0009530 | ParaView | Bug | public | 2009-09-14 09:36 | 2010-04-26 19:59 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | Robert Maynard | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Product Version | 3.6 | ||||||||
Summary | 0009530: ParaView crashes when loading a state, deleting all objects and reloading the same state again | ||||||||
Description | Go to the directory Data where the file blow.vtk is stored. Start ParaView Load the attached state file Delete all objects one by one, starting from the bottom Load the same state file again => Both ParaView 3.6.1 and a top of cvs build will segfault. | ||||||||
Attached Files | causing.segfault.pvsm [^] (290,930 bytes) 2009-09-14 09:36 causing.segfault.recreated.pvsm [^] (166,906 bytes) 2010-04-20 17:52 | ||||||||
(0020311) Sven Buijssen (reporter) 2010-04-20 17:53 |
I've recreated the pipeline as the first state file seems not compatible any more with PV 3.8.0 RC1. Good news, the issue is gone. |
(0020417) Alan Scott (manager) 2010-04-26 19:59 |
Reporter of the bug says it is fixed. |
2009-09-14 09:36 | Sven Buijssen | New Issue | |
2009-09-14 09:36 | Sven Buijssen | File Added: causing.segfault.pvsm | |
2010-04-20 17:52 | Sven Buijssen | File Added: causing.segfault.recreated.pvsm | |
2010-04-20 17:53 | Sven Buijssen | Note Added: 0020311 | |
2010-04-21 08:57 | Robert Maynard | Status | backlog => tabled |
2010-04-21 08:57 | Robert Maynard | Assigned To | => Robert Maynard |
2010-04-21 09:26 | Robert Maynard | Status | tabled => @80@ |
2010-04-21 09:26 | Robert Maynard | Resolution | open => fixed |
2010-04-26 19:59 | Alan Scott | Note Added: 0020417 | |
2010-04-26 19:59 | Alan Scott | Status | @80@ => closed |
