0009958 | ParaView | Bug | public | 2009-11-23 17:04 | 2016-08-12 09:57 | ||||
Assigned To | Yumin Yuan | ||||||||
Summary | 0009958: Clip filter not updating when ClipType changed in Python | ||||||||
Description | When creating and editing a clip filter in Python, the filter does not update properly after the ClipType is changed. To replicate, enter the following script in the Python shell. wavelet = Wavelet() clip = Clip() clip.InsideOut = 1 clip.ClipType = "Box" clip.ClipType.Scale = [0.5,0.5,0.5] Show() Render() At this point the filters should all be executed and updated. However, the output of the clip filter is empty. | ||||||||
Project | Sandia | ||||||||
(0026271) Utkarsh Ayachit (administrator) 2011-04-27 16:27 |
Seems to work now. |
(0026415) Ken Moreland (manager) 2011-05-02 21:39 |
I just pulled the latest on Mac and still have the same problem. |
(0030739) Yumin Yuan (developer) 2013-05-09 15:41 |
Ok, I figured out the problem. By default the clip box's bounds is set to (0,1,0,1,01), which you may notice after clip.ClipType = "Box", and "clip.ClipType.Scale = [0.5,0.5,0.5]" will make the bounds become (0,0.5,0,0.5,0, 0.5), therefore the output of clip is empty as expected, because it only considers point (0,0,0) is inside. If you add "clip.Crinkleclip = 1", you can see some cells. If you do "clip.ClipType.Bounds = [-5.0, 5.0, -5.0, 5.0, -5.0, 5.0]", instead of "clip.ClipType.Scale = [0.5,0.5,0.5]", the output will be correct. In summary, when running from python, the clip box's bounds needs to be explicitly set currently, just like the radius of clip-with-sphere, in this case we can say this bug is a user error. However, the other (ideal) option will be using the bounds of input data for the clip-box's bounds or clip-sphere's radius (just like doing it from GUI). I will let you guys decide how I should proceed from here. |
(0030756) Yumin Yuan (developer) 2013-05-13 11:44 |
To really fix this, more work needs to be planned. For now, put it in to-do list. |
(0037750) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-11-23 17:04 | Ken Moreland | New Issue | |
2010-04-16 02:09 | Utkarsh Ayachit | Target Version | 3.8 => 3.10 |
2011-04-27 16:27 | Utkarsh Ayachit | Note Added: 0026271 | |
2011-04-27 16:27 | Utkarsh Ayachit | Status | backlog => @80@ |
2011-04-27 16:27 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2011-04-27 16:27 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2011-04-27 16:27 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-05-02 21:39 | Ken Moreland | Note Added: 0026415 | |
2011-05-02 21:39 | Ken Moreland | Status | @80@ => @20@ |
2011-05-02 21:39 | Ken Moreland | Resolution | unable to reproduce => reopened |
2013-01-08 21:30 | Alan Scott | Project | => Sandia |
2013-01-08 21:30 | Alan Scott | Type | => incorrect functionality |
2013-05-03 14:01 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Yumin Yuan |
2013-05-07 17:04 | Yumin Yuan | Status | backlog => todo |
2013-05-07 17:04 | Yumin Yuan | Status | todo => active development |
2013-05-09 15:41 | Yumin Yuan | Note Added: 0030739 | |
2013-05-13 11:44 | Yumin Yuan | Note Added: 0030756 | |
2013-05-13 11:44 | Yumin Yuan | Status | active development => todo |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037750 | |
2016-08-12 09:57 | Kitware Robot | Status | todo => closed |
2016-08-12 09:57 | Kitware Robot | Fixed in Version | 3.12 => |
2016-08-12 09:57 | Kitware Robot | Resolution | reopened => moved |
