0009250 | ParaView | Bug | public | 2009-07-09 09:33 | 2016-08-12 09:57 | ||||
Reporter | Bryn Lloyd | ||||||||
Summary | 0009250: XDMF writer does not write over existing data, if array length changes | ||||||||
Description | I am using a fairly recent CVS version of paraview. While using the xdmf writer, I noticed that the file <filename>.h5 is not overwritten. It seems to happen if the new data set contains arrays of different length to the arrays in the existing *.h5 file. Following warning message is displayed: blloyd@dock:~/src>XDMF Error in /home/blloyd/Kitware/Paraview-CVS/Utilities/Xdmf2/libsrc/XdmfHDF.cxx line 594 (Source and Target Spaces specify different sizes for path: /Unnamed/Connections) XDMF Error in /home/blloyd/Kitware/Paraview-CVS/Utilities/Xdmf2/libsrc/XdmfHDF.cxx line 595 (Source = 4508 items) XDMF Error in /home/blloyd/Kitware/Paraview-CVS/Utilities/Xdmf2/libsrc/XdmfHDF.cxx line 596 (Target = 43184 items) Is the writer supposed to behave like this, or is this a bug? | ||||||||
Additional Information | This can easily be verified by saving first unstructured grid A, then unstructured grid B as a XDMF file. | ||||||||
(0037663) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-07-09 09:33 | Bryn Lloyd | New Issue | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037663 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
