | ||||||||
Relationships | ||||||
(0016535) Ken Moreland (manager) 2009-05-19 13:15 |
I made a little headway on this bug. I wrote a class called vtkFileSeriesWriter which is the analog to vtkFileSeriesReader. This new class is attached (although is as of yet untested). For now I am stopping here because I ran in to a stumbling block for implementing vtkSMFileSeriesWriterProxy. I discovered that whereas all readers use the same proxy object, there are 4 types of vtkSMWriterProxy objects (although 1 seems to be unused). The differences seem mostly concerned with providing extent (piece) information to the writers and handling the different conventions. How do we handle this? Do we provide a separate file series proxy for each of these writer proxy types? Do we do some consolidation? And how does the piece information get from vtkFileSeriesWriter to the actual writer? I would rather Utkarsh "the man" Ayachit make this determination than me. |
(0016540) Utkarsh Ayachit (administrator) 2009-05-21 10:23 |
Adding support to save temporal datasets as file series for legacy vtk and vtk-xml file formats. Cleaned up the writer proxies. Removed obsolete vtkPVSummaryHelper and vtkSMPVDWriterProxy. Now summary file is written by the root node alone. Since this change is quite pervasive, I am not too comfortable committing to 3.6 branch without it having used and tested for a while. So delaying until 3.8 (or 3.6.2 is we the issues get cleaned up by then). /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewWriters.xml,v <-- Qt/Components/Resources/XML/ParaViewWriters.xml new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt new revision: 1.193; previous revision: 1.192 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCompleteArrays.cxx,v <-- Servers/Filters/vtkCompleteArrays.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkFileSeriesWriter.cxx,v <-- Servers/Filters/vtkFileSeriesWriter.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkFileSeriesWriter.h,v <-- Servers/Filters/vtkFileSeriesWriter.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVSummaryHelper.cxx,v <-- Servers/Filters/vtkPVSummaryHelper.cxx new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVSummaryHelper.h,v <-- Servers/Filters/vtkPVSummaryHelper.h new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkXMLPVDWriter.cxx,v <-- Servers/Filters/vtkXMLPVDWriter.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Servers/Filters/Testing/Cxx/ServersFiltersPrintSelf.cxx,v <-- Servers/Filters/Testing/Cxx/ServersFiltersPrintSelf.cxx new revision: 1.39; previous revision: 1.38 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/CMakeLists.txt,v <-- Servers/ServerManager/CMakeLists.txt new revision: 1.241; previous revision: 1.240 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPSWriterProxy.cxx,v <-- Servers/ServerManager/vtkSMPSWriterProxy.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPSWriterProxy.h,v <-- Servers/ServerManager/vtkSMPSWriterProxy.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPVDWriterProxy.cxx,v <-- Servers/ServerManager/vtkSMPVDWriterProxy.cxx new revision: delete; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPVDWriterProxy.h,v <-- Servers/ServerManager/vtkSMPVDWriterProxy.h new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPWriterProxy.cxx,v <-- Servers/ServerManager/vtkSMPWriterProxy.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPWriterProxy.h,v <-- Servers/ServerManager/vtkSMPWriterProxy.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMWriterProxy.cxx,v <-- Servers/ServerManager/vtkSMWriterProxy.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMWriterProxy.h,v <-- Servers/ServerManager/vtkSMWriterProxy.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/internal_writers.xml,v <-- Servers/ServerManager/Resources/internal_writers.xml initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/readers.xml,v <-- Servers/ServerManager/Resources/readers.xml new revision: 1.153; previous revision: 1.152 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/writers.xml,v <-- Servers/ServerManager/Resources/writers.xml new revision: 1.34; previous revision: 1.33 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/Cxx/ServersServerManagerPrintSelf.cxx,v <-- Servers/ServerManager/Testing/Cxx/ServersServerManagerPrintSelf.cxx new revision: 1.26; previous revision: 1.25 |
(0016543) Utkarsh Ayachit (administrator) 2009-05-21 11:10 |
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/CMakeLists.txt,v <-- Servers/ServerManager/CMakeLists.txt new revision: 1.242; previous revision: 1.241 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSummaryHelperProxy.cxx,v <-- Servers/ServerManager/vtkSMSummaryHelperProxy.cxx new revision: delete; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSummaryHelperProxy.h,v <-- Servers/ServerManager/vtkSMSummaryHelperProxy.h new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMXMLPVAnimationWriterProxy.cxx,v <-- Servers/ServerManager/vtkSMXMLPVAnimationWriterProxy.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMXMLPVAnimationWriterProxy.h,v <-- Servers/ServerManager/vtkSMXMLPVAnimationWriterProxy.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Testing/Cxx/ServersServerManagerPrintSelf.cxx,v <-- Servers/ServerManager/Testing/Cxx/ServersServerManagerPrintSelf.cxx new revision: 1.27; previous revision: 1.26 |
(0016574) Alan Scott (manager) 2009-05-26 21:09 |
Looks like it works to me. Want to try to put it in 3.6.2? Tested local server. |
2009-04-20 08:52 | Utkarsh Ayachit | New Issue | |
2009-05-11 10:42 | Ken Moreland | Relationship added | parent of 0008617 |
2009-05-11 10:43 | Ken Moreland | Status | backlog => tabled |
2009-05-11 10:43 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-05-19 13:09 | Ken Moreland | File Added: vtkFileSeriesWriter.tar | |
2009-05-19 13:15 | Ken Moreland | Note Added: 0016535 | |
2009-05-21 10:23 | Utkarsh Ayachit | Note Added: 0016540 | |
2009-05-21 10:23 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-05-21 10:23 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2009-05-21 10:23 | Utkarsh Ayachit | Resolution | open => fixed |
2009-05-21 11:10 | Utkarsh Ayachit | Note Added: 0016543 | |
2009-05-26 21:09 | Alan Scott | Note Added: 0016574 | |
2009-05-26 21:09 | Alan Scott | Status | @80@ => closed |
