| 0009808 | ParaView | Feature | public | 2009-10-30 14:03 | 2015-01-11 08:16 | ||||
| Priority | high | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0009808: Ability to automatically select min, max, or average cell or point at a time step. | ||||||||
| Description | We need to add the functionality to have ParaView automatically select the cell or point that represents a variable's min or max or average value. This should work for all time steps - thus the selected cell or point would move around with time. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | remove_duplicate_tiff_readers | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0018304) Alan Scott (manager) 2009-10-30 14:10 |
A stretch goal would be to use the output of this filter as input to the plot selection over time filter. |
(0022711) Alan Scott (manager) 2010-10-26 17:10 |
A user of mine just asked for this "stretch goal". We really do need to include my note above as part of this feature. |
(0022712) Alan Scott (manager) 2010-10-26 17:10 |
(0029664) Alan Scott (manager) 2012-11-07 21:33 |
Not sure if this belongs assigned to Robert, but issuing a Todo. The Find Data dialog is important. |
(0032481) David C. Lonie (developer) 2014-03-18 08:40 |
This bug is quite old, and seems to already be implemented: 1) Open can.ex2, load all arrays 2) Open find data dialog 3) Find Cells of can.ex2, set query to 'EQPS == max(EQPS)' 4) Walk through timesteps. The selection will updated. Feel free to reopen if there is more work needed. |
(0032483) Utkarsh Ayachit (administrator) 2014-03-18 13:11 |
(developers should never close bugs directly without going through gatekeeper review/customer review). I've also change workflow permissions to reflect the same. |
(0032486) Alan Scott (manager) 2014-03-19 20:03 |
From an e-mail thread between Dave, Utkarsh and me: From Alan: > What I want is to have some very basic options such as min and max > available as a button, or pull down menus, etc. Think of a very > bright person that has never programmed in their life (such as a PhD > in Geology or an MD doing medical research). If I were king, and i > realize this is harder, I would like to be able to select the max and > min cell per time step, and the max and min over all time. > > At the minimum - total minimum, we should have it trivial to find good > quality documentation - with examples - of how this works. > > My/our rule of thumb is that if it doesn't work correctly in parallel, > it is broken. And, misrepresenting data is significantly worse than > not giving any data at all. And thanks for testing all the > combinations (which is what I will do when I close it). Regarding the query on the Find Data: From Dave: > > BTW, the Query option is in a drop-down menu on the find data dialog. > It's the first combo box in the second section of the dialog. From Alan > > Ah, I found it. Big picture - I don't like > it. We shouldn't have a list of variable names intermixed with a > command. It is confusing. Could we move query to be its own line, or > its own button, or something? At the least, could we create a space > above Query and bold any commands (such as Query)? From Dave: > > I'm still tracking down the issues with doing this on a distributed dataset. > I got the calculations to run without crashing, but got different > results depending on the data distribution (e.g. multiblock vs. single > data set, with/without D3, etc). I'll hold off on the GUI elements > until this is behaving properly. > > |
(0032487) Alan Scott (manager) 2014-03-19 20:04 |
Nope, doesn't work. See notes from the e-mail thread below. |
(0032551) David C. Lonie (developer) 2014-04-08 10:55 |
Fixed problems with the "arrayname == global_max(arrayname)" query on datasets with unevenly distributed data arrays by syncing array names and ensuring that all processors have the same names available in their scope. This does not address the usability concerns raised by Alan. Further GUI work will be needed to expose the functionality in a user-friendly way, but now the underpinnings should be ready. |
(0032579) Utkarsh Ayachit (administrator) 2014-04-09 09:55 |
SUMMARY --------------------------------------------- Topics merged into master: 14220-hide-decoration-button (VTK) 14646-scalar-bar-borders 14663_timesteps_indicator 9808-distributed-query-selection catalyst-rgbz-plugin (VTK) view-settings --------------------------------------------- Topics reverted from next: expand_fragment_integration |
(0032580) Utkarsh Ayachit (administrator) 2014-04-09 09:55 |
leaving this one open so I can test it before passing on to Alan. |
(0032589) David C. Lonie (developer) 2014-04-14 09:34 |
9808-bugfix should fix the dashboard issues on blight. |
(0032645) Utkarsh Ayachit (administrator) 2014-05-17 22:23 |
Argh, still doesn't work fully. The following query fails: + builtin mode + open can.ex2, move to timestep > 0 (e.g. 15) + run query for Points, VEL[:,1] == global_min(VEL[:,1]) -- we get two points selected -- min for each block is selected. + if you run Python calculator with expression "global_min(VEL[:,1])", it works fine. + It's curious that cell query, EQPS == global_min(EQPS) works just fine |
(0032646) Utkarsh Ayachit (administrator) 2014-05-17 22:29 |
Some more insight into the problem: Attached is a simple dataset with 2 spheres as 2 blocks with "Result" array set to 1 and 2 respectively. The following query fails: Result[:,0] == global_max(Result[:,0]) The following succeeds: Result == global_max(Result) The problem stems from the fact that Result[:,0] is a new array and hence the code doesn't treat it as a composite-array. I think we may have to give up on Python implementation for this and just and custom extract selection support for max/min/mean. |
(0033034) Utkarsh Ayachit (administrator) 2014-07-18 10:07 |
Alright, resolving this again, fingers crossed. The FindData dialog now has "is min", "is max", "is mean", "is mean within threshold" options that will help you find elements that min, max etc. And it should work in parallel too. Note, it uses NumPy. Also another caveat: FindData by just IDs is currently not working and it will raise warnings. I'm working on it. Feel free to leave this bug open till that's resolved. I'm marking this "customer review" so that you can test the min/max functionality. |
(0033039) Alan Scott (manager) 2014-07-18 20:46 |
Yes!! OK, I will test. OK, tested! It died. I did the following: master, Linux, remote server (8 pvservers). Numpy support Client side: On (and using my numpy), version 1.7.1 Numpy support Server side: On (and using my numpy), version 1.6.1 (Could this be the problem?) Python version matches (and is mine), 2.7.5. Opened g1s1 (ask me, Do Not Release). Find Data/ EQPS/ find max Died. Here is what the client put out: paraview: /.../ParaView4/ParaViewCore/ClientServerCore/Rendering/vtkSpreadSheetView.cxx:83: bool<unnamed>::OrderByNames::operator()(vtkAbstractArray*, vtkAbstractArray*): Assertion `a1Index == static_cast< int >(~0u >> 1) && a2Index == static_cast< int >(~0u >> 1)' failed. Server side just grumbled that the socket had died. |
(0033042) Alan Scott (manager) 2014-07-18 21:11 |
Tested remote server, can.exo, and disk_out_ref.exo. Worked great! |
(0033045) Utkarsh Ayachit (administrator) 2014-07-21 14:23 |
Grrr...this seems to work for me. Can you try again please? Also make sure you start with a clean build on client and server. The python code build/install logic is a bug wacky. |
(0033049) Alan Scott (manager) 2014-07-21 21:23 |
Still asserts. I replicated it as follows: Deleted all .config/ParaView/* files. Master as of today, clean build, Linux, 8 pvservers, client debug, client running under totalview. Assert is from the client. Open g1s1. There will be 16 files. All variables on. Apply. Click on the Find Data icon (I didn't use the Edit/ Find Data menu.) Change Global Id to EQPS. Change "is" to "Is Max". Click on Run Selection Query. Assert. We hit an assert in vtkSpreadSheetView.cxx, line 83. Basically, a1->GetName() and a2->GetName() don't equal anything in the order[] array. I believe that a1 and a2 GetName() is just null. Thus, a result is never found, and the assert asserts. Furthermore, in vtkSpreadSheetView.cxx, vtkSpreadSheetView::GetNumberOfColumns(), I believe that this->Internals->ActiveRepresentation and MostRecentlyAccessedBlock may be bad. Sending Utkarsh a screenshot at this point. Note that I am showing this, then what is in *(this), then *(this->Internals). Next, showing the call stack, and what is in FetchBlock. Notice that block index == 0. Not sure where else to go from here... :-) |
(0033077) Utkarsh Ayachit (administrator) 2014-07-24 16:12 |
commit f6dc4055de7af65df0e1bde427ca09416611bf42 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Jul 24 16:11:40 2014 -0400 Fix segfault seen in BUG 0009808. On certain platforms, the comparison operator is called for sorting with same arguments. We skipped that case in our "assert". Fixed that. Change-Id: I8fdc496d2b078878dca21eca64b8b8ce3547285 |
(0033092) Utkarsh Ayachit (administrator) 2014-07-25 09:35 |
SUMMARY --------------------------------------------- Topics merged into master: 13575_PV_PLUGIN_DEBUG 14771_fix_global_annotation_filter 14885_python_view_crash fix_apply_pqProxyWidgetDialog fix_get_proxies fix-int64_t (VTK) remove_duplicate_tiff_readers remove_matplotlib_utilities |
(0033112) Alan Scott (manager) 2014-07-28 18:17 |
Spectacular!!!!! Tested g1s1, max EQPS, remote server, Linux, master. |
| Notes |
| Issue History | |||
| 2009-10-30 14:03 | Alan Scott | New Issue | |
| 2009-10-30 14:10 | Alan Scott | Note Added: 0018304 | |
| 2010-08-30 22:22 | Alan Scott | Relationship added | related to 0010958 |
| 2010-09-01 11:32 | Utkarsh Ayachit | Target Version | => 3.10.shortlist |
| 2010-10-26 17:10 | Alan Scott | Note Added: 0022711 | |
| 2010-10-26 17:10 | Alan Scott | Note Added: 0022712 | |
| 2010-12-01 16:53 | Utkarsh Ayachit | Assigned To | => Robert Maynard |
| 2010-12-01 16:53 | Utkarsh Ayachit | Status | backlog => tabled |
| 2010-12-01 16:53 | Utkarsh Ayachit | Priority | normal => high |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| 2011-06-24 14:24 | Alan Scott | Status | expired => backlog |
| 2011-06-24 14:24 | Alan Scott | Resolution | open => reopened |
| 2011-06-24 14:24 | Alan Scott | Status | backlog => todo |
| 2011-06-27 08:32 | Utkarsh Ayachit | Project | => Sandia |
| 2012-05-31 10:23 | Utkarsh Ayachit | Status | todo => backlog |
| 2012-11-07 21:33 | Alan Scott | Note Added: 0029664 | |
| 2012-11-07 21:33 | Alan Scott | Status | backlog => todo |
| 2012-12-11 09:47 | Sebastien Jourdain | Assigned To | Robert Maynard => David Thompson |
| 2014-01-16 17:00 | Utkarsh Ayachit | Type | => incorrect functionality |
| 2014-01-16 17:00 | Utkarsh Ayachit | Assigned To | David Thompson => David C. Lonie |
| 2014-01-16 17:00 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-03-18 08:40 | David C. Lonie | Note Added: 0032481 | |
| 2014-03-18 08:40 | David C. Lonie | Status | todo => closed |
| 2014-03-18 08:40 | David C. Lonie | Resolution | reopened => fixed |
| 2014-03-18 08:40 | David C. Lonie | Fixed in Version | => git-master |
| 2014-03-18 13:10 | Utkarsh Ayachit | Status | closed => customer review |
| 2014-03-18 13:11 | Utkarsh Ayachit | Note Added: 0032483 | |
| 2014-03-19 20:03 | Alan Scott | Note Added: 0032486 | |
| 2014-03-19 20:04 | Alan Scott | Note Added: 0032487 | |
| 2014-03-19 20:04 | Alan Scott | Status | customer review => todo |
| 2014-04-08 10:55 | David C. Lonie | Topic Name | => 9808-distributed-query-selection |
| 2014-04-08 10:55 | David C. Lonie | Note Added: 0032551 | |
| 2014-04-08 10:55 | David C. Lonie | Status | todo => gatekeeper review |
| 2014-04-08 10:55 | David C. Lonie | Resolution | fixed => open |
| 2014-04-09 09:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-04-09 09:55 | Utkarsh Ayachit | Note Added: 0032579 | |
| 2014-04-09 09:55 | Utkarsh Ayachit | Assigned To | David C. Lonie => Utkarsh Ayachit |
| 2014-04-09 09:55 | Utkarsh Ayachit | Note Added: 0032580 | |
| 2014-04-09 09:55 | Utkarsh Ayachit | Status | customer review => gatekeeper review |
| 2014-04-09 09:55 | Utkarsh Ayachit | Resolution | open => fixed |
| 2014-04-14 09:33 | David C. Lonie | Status | gatekeeper review => active development |
| 2014-04-14 09:34 | David C. Lonie | Topic Name | 9808-distributed-query-selection => 9808-distributed-query-selection, 9808-bugfix |
| 2014-04-14 09:34 | David C. Lonie | Note Added: 0032589 | |
| 2014-04-14 09:34 | David C. Lonie | Status | active development => gatekeeper review |
| 2014-05-17 22:23 | Utkarsh Ayachit | Note Added: 0032645 | |
| 2014-05-17 22:23 | Utkarsh Ayachit | Status | gatekeeper review => todo |
| 2014-05-17 22:29 | Utkarsh Ayachit | Note Added: 0032646 | |
| 2014-07-18 10:05 | Utkarsh Ayachit | Topic Name | 9808-distributed-query-selection, 9808-bugfix => fix_find_data |
| 2014-07-18 10:05 | Utkarsh Ayachit | Status | todo => gatekeeper review |
| 2014-07-18 10:07 | Utkarsh Ayachit | Note Added: 0033034 | |
| 2014-07-18 10:07 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-07-18 20:46 | Alan Scott | Note Added: 0033039 | |
| 2014-07-18 21:11 | Alan Scott | Note Added: 0033042 | |
| 2014-07-21 14:23 | Utkarsh Ayachit | Note Added: 0033045 | |
| 2014-07-21 21:23 | Alan Scott | Note Added: 0033049 | |
| 2014-07-24 16:12 | Utkarsh Ayachit | Note Added: 0033077 | |
| 2014-07-24 16:13 | Utkarsh Ayachit | Topic Name | fix_find_data => remove_duplicate_tiff_readers |
| 2014-07-24 16:13 | Utkarsh Ayachit | Status | customer review => gatekeeper review |
| 2014-07-25 09:35 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
| 2014-07-25 09:35 | Utkarsh Ayachit | Note Added: 0033092 | |
| 2014-07-25 09:38 | Utkarsh Ayachit | Status | backlog => customer review |
| 2014-07-28 18:17 | Alan Scott | Note Added: 0033112 | |
| 2014-07-28 18:17 | Alan Scott | Status | customer review => closed |
| 2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| 2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 879dbb3d |
| 2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master f6dc4055 |
| Issue History |
