0013160 | VTK | (No Category) | public | 2012-05-10 10:48 | 2013-04-05 20:34 | ||||
Reporter | JensH | ||||||||
Status | closed | Resolution | duplicate | ||||||
Product Version | 5.8.0 | ||||||||
Summary | 0013160: vtkSTLReader does not read files any more | ||||||||
Description | I have a piece of code, that uses the vtkSTLReader to perform some manipulations on a STL file via python and on the older VTK versions it works great. But after the update via git (d1db5b1), vtk raises the following error on reading an STL. <snip> vtkSTLReader (0x7ffc819363c0): STLReader error reading file: /Users/jens/test.stl Premature EOF while reading end solid. </snip> The stl can be displayed in paraview and was not altered at all, during the last year. My guess is, that this was introduced in release bbc7a0ef. If you need further information, please let me know. Jens | ||||||||
Project | Release | ||||||||
Attached Files | ![]() ![]() | ||||||||
Relationships | |||||||
(0028584) Utkarsh Ayachit (administrator) 2012-05-10 10:54 |
Can you post a sample dataset please? |
(0028585) Bill Lorensen (developer) 2012-05-10 12:04 |
Jens, We added more error checking to the STL reader. Is this a file that you created? |
(0028588) JensH (reporter) 2012-05-11 03:41 edited on: 2012-05-11 04:18 |
First of all, thanks for your almost instant reply! @Utkarsh: I've uploaded the geometry as a tar.gz, otherwise it would be to large @Bill: This is an STL I received from a workshop's site and it is in the ASCII format, not binary. I've used exactly that (and some other) stl file to run the code and it worked like a charm. |
(0028590) JensH (reporter) 2012-05-11 05:06 |
I've created a box in paraview exported it as a STL after triangulating it. Using the ReadASCIISTL method results in the same error message. This stl is attatched as well to this report. |
(0028591) JensH (reporter) 2012-05-11 07:17 |
Ok, I've changed the branch from release to master and now seems to be working. |
(0028619) Utkarsh Ayachit (administrator) 2012-05-17 12:59 |
This has been fixed. commit 1d6745888bcc34b260410a3cdbba49ecf0084ba2 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Apr 17 14:54:05 2012 -0400 BUG 0013101. STL ascii reader was report failures prematurely. STL ascii reader was reporting error when eof was reached at an expected location. This was causing the reader to fail for the STL file attached with the bug report. Change-Id: I734d2c8d8c85854df3d2a63bae6ba23bccf7a9c2 |
2012-05-10 10:48 | JensH | New Issue | |
2012-05-10 10:54 | Utkarsh Ayachit | Note Added: 0028584 | |
2012-05-10 12:04 | Bill Lorensen | Note Added: 0028585 | |
2012-05-11 03:33 | JensH | File Added: stl.tgz | |
2012-05-11 03:41 | JensH | Note Added: 0028588 | |
2012-05-11 03:48 | JensH | Note Added: 0028589 | |
2012-05-11 04:18 | JensH | Note Deleted: 0028589 | |
2012-05-11 04:18 | JensH | Note Edited: 0028588 | |
2012-05-11 05:06 | JensH | Note Added: 0028590 | |
2012-05-11 05:07 | JensH | File Added: box.stl | |
2012-05-11 07:17 | JensH | Note Added: 0028591 | |
2012-05-17 12:56 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-05-17 12:56 | Utkarsh Ayachit | Status | backlog => tabled |
2012-05-17 12:56 | Utkarsh Ayachit | Resolution | open => fixed |
2012-05-17 12:59 | Utkarsh Ayachit | Note Added: 0028619 | |
2012-05-17 12:59 | Utkarsh Ayachit | Status | tabled => customer review |
2012-05-17 12:59 | Utkarsh Ayachit | Resolution | fixed => duplicate |
2012-05-30 11:09 | Utkarsh Ayachit | Relationship added | related to 0013101 |
2013-04-05 20:34 | Berk Geveci | Status | customer review => closed |
