0009531 | ParaView | Bug | public | 2009-09-14 11:10 | 2016-08-12 09:57 | ||||
Assigned To | Julien Finet | ||||||||
Summary | 0009531: Scatter plot "camera" should be reset when coordinates are changed | ||||||||
Description | When you change the coordinates used for a scatter plot, it often results in a different scale on that axis, which makes the current view pretty much invalid. When a new coordinate is selected, the camera should automatically be reset. To see the problem in action, do the following: 1. Load disk_out_ref.ex2. All variables on. Apply. 2. Create a scatter plot view. Make disk_out_ref visible. 3. In the Display panel, change X Coords to Temp. When you changed the X Coords from the point X coords to the Temp field, the range changed from about -6 to 6 to about 200-900. The data is now completely outside the current view and you cannot see anything. Clicking reset camera will bring the data back into the view. | ||||||||
(0037704) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-09-14 11:10 | Ken Moreland | New Issue | |
2009-09-14 11:10 | Ken Moreland | Status | backlog => tabled |
2009-09-14 11:10 | Ken Moreland | Assigned To | => Julien Finet |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037704 | |
