0009083 | ParaView | Bug | public | 2009-05-29 14:05 | 2009-06-08 10:12 | ||||
Reporter | Ed Sykes | ||||||||
Product Version | 3.4 | ||||||||
Summary | 0009083: Cannot set up lookup table, no X array. | ||||||||
Description | Running ParaView 3.4.0 on XP. Local server. Open .cvs file I select "Field Delimiter Characters" as a "," then press "Apply" the following errors occur: Cannot set up lookup table, no X array. Cannot set up lookup table, no X array. Failed to locate the data to plot on either axes. | ||||||||
Additional Information | Please let me know the required file structure for a .cvs file. | ||||||||
Attached Files | Eye_Mon_May_25_2009_15_21_51.csv [^] (2,380,591 bytes) 2009-05-29 14:05 | ||||||||
Relationships | ||||||
(0016592) Ken Moreland (manager) 2009-05-29 14:13 |
This is already fixed in the soon to be released version 3.6. |
(0016594) Ed Sykes (reporter) 2009-05-29 14:20 |
Hi, Thanks.... could you let me know when version 3.6 is planned to be released please? Thanks, Ed Sykes |
(0016595) Ken Moreland (manager) 2009-05-29 15:14 |
The 3.6 version has been branched and is undergoing last minute fixes and cleanup. Once the source is satisfactory stable and the builds are created, the official release announcement will be made. This should happen in the next couple of weeks. If you are willing to compile ParaView, I encourage you to check out the branch from CVS right now. It will not change significantly between now and the official release. cvs -d :pserver:anoncvs@www.paraview.org:/cvsroot/ParaView3 co -r ParaView-3-6 ParaView3 |
(0016596) Ed Sykes (reporter) 2009-05-29 15:46 |
Hi, Thanks for your help. Yes, I'd like to try it out. Is there any way I can get the source by using Subversion or could someone post the beta .exe file somewhere that I could access? Thanks, Ed Sykes |
(0016600) Ken Moreland (manager) 2009-06-01 12:33 |
SVN access is not available although there is a git mirror hosted at github. You should be able to get it from there if nowhere else. http://github.com/Kitware/ParaView/tree/cvshead [^] Binaries have not been created. They will be posted on the ParaView download site when they are ready. |
(0016628) Alan Scott (manager) 2009-06-03 21:47 |
Tested local server. |
(0016647) Ed Sykes (reporter) 2009-06-05 13:42 |
Hi, I've spent many hours trying to compile and build Paraview 3.6 ... but no luck. Is there any way that I can import my .cvs datafile into Paraview 3.4? Thanks, Ed Sykes |
(0016654) Ken Moreland (manager) 2009-06-08 10:12 |
In short, no. CVS is not really a generally capability in 3.4 as it is in 3.6. For help in building ParaView, you should consult the Wiki. http://www.paraview.org/Wiki/ParaView:Build_And_Install [^] If you are having a specific problem, you should email the ParaView mailing list. paraview@paraview.org Please don't ask by reopening this bug. This bug has a limited audience. |
2009-05-29 14:05 | Ed Sykes | New Issue | |
2009-05-29 14:05 | Ed Sykes | File Added: Eye_Mon_May_25_2009_15_21_51.csv | |
2009-05-29 14:13 | Ken Moreland | Note Added: 0016592 | |
2009-05-29 14:13 | Ken Moreland | Status | backlog => @80@ |
2009-05-29 14:13 | Ken Moreland | Resolution | open => no change required |
2009-05-29 14:13 | Ken Moreland | Assigned To | => Ken Moreland |
2009-05-29 14:20 | Ed Sykes | Note Added: 0016594 | |
2009-05-29 14:20 | Ed Sykes | Status | @80@ => @20@ |
2009-05-29 14:20 | Ed Sykes | Resolution | no change required => reopened |
2009-05-29 15:14 | Ken Moreland | Note Added: 0016595 | |
2009-05-29 15:14 | Ken Moreland | Status | @20@ => @80@ |
2009-05-29 15:14 | Ken Moreland | Resolution | reopened => no change required |
2009-05-29 15:46 | Ed Sykes | Note Added: 0016596 | |
2009-05-29 15:46 | Ed Sykes | Status | @80@ => @20@ |
2009-05-29 15:46 | Ed Sykes | Resolution | no change required => reopened |
2009-06-01 12:33 | Ken Moreland | Note Added: 0016600 | |
2009-06-01 12:33 | Ken Moreland | Status | @20@ => @80@ |
2009-06-01 12:33 | Ken Moreland | Resolution | reopened => no change required |
2009-06-03 21:47 | Alan Scott | Note Added: 0016628 | |
2009-06-03 21:47 | Alan Scott | Status | @80@ => closed |
2009-06-04 14:56 | Alan Scott | Relationship added | related to 0009111 |
2009-06-05 13:42 | Ed Sykes | Note Added: 0016647 | |
2009-06-05 13:42 | Ed Sykes | Status | closed => @20@ |
2009-06-05 13:42 | Ed Sykes | Resolution | no change required => reopened |
2009-06-08 10:12 | Ken Moreland | Note Added: 0016654 | |
2009-06-08 10:12 | Ken Moreland | Status | @20@ => closed |
2009-06-08 10:12 | Ken Moreland | Resolution | reopened => no change required |
