0009487 | ParaView | Feature | public | 2009-09-04 10:03 | 2016-08-12 09:57 | ||||
Reporter | Renato Elias | ||||||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0009487: Load Ensight SOS files in serial sessions | ||||||||
Description | When working with "not so large" parallel models, sometimes it's easier to load them in serial sessions for tests, however, when they are stored in Ensight format we need to open each piece of model independently in order to recover the entire (unpartitioned) model. Since Ensight SOS file has the information of what case files must be loaded, it could be also used to load the entire model in serial sessions (why not?!). Note that it's already possible with other parallel formats suchs as Xdmf. | ||||||||
(0037696) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-09-04 10:03 | Renato Elias | New Issue | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037696 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
