0009844 | ParaView | Bug | public | 2009-11-04 22:03 | 2010-01-21 17:42 | ||||
Target Version | Fixed in Version | 3.8 | |||||||
Summary | 0009844: Python trace doesn't work reading in CTH files | ||||||||
Description | The Python trace code messes up when trying to read in multi-file CTH files. ParaView 3.6.2, XP, local server. Start Paraview. Open Dave's large cth fileset. Delete all. Start trace. File/ Recent Files/ read in Dave's large cth dataset. Stop trace. Save trace. Run trace. It will fail. The problem is in the trace file. Instead of the following line: spcta_* = SpyPlotReader( FileName='/storz/wascott/data/dbkarel/cth-large/spcta.0' ) We should have the following line (or some version of same): spcta = SpyPlotReader( FileName='/storz/wascott/data/dbkarel/cth-large/spcta.0' ) Notice that I got rid of the _* after spcta. | ||||||||
(0019226) Utkarsh Ayachit (administrator) 2010-01-20 16:22 |
This seems to have been fixed already. |
(0019253) Alan Scott (manager) 2010-01-21 17:42 |
Tested XP, local server, trunk. |
2009-11-04 22:03 | Alan Scott | New Issue | |
2010-01-20 16:22 | Utkarsh Ayachit | Note Added: 0019226 | |
2010-01-20 16:22 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-01-20 16:22 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-01-20 16:22 | Utkarsh Ayachit | Resolution | open => no change required |
2010-01-20 16:22 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-01-21 17:42 | Alan Scott | Note Added: 0019253 | |
2010-01-21 17:42 | Alan Scott | Status | @80@ => closed |
