0009787 | ParaView | Bug | public | 2009-10-28 04:09 | 2016-08-12 09:57 | ||||
Reporter | Takuya OSHIMA | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Summary | 0009787: Stream Tracer crashes pvservers when the number of pvserver processes is larger than the number of dataset pieces | ||||||||
Description | Start ParaView (3.7 CVS as of 28/Oct/09) in client/server mode with 9 pvserver processes, * Open Iron_Protein.ImageData.xmf (which has 8 dataset pieces) * Select Filters->Stream Tracer * Apply Then pvservers crash (on OS X). If they don't, * Delete to delete Stream Tracer * Delete again to delete Iron_Protein.ImageData.xmf Then pvservers crash (on Linux). | ||||||||
Additional Information | The backtrace by gdb attached to the 9th process. (on OS X 10.6.1, Qt 4.5.3 Cocoa, 64bit): Program received signal EXC_BAD_ACCESS, Could not access memory. Reason: KERN_INVALID_ADDRESS at address: 0x000000000000425b 0x0000000108a8a7cf in vtkInformation::GetAsObjectBase () (gdb) where #0 0x0000000108a8a7cf in vtkInformation::GetAsObjectBase () #1 0x0000000108a8f049 in vtkInformationIntegerKey::Get () #2 0x00000001087e79e4 in vtkStreamingDemandDrivenPipeline::ExecuteDataEnd () #3 0x00000001086ce3e3 in vtkDemandDrivenPipeline::ExecuteData () #4 0x00000001086ae3d1 in vtkCompositeDataPipeline::ExecuteData () #5 0x00000001086d1998 in vtkDemandDrivenPipeline::ProcessRequest () #6 0x00000001087ea759 in vtkStreamingDemandDrivenPipeline::ProcessRequest () #7 0x00000001086ad4c1 in vtkCompositeDataPipeline::ProcessRequest () #8 0x00000001086cff0a in vtkDemandDrivenPipeline::UpdateData () 0000009 0x00000001087ea4cd in vtkStreamingDemandDrivenPipeline::Update () #10 0x000000010327d2cc in vtkAlgorithm_Update () 0000011 0x000000010328345f in vtkAlgorithmCommand () #12 0x00000001034227e7 in vtkPolyDataAlgorithmCommand () #13 0x00000001029aa597 in vtkStreamTracerCommand () #14 0x00000001020c1c47 in vtkPStreamTracerCommand () #15 0x0000000102063067 in vtkDistributedStreamTracerCommand () #16 0x0000000103a8c33b in vtkClientServerInterpreter::ProcessCommandInvoke () #17 0x0000000103a8ce8e in vtkClientServerInterpreter::ProcessOneMessage () #18 0x0000000103a8d2dd in vtkClientServerInterpreter::ProcessStream () #19 0x000000010008afe7 in vtkSelfConnection::ProcessStreamLocally () #20 0x0000000105f15b6e in vtkMultiProcessController::ProcessRMI () #21 0x0000000105f16b7d in vtkMultiProcessController::ProcessRMIs () #22 0x0000000100042c09 in vtkProcessModule::Start () #23 0x000000010023f934 in vtkPVMain::Run () #24 0x0000000100018d08 in main () On Linux 64bit (Ubuntu 8.04, Qt 4.5.3, gcc 4.2.4): Program received signal SIGSEGV, Segmentation fault. [Switching to Thread 0x7ff85b1156f0 (LWP 7512)] 0x0000000000000000 in ?? () (gdb) where #0 0x0000000000000000 in ?? () #1 0x00007ff849ed402f in vtkGarbageCollectorImpl::CollectComponent () from /usr/local/src/paraview/build/bin/libvtkCommon.so.pv3.7 #2 0x00007ff849ed4e4a in vtkGarbageCollectorImpl::CollectInternal () from /usr/local/src/paraview/build/bin/libvtkCommon.so.pv3.7 #3 0x00007ff849ed4f8d in vtkGarbageCollector::Collect () from /usr/local/src/paraview/build/bin/libvtkCommon.so.pv3.7 #4 0x00007ff849f2cd71 in vtkObject::UnRegisterInternal () from /usr/local/src/paraview/build/bin/libvtkCommon.so.pv3.7 #5 0x00007ff853bdda76 in vtkClientServerStreamInternals::~vtkClientServerStreamInternals () from /usr/local/src/paraview/build/bin/libvtkClientServer.so #6 0x00007ff853bd8a91 in vtkClientServerStream::~vtkClientServerStream () from /usr/local/src/paraview/build/bin/libvtkClientServer.so #7 0x00007ff853bcdb87 in vtkClientServerInterpreter::ProcessCommandDelete () from /usr/local/src/paraview/build/bin/libvtkClientServer.so #8 0x00007ff853bd3152 in vtkClientServerInterpreter::ProcessOneMessage () from /usr/local/src/paraview/build/bin/libvtkClientServer.so 0000009 0x00007ff853bd360d in vtkClientServerInterpreter::ProcessStream () from /usr/local/src/paraview/build/bin/libvtkClientServer.so #10 0x00007ff853bd3674 in vtkClientServerInterpreter::ProcessStream () from /usr/local/src/paraview/build/bin/libvtkClientServer.so 0000011 0x00007ff85ace85a5 in vtkSelfConnection::ProcessStreamLocally () from /usr/local/src/paraview/build/bin/libvtkPVServerCommon.so #12 0x00007ff84c59c760 in vtkMultiProcessController::ProcessRMI () from /usr/local/src/paraview/build/bin/libvtkParallel.so.pv3.7 #13 0x00007ff84c59c83e in vtkMultiProcessController::ProcessRMIs () from /usr/local/src/paraview/build/bin/libvtkParallel.so.pv3.7 #14 0x00007ff85aca06da in vtkProcessModule::Start () from /usr/local/src/paraview/build/bin/libvtkPVServerCommon.so #15 0x00007ff85a8f2ae9 in vtkPVMain::Run () from /usr/local/src/paraview/build/bin/libvtkPVFilters.so #16 0x000000000040140b in main () | ||||||||
(0037738) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-10-28 04:09 | Takuya OSHIMA | New Issue | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037738 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
