0009312 | ParaView | Bug | public | 2009-07-24 15:32 | 2009-12-16 19:08 | ||||
Priority | normal | Severity | crash | Reproducibility | have not tried | ||||
Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
Summary | 0009312: QAbstractItemModel::endRemoveRows: Invalid index ( 1 , 0 ) in model pqPipelineModel(0x230b550) | ||||||||
Description | Create two sphere sources. Apply "Glyph with Custom Sources" and choose each of the sphere's as one of the inputs. Now delete the glyph. You'll get errors: QAbstractItemModel::endRemoveRows: Invalid index ( 1 , 0 ) in model pqPipelineModel(0x230b550) | ||||||||
Relationships | ||||||
(0016981) Pat Marion (reporter) 2009-07-27 15:01 |
This may be the same bug, here is another way to trigger it: Create two spheres Apply the group datasets filter to both spheres Delete the group datasets filter Results in error message and sometimes segfault on exit. |
(0017317) Utkarsh Ayachit (administrator) 2009-09-05 15:25 |
This doesn't need to be a 3.6.2 bug since the issue started after upgrade to Qt 4.5 which is not officially supported by 3.6 releases. |
(0018693) Utkarsh Ayachit (administrator) 2009-12-04 11:26 |
There was weird logic in pqPipelineModel that somehow lead to invalid indexes. This was not being flagged until now, but Qt 4.5 started raising errors for it. Fixed that by cleaning up the implementation of pqPipelineModel to be a bit more tractable. The issue simply disappeared when I revivied the older version of pqPipelineModel (+some changes for multiple ports/visibility etc). /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- Qt/Components/CMakeLists.txt new revision: 1.175; previous revision: 1.174 /cvsroot/ParaView3/ParaView3/Qt/Components/pqFilterInputDialog.cxx,v <-- Qt/Components/pqFilterInputDialog.cxx new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowser.cxx,v <-- Qt/Components/pqPipelineBrowser.cxx new revision: delete; previous revision: 1.30 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowser.h,v <-- Qt/Components/pqPipelineBrowser.h new revision: delete; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserContextMenu.cxx,v <-- Qt/Components/pqPipelineBrowserContextMenu.cxx new revision: delete; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserContextMenu.h,v <-- Qt/Components/pqPipelineBrowserContextMenu.h new revision: delete; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserWidget.cxx,v <-- Qt/Components/pqPipelineBrowserWidget.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineBrowserWidget.h,v <-- Qt/Components/pqPipelineBrowserWidget.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineMenu.cxx,v <-- Qt/Components/pqPipelineMenu.cxx new revision: delete; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineMenu.h,v <-- Qt/Components/pqPipelineMenu.h new revision: delete; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineModel.cxx,v <-- Qt/Components/pqPipelineModel.cxx new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPipelineModel.h,v <-- Qt/Components/pqPipelineModel.h new revision: 1.7; previous revision: 1.6 |
(0018934) Alan Scott (manager) 2009-12-16 19:08 |
Tested remote server. |
2009-07-24 15:32 | Utkarsh Ayachit | New Issue | |
2009-07-27 15:01 | Pat Marion | Note Added: 0016981 | |
2009-09-05 15:25 | Utkarsh Ayachit | Note Added: 0017317 | |
2009-09-05 15:25 | Utkarsh Ayachit | Target Version | 3.6.2 => 3.8 |
2009-12-02 14:17 | Utkarsh Ayachit | Relationship added | has duplicate 0009651 |
2009-12-04 11:00 | Utkarsh Ayachit | Status | backlog => tabled |
2009-12-04 11:00 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-12-04 11:26 | Utkarsh Ayachit | Note Added: 0018693 | |
2009-12-04 11:26 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-12-04 11:26 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2009-12-04 11:26 | Utkarsh Ayachit | Resolution | open => fixed |
2009-12-16 19:08 | Alan Scott | Note Added: 0018934 | |
2009-12-16 19:08 | Alan Scott | Status | @80@ => closed |
