View Issue Details [ Jump to Notes ] [ Print ]
0009998ParaViewBugpublic2009-12-05 11:462010-11-16 17:45
ReporterUtkarsh Ayachit
Assigned ToDavid Partyka
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.8Fixed in Version3.8
Summary0009998: Installation Issues
DescriptionThis bug collects numerous installation issues people have run into with previous ParaView installs.
All Platforms:
* Make install doesn't work well -- looks like prefix is being ignored.
* Development install doesn't work well.
Linux:
* Plugins are being installed under "/bin".
* Documentation is not installed at standard locations
Windows:
* "bin" and "lib" dirs are created which seems unnecessary. On Windows, we can just put everything under the same dir.
Mac:
* ... please remember that Qt-cocoa needs the qt_menu.nib directory in the Resources. Also, I think I had trouble with QT_QTCLUCENE_LIBRARY not being included in the bundle and a missing empty qt.conf file (to prevent Qt from loading png/tiff plugins). ~ Michael Wild
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
parent of 0009868closedDavid Partyka vtkParse.h is missing from the install tree (PARAVIEW_INSTALL_DEVELOPMENT)
parent of 0009867closedDavid Partyka building server side plugin against install tree (with PARAVIEW_INSTALL_DEVELOPMENT ON) create unloadable plugins
parent of 0009977closedDavid Partyka For development install, add option to not install Qt libraries.
parent of 0008712closedDavid Partyka development install issue
parent of 0010558closedDavid Partyka Make install doesn't work well.
  Notes
(0018696)
Mike Jackson (reporter)
2009-12-05 15:32
=== OS X ====
My custom plugins are NOT being copied into the final installed location.
(0018697)
2009-12-05 15:54
==== OS X ====
The ParaView Application bundle is being forcibly installed into /Applications when I specifically set a CMAKE_INSTALL_PREFIX of /Users/Shared/Toolkits/ParaView-3.6.1
 Following suggestions in the shell script file:
# InstallPrefix environment variable may be set by caller...
# If not, default to "$DESTDIR/Applications"
 I tried "export InstallPrefix=/Users/Shared/Toolkits/ParaView-3.6.1" and the make install. Still put ParaView.app into /Applications
If this is going to be an "option" then there really needs to be a CMake variable such as "PARAVIEW_OSX_BUNDLE_INSTALL" to make it clear just where the app bundle is going to be installed.
(0018698)
2009-12-05 16:01
Here is my version of CreateBundle.sh.in that will create a blank qt.conf and copy the qt_menu.nib file into the proper location inside the application bundle and the qtassistant bundle.
#!/bin/sh
if [ "x$InstallPrefix" = "x" ]; then
  InstallPrefix="$DESTDIR/Applications"
  echo "info: Using default InstallPrefix value:"
  echo " $InstallPrefix"
fi
ParaViewBinaryDir="@ParaView_BINARY_DIR@"
ParaViewExeName="@PV_EXE_NAME@"
ParaView_App="@EXECUTABLE_OUTPUT_PATH@/$ParaViewExeName.app"
# Remove the previous app package so we start with a clean bundle
echo "Remove previous bundle"
rm -rf "$InstallPrefix/ParaView @PARAVIEW_VERSION_MAJOR@.@PARAVIEW_VERSION_MINOR@.@PARAVIEW_VERSION_PATCH@.app"
# Copy paraview.app from the build tree to the install tree:
echo "Copy paraview.app from the build tree to $InstallPrefix/"
mkdir -p "$InstallPrefix"
cp -Rp "$ParaView_App" "$InstallPrefix/"
mv "$InstallPrefix/paraview.app" "$InstallPrefix/ParaView @PARAVIEW_VERSION_MAJOR@.@PARAVIEW_VERSION_MINOR@.@PARAVIEW_VERSION_PATCH@.app"
# Now operate on the bundle in the install tree:
ParaView_App="$InstallPrefix/ParaView @PARAVIEW_VERSION_MAJOR@.@PARAVIEW_VERSION_MINOR@.@PARAVIEW_VERSION_PATCH@.app"
FrameworksDir="$ParaView_App/Contents/Frameworks"
LibrariesDir="$ParaView_App/Contents/Libraries"
PluginsDir="$ParaView_App/Contents/Plugins"
PythonDir="$ParaView_App/Contents/Python"
SupportDir="$ParaView_App/Contents/Support"
ResourcesDir="$ParaView_App/Contents/Resources"
# Create directories in the install tree bundle
mkdir -p "$FrameworksDir"
mkdir -p "$LibrariesDir"
mkdir -p "$PluginsDir"
mkdir -p "$PythonDir"
mkdir -p "$SupportDir"
mkdir -p "$ResourcesDir"
# Copy the documentation into the Support directory
echo "Copy documentation"
cp -Rp "${ParaViewBinaryDir}/Documentation" "$SupportDir/"
cp -p "${ParaViewBinaryDir}/pqClient.adp" "$SupportDir/."
# Copy the python scripts into the Python directory
echo "Copy python scripts"
cp -Rp "${ParaViewBinaryDir}/Utilities/VTKPythonWrapping/paraview" "$PythonDir/"
# Copy the Qt Assistant application into the Support directory
echo "Embed copy of the QtAssistant in bundle"
cp -RpL "@QT_ASSISTANT_DOTAPP_BUNDLE@" "$SupportDir/"
# Create an empty qt.conf file in the Assistant_adp app package
# to stop plugin loading by Assistant.
touch "$SupportDir/@QT_ASSISTANT_DOTAPP_BUNDLE_NAME@/Contents/Resources/qt.conf"
# to stop ParaView from loading Qt plugins like qttiff and things like that.
touch "$ResourcesDir/qt.conf"
# Create symlinks so that the Assistant.app bundle can use the same
# copy of Qt Frameworks/Libraries as the paraview executable, yet still
# refer to them via a string like "@executable_path/../Frameworks"...
pushd "$SupportDir/@QT_ASSISTANT_DOTAPP_BUNDLE_NAME@/Contents"
ln -s "../../../Libraries" "Libraries"
ln -s "../../../Frameworks" "Frameworks"
popd
# Remove unneeded build-byproduct files that were copied by the
# above recursive directory copies:
rm -rf "$PythonDir/paraview/pv_compile_complete"
rm -rf "$SupportDir/Documentation/CMakeFiles"
rm -rf "$SupportDir/Documentation/cmake_install.cmake"
rm -rf "$SupportDir/Documentation/CTestTestfile.cmake"
rm -rf "$SupportDir/Documentation/Makefile"
# If we built with the Cocoa version of Qt then copy the qt_menu.nib bundle from
# the framework directory into the actual Applications directory and the
# QtAssistant Application Bundle
if [ "@VTK_USE_COCOA@" = "ON" ]; then
  cp -R "@QT_LIBRARY_DIR@/QtGui.framework/Resources/qt_menu.nib" "$ResourcesDir/"
  cp -R "@QT_LIBRARY_DIR@/QtGui.framework/Resources/qt_menu.nib" "$SupportDir/@QT_ASSISTANT_DOTAPP_BUNDLE_NAME@/Contents/Resources/"
fi
(0018720)
olesen (reporter)
2009-12-08 08:40
See related issue - http://www.paraview.org/Bug/view.php?id=8712 [^]
This prevents paraview from finding paraview-real
(0019471)
Michael Wild (reporter)
2010-02-08 11:04
The issues with libQtCLucene.dylib and libqsqlite.dylib not being copied into the application-bundle on Mac OS X can be fixed by this patch:
http://github.com/themiwi/ParaView/commit/f07cdfd91f513962d1a242eb799373016044ef12 [^]
(0019474)
2010-02-08 11:34
The issue of the missing qt_menu.nib when using Qt-Cocoa is solved by this patch:
http://github.com/themiwi/ParaView/commit/f2c5d7e0b065a232a54ebb39f516122cc854b6a2 [^]
(0019925)
David Partyka (developer)
2010-03-17 09:30
Okay, both of Michael Wild's patches have been patched in but this bug has become very multi faceted. What parts of this bug are still not fixed? Just the Application bundle install dir?
Mike Jackson, if you export DESTDIR=<some_dir> and then make install you should get the desired behavior. Though this is more of just a testing feature that Dave Cole put in.
(0019936)
2010-03-17 10:39
I tried what you suggested on a "git pull origin master" on 3/17/2010 at 10:15 AM EDT and when I run the make install I get the following:
CMAKE_INSTALL_PREFIX=/Users/Shared/Toolkits/ParaView
export DESTDIR=$CMAKE_INSTALL_PREFIX
make install
I then get an "Applications/ParaView-3.7.0.app" created in the /Users/Shared/Toolkits/ParaView directory
I also get another folder hierarchy created:
/Users/Shared/Toolkits/ParaView/Users/Shared/Toolkits/ParaView/bin with another paraview.app inside that. So basically the "make install" does NOT work at all on OS X. It is totally messed up. And my custom client plugins were NOT copied into the proper folder structure in any of those folders above.
(0020201)
2010-04-16 01:30
Reminder sent to: David Partyka
Dave,
What's the status of this bug? As far as "make install" goes, create a new bug for fix "make install" on all platforms (including Mac). Once CMake adds support for it, we can look it at.
(0020213)
2010-04-16 06:23
edited on: 2010-04-16 06:36
All the fixes have been applied for installing missing libs. Created a child issue for the make install related issues.
(0021256)
2010-07-06 16:34
Hi Mike, I think I have fixed the remainder of the issues related to make install on Mac. If you do make install you should get a bin, lib directories and a paraview app in your CMAKE_INSTALL_PREFIX. Can you test this out. The changes are on ParaView master. Also note I opened a child bug 0010558 specifically for this issue.
(0023295)
2010-11-16 12:24
I believe all of these issues are resolved. If anyone disagrees please reopen.
(0023308)
Alan Scott (manager)
2010-11-16 17:45
Trusting Dave, the buildmeister.
 Issue History
2009-12-05 11:46 Utkarsh Ayachit New Issue
2009-12-05 11:48 Utkarsh Ayachit Relationship added parent of 0009868
2009-12-05 11:48 Utkarsh Ayachit Relationship added parent of 0009867
2009-12-05 11:49 Utkarsh Ayachit Relationship added parent of 0009977
2009-12-05 15:32 Mike Jackson Note Added: 0018696
2009-12-05 15:54 Mike Jackson Note Added: 0018697
2009-12-05 16:01 Mike Jackson Note Added: 0018698
2009-12-08 08:40 olesen Note Added: 0018720
2009-12-08 09:29 Utkarsh Ayachit Relationship added parent of 0008712
2009-12-11 10:44 Utkarsh Ayachit Status backlog => tabled
2009-12-11 10:44 Utkarsh Ayachit Assigned To => David Partyka
2010-02-08 11:04 Michael Wild Note Added: 0019471
2010-02-08 11:34 Michael Wild Note Added: 0019474
2010-03-17 09:30 David Partyka Note Added: 0019925
2010-03-17 10:39 Mike Jackson Note Added: 0019936
2010-04-16 01:30 Utkarsh Ayachit Note Added: 0020201
2010-04-16 06:23 David Partyka Note Added: 0020213
2010-04-16 06:35 David Partyka Relationship added parent of 0010558
2010-04-16 06:36 David Partyka Note Edited: 0020213
2010-07-06 16:34 David Partyka Note Added: 0021256
2010-11-16 12:24 David Partyka Note Added: 0023295
2010-11-16 12:24 David Partyka Status tabled => @80@
2010-11-16 12:24 David Partyka Fixed in Version => 3.8
2010-11-16 12:24 David Partyka Resolution open => fixed
2010-11-16 17:45 Alan Scott Note Added: 0023308
2010-11-16 17:45 Alan Scott Status @80@ => closed
