0009200ParaView(No Category)public2009-06-24 03:492016-08-12 09:57
ReporterPaul Edwards
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0009200: Bug when saving colours in state files
DescriptionThere is a bug with colours and state files. If you set the colour via the toolbar then it will not be saved in a state file. However this does work if you set it via the "Object Inspector" in the "Display" tab. Steps to reproduce this are:
    * launch paraview
    * create sphere
    * change the colour - either "Object inspector" (gets saved in state file) or toolbar (doesn't get saved in state file)
    * save state
    * reload paraview
    * load state
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0017885)
2009-10-01 17:31
/cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleToolbar.cxx,v <-- Qt/Components/pqColorScaleToolbar.cxx
/cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorLinkAdaptor.cxx,v <-- Qt/Components/pqStandardColorLinkAdaptor.cxx
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/Qt/Components/pqStandardColorLinkAdaptor.h,v <-- Qt/Components/pqStandardColorLinkAdaptor.h
(0017886)
2009-10-01 17:35
For some reason I cannot close this bug -- don't have enough privileges.
(0037659)
Kitware Robot (administrator)
2016-08-12 09:57
Resolving issue as `moved`.
 Issue History
2009-06-24 03:49 Paul Edwards New Issue
2009-10-01 17:31 Utkarsh Ayachit Note Added: 0017885
2009-10-01 17:35 Utkarsh Ayachit Note Added: 0017886
2009-12-09 14:49 Berk Geveci Project @3@ => ParaView
2016-08-12 09:57 Kitware Robot Note Added: 0037659
2016-08-12 09:57 Kitware Robot Status expired => closed
2016-08-12 09:57 Kitware Robot Resolution open => moved
2016-08-12 09:57 Kitware Robot Assigned To => Kitware Robot
