0009549 | ParaView | Bug | public | 2009-09-16 03:18 | 2011-09-01 13:31 | ||||
Reporter | Sven Buijssen | ||||||||
Product Version | 3.6 | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0009549: Python Shell issues warning on init if simple custom filter is loaded | ||||||||
Description | Remove any ParaView config files (Unix/Mac: rm -rf ~/.config/ParaView/ParaView3.6.ini) Invoke paraview Tools - Manage Custom Filter - Import Load attached file Tools - Python Shell => the initial import of paraview.simple will raise the following warning: Warning: Curvature is being overwritten. This may point to an issue in the ParaView configuration files Warning can be removed by merely removing the line CustomFilters= in section [General] of ~/.config/ParaView/ParaView<version>.ini and restarting paraview, but appears again as soon as another custom filter is loaded. Happens with ParaView 3.6.1 and top of cvs build. Happens with other custom filters as well: Apply an arbitrary filter and turn it into a custom filter. The kind of warning changes, but there is always one per loaded custom filter. | ||||||||
Attached Files | ![]() | ||||||||
(0018925) Sven Buijssen (reporter) 2009-12-16 12:42 |
Resolved by Utilities/VTKPythonWrapping/paraview/servermanager.py revision 1.70. |
(0019109) Alan Scott (manager) 2010-01-12 18:34 |
Tested local server. |
2009-09-16 03:18 | Sven Buijssen | New Issue | |
2009-09-16 03:18 | Sven Buijssen | File Added: cell.centers.as.custom.filter.xml | |
2009-12-16 12:42 | Sven Buijssen | Note Added: 0018925 | |
2009-12-16 12:58 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-12-16 12:58 | Utkarsh Ayachit | Fixed in Version | => Development |
2009-12-16 12:58 | Utkarsh Ayachit | Resolution | open => fixed |
2009-12-16 12:58 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-01-12 18:34 | Alan Scott | Note Added: 0019109 | |
2010-01-12 18:34 | Alan Scott | Status | @80@ => closed |
2011-09-01 13:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.12 |
