| 0009526 | ParaView | Bug | public | 2009-09-12 10:56 | 2009-10-02 13:29 | ||||
| Product Version | |||||||||
| Target Version | 3.6.2 | Fixed in Version | 3.8 | ||||||
| Summary | 0009526: Background color reset to default when saving screen shots using a different palette. | ||||||||
| Description | 1. Open a new Paraview scene, and set the background color (to white for example) 2. Import or create a VTK object 3. Export screenshot with the screen or print palette. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0017707) Utkarsh Ayachit (administrator) 2009-09-22 13:46 |
This is weird. I was able to reproduce this bug when I added it (someone reported it on the mailing list). But now I cannot reproduce it. Even tried with 3.6 branch. Seems to work just fine. |
(0017724) Alan Scott (manager) 2009-09-22 22:21 |
Looks OK to me. I assume you mean "Save Screenshot" Tested local client, trunk. |
(0017883) Utkarsh Ayachit (administrator) 2009-10-01 15:59 edited on: 2009-10-01 17:38 |
Fixed BUG 0009526. The background color change widget was not breaking the link with the color palette when the user explicitly changed the color. Hence when screen shot was saved, it would restore the color to that what was set by the palette. Fixed by making the render view options dialog use the correct color button which allows the user to choose standard color links to custom color. /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqRenderViewOptions.ui,v <-- Qt/Components/Resources/UI/pqRenderViewOptions.ui new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderViewOptions.cxx,v <-- Qt/Components/pqRenderViewOptions.cxx new revision: 1.7; previous revision: 1.6 |
(0017887) Utkarsh Ayachit (administrator) 2009-10-01 17:39 |
Committed to 3.6.2 branch /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqRenderViewOptions.ui,v <-- Qt/Components/Resources/UI/pqRenderViewOptions.ui new revision: 1.4.2.1; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqRenderViewOptions.cxx,v <-- Qt/Components/pqRenderViewOptions.cxx new revision: 1.6.6.1; previous revision: 1.6 |
(0017908) Alan Scott (manager) 2009-10-02 13:29 |
Once again, looks OK to me. Tested local server, 3.6.2, XP. |
| Notes |
| Issue History | |||
| 2009-09-12 10:56 | Utkarsh Ayachit | New Issue | |
| 2009-09-22 13:46 | Utkarsh Ayachit | Note Added: 0017707 | |
| 2009-09-22 13:46 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2009-09-22 13:46 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
| 2009-09-22 13:46 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2009-09-22 22:21 | Alan Scott | Note Added: 0017724 | |
| 2009-09-22 22:21 | Alan Scott | Status | @80@ => closed |
| 2009-10-01 15:59 | Utkarsh Ayachit | Note Added: 0017883 | |
| 2009-10-01 15:59 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
| 2009-10-01 16:00 | Utkarsh Ayachit | Status | closed => tabled |
| 2009-10-01 17:38 | Utkarsh Ayachit | Note Edited: 0017883 | |
| 2009-10-01 17:39 | Utkarsh Ayachit | Note Added: 0017887 | |
| 2009-10-01 17:39 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2009-10-01 17:39 | Utkarsh Ayachit | Resolution | unable to reproduce => fixed |
| 2009-10-02 13:29 | Alan Scott | Note Added: 0017908 | |
| 2009-10-02 13:29 | Alan Scott | Status | @80@ => closed |
| Issue History |
