0009408ParaViewFeaturepublic2009-08-12 13:022010-01-22 15:50
ReporterKen Moreland
Assigned ToUtkarsh Ayachit
PriorityurgentSeverityminorReproducibilityhave not tried
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.8Fixed in Version3.8
Summary0009408: Enable zlib compression for image delivery
DescriptionBurlen Loring recently sent an email to the ParaView developer mailing list about comparisons of image transfer rate between using the current SQUIRT algorithm and then using zlib instead. He found that zlib outperformed SQUIRT in both compression rate and overall rendering rate. Thus, we should add zlib as an option (probably the default) for image delivery compression. If it really outperforms SQUIRT in all cases (including higher speed network connections), then perhaps it should replace SQUIRT altogether.
Burlen also noted that performing the SQUIRT-type color reductions also helped zlib be more effective. It may be worthwhile to do the same bit masking before the zlib compression.
A document detailing Burlen's performance measurements is attached.
Additional InformationEfficient remote interactivity is paramount to the near-term needs for large scale visualization at Sandia. Thus, I place a high priority for implementing this for ParaView 3.8.
TagsNo tags attached.
Project
Topic Name
Type
Attached Filespdf file icon PV3_remote_interactivity.pdf [^] (277,407 bytes) 2009-08-12 13:02
 Relationships
  Notes
(0019191)
2010-01-19 10:40
Burlen already committed a patch to add zlib compression to ParaView. It's accessible from Edit| Settings | Render View | Server tab.
(0019278)
Alan Scott (manager)
2010-01-22 15:50
Tested remote server, Linux, trunk.
 Issue History
2009-08-12 13:02 Ken Moreland New Issue
2009-08-12 13:02 Ken Moreland File Added: PV3_remote_interactivity.pdf
2010-01-19 10:40 Utkarsh Ayachit Note Added: 0019191
2010-01-19 10:40 Utkarsh Ayachit Status backlog => @80@
2010-01-19 10:40 Utkarsh Ayachit Fixed in Version => 3.8
2010-01-19 10:40 Utkarsh Ayachit Resolution open => fixed
2010-01-19 10:40 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2010-01-22 15:50 Alan Scott Note Added: 0019278
2010-01-22 15:50 Alan Scott Status @80@ => closed
2011-06-16 13:10 Zack Galbreath Category Feature Request => Feature
