0009170 | ParaView | Bug | public | 2009-06-17 03:34 | 2016-08-12 09:57 | ||||
Reporter | Jean M. Favre | ||||||||
Assigned To | George Zagaris | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Target Version | NeedsVerification | Fixed in Version | |||||||
Summary | 0009170: ExtractSubset fails on a single block extracted from a hierarchical composite dataset | ||||||||
Description | tested with PV 3.6.1 and 3.7 selecting a single plane, or several planes of a 3D structured block extracted from a hierarchical dataset fails completely with the wrong bounds and the wrong offsets. The output generated is outside the input's bounds. A state file is included | ||||||||
Attached Files | hierarchicalextractblockextractsubset.pvsm [^] (114,545 bytes) 2009-06-17 03:34 | ||||||||
(0025145) Robert Maynard (developer) 2011-01-28 15:01 |
I was able to replicate the problem using ParaView 3.10. George, I am assigning you this bug in case you fix this bug while working on AMR datasets. |
(0037657) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-06-17 03:34 | Jean M. Favre | New Issue | |
2009-06-17 03:34 | Jean M. Favre | File Added: hierarchicalextractblockextractsubset.pvsm | |
2011-01-28 13:53 | Utkarsh Ayachit | Assigned To | => Robert Maynard |
2011-01-28 13:53 | Utkarsh Ayachit | Status | backlog => tabled |
2011-01-28 13:53 | Utkarsh Ayachit | Target Version | => NeedsVerification |
2011-01-28 15:01 | Robert Maynard | Note Added: 0025145 | |
2011-01-28 15:01 | Robert Maynard | Assigned To | Robert Maynard => George Zagaris |
2011-01-28 15:01 | Robert Maynard | Priority | normal => low |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037657 | |
2016-08-12 09:57 | Kitware Robot | Status | backlog => closed |
