0009324 | ParaView | Feature | public | 2009-07-28 10:41 | 2011-02-11 21:38 | ||||
Reporter | David Doria | ||||||||
Priority | normal | Severity | minor | Reproducibility | N/A | ||||
Status | closed | Resolution | suspended | ||||||
Summary | 0009324: Allow 0 point size | ||||||||
Description | If for some reason a dataset has vertices as well as triangles, it would be nice to be able to set the representation to "surface" as well as the point size to "0" so that the triangles are displayed but the points at the vertices are not. | ||||||||
(0016985) Ken Moreland (manager) 2009-07-28 11:32 |
Not long ago on the mailing list there was talk about adding a feature that would allow you to suppress the drawing of points or lines. This is one way of providing that functionality, but another GUI mechanism should also be satisfactory, right? |
(0016986) David Doria (reporter) 2009-07-28 11:36 |
Sure, however - the result is just the ability to turn off points. Although if it can be done somewhere else, setting the point size to zero should trigger the same functionality. |
(0025288) David Partyka (developer) 2011-02-04 13:58 |
Please submit this as an idea to user voice. Unfortunately that point size setting is really a direct call to glPointSize() which doesn't allow point size of 0. |
(0025408) Alan Scott (manager) 2011-02-11 21:38 |
Agreed. |
2009-07-28 10:41 | David Doria | New Issue | |
2009-07-28 11:32 | Ken Moreland | Note Added: 0016985 | |
2009-07-28 11:36 | David Doria | Note Added: 0016986 | |
2011-02-04 13:58 | David Partyka | Note Added: 0025288 | |
2011-02-04 13:58 | David Partyka | Status | backlog => @80@ |
2011-02-04 13:58 | David Partyka | Resolution | open => suspended |
2011-02-04 13:58 | David Partyka | Assigned To | => David Partyka |
2011-02-11 21:38 | Alan Scott | Note Added: 0025408 | |
2011-02-11 21:38 | Alan Scott | Status | @80@ => closed |
