0010956 | ParaView | Feature | public | 2010-07-08 12:08 | 2014-02-05 12:22 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0010956: Find/Edit data command - ability to click on a cell or point, highlighted on | ||||||||
Description | The Edit/ Find data command is a fabulous tool. However, it really needs a few more features. * Ability for the user to select (using the mouse or p key) on a cell or point, and have the data display. I.e., merging of the spreadsheet view (where you select data with a mouse) and the find data query results (where you select data with a keyboard). Note that this requires the edit/find data dialog box to stay open when interacting witht he 3d window, but that is another bug. | ||||||||
Project | Sandia | ||||||||
Topic Name | seln-inspector-spreadsheet | ||||||||
Relationships | |||||||||||
(0029241) Alan Scott (manager) 2012-09-20 17:16 |
Bringing to backlog |
(0029497) Ken Moreland (manager) 2012-10-23 22:42 |
In addition, I would add that the spreadsheet in the find data dialog should _always_ show the current selection regardless of how it was selected. Thus, you should be able to pick in the 3d view and then open the Find Dialog and see the data in the spreadsheet (as well as see it if the pick happens while the dialog is already open). |
(0029657) Alan Scott (manager) 2012-11-07 21:22 |
Ken and I would really like to see the Find Data cleaned up. Thus, this needs to be done. |
(0029658) Alan Scott (manager) 2012-11-07 21:23 |
Changing to high priority. This really needs to be done. |
(0029905) David Thompson (developer) 2012-12-18 14:09 |
The seln-inspector-spreadsheet branch (sorry, branch merged to next before I saw this bug), moves the spreadsheet view from the Find Data dialog to the selection inspector, where it displays the current selection. |
(0029906) Ken Moreland (manager) 2012-12-18 14:14 |
Wait? Did you just say that the spreadsheet in the find data dialog was moved to the selection inspector? NO! NO! GOD, NO! Say it's not so. Die selection inspector! Die! |
(0032135) Utkarsh Ayachit (administrator) 2014-01-07 13:06 |
This is indeed supported. FindData dialog stays open and you can track active selections in the dialog. |
(0032155) Utkarsh Ayachit (administrator) 2014-01-08 10:45 |
SUMMARY --------------------------------------------- Topics merged into master: 14478-system-query 14480-choose-preset-Remove 14497-fix-compiler-warnings catalyst-link-issue catalyst-web pvweb-fix-pipeline-lut-inconsistency silence-find-cuda simpler-catalyst-editions windows_getenv |
(0032282) Alan Scott (manager) 2014-02-05 12:22 |
Tested master, Linux, remote server. |
2010-07-08 12:08 | Alan Scott | New Issue | |
2010-07-08 12:34 | Alan Scott | Relationship added | child of 0010627 |
2010-09-01 11:26 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2012-05-22 19:28 | Alan Scott | Relationship added | related to 0013150 |
2012-09-20 17:16 | Alan Scott | Assigned To | => Alan Scott |
2012-09-20 17:16 | Alan Scott | Note Added: 0029241 | |
2012-09-20 17:16 | Alan Scott | Status | expired => backlog |
2012-09-20 17:16 | Alan Scott | Resolution | open => reopened |
2012-10-23 21:01 | Alan Scott | Assigned To | Alan Scott => |
2012-10-23 21:04 | Alan Scott | Project | => Sandia |
2012-10-23 21:04 | Alan Scott | Type | => incorrect functionality |
2012-10-23 22:42 | Ken Moreland | Note Added: 0029497 | |
2012-11-07 21:22 | Alan Scott | Note Added: 0029657 | |
2012-11-07 21:22 | Alan Scott | Status | backlog => todo |
2012-11-07 21:23 | Alan Scott | Note Added: 0029658 | |
2012-11-07 21:23 | Alan Scott | Priority | normal => high |
2012-12-11 09:45 | Sebastien Jourdain | Assigned To | => David Thompson |
2012-12-18 14:09 | David Thompson | Topic Name | => seln-inspector-spreadsheet |
2012-12-18 14:09 | David Thompson | Note Added: 0029905 | |
2012-12-18 14:09 | David Thompson | Status | todo => gatekeeper review |
2012-12-18 14:09 | David Thompson | Fixed in Version | => git-next |
2012-12-18 14:09 | David Thompson | Resolution | reopened => fixed |
2012-12-18 14:14 | Ken Moreland | Note Added: 0029906 | |
2012-12-21 11:16 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
2012-12-21 11:16 | Utkarsh Ayachit | Resolution | fixed => reopened |
2013-10-21 08:16 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-10-21 08:17 | Utkarsh Ayachit | Fixed in Version | git-master => |
2014-01-07 13:06 | Utkarsh Ayachit | Note Added: 0032135 | |
2014-01-07 13:06 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-01-07 13:06 | Utkarsh Ayachit | Fixed in Version | => 4.1 |
2014-01-07 13:06 | Utkarsh Ayachit | Resolution | reopened => fixed |
2014-01-07 13:06 | Utkarsh Ayachit | Assigned To | David Thompson => Utkarsh Ayachit |
2014-01-08 10:44 | Utkarsh Ayachit | Fixed in Version | 4.1 => git-master |
2014-01-08 10:45 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-01-08 10:45 | Utkarsh Ayachit | Note Added: 0032155 | |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2014-02-05 12:22 | Alan Scott | Note Added: 0032282 | |
2014-02-05 12:22 | Alan Scott | Status | customer review => closed |
