0009502 | ParaView | Bug | public | 2009-09-07 09:37 | 2016-08-12 09:57 | ||||
Reporter | David Doria | ||||||||
Priority | normal | Severity | trivial | Reproducibility | always | ||||
Summary | 0009502: Tube filter needs a "vectors: none" option | ||||||||
Description | If a file contains lines where the end points of the lines have normals, but the normals are not appropriate for defining the orientation of a tube, the filter crashes. If you could select "Vectors: none", the filter would work fine (the equivalent thing to do that is possible now is to uncheck "normals" in Properties -> Cell/Point Array Status). | ||||||||
(0037700) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-09-07 09:37 | David Doria | New Issue | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037700 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
