0013294 | VTK | (No Category) | public | 2012-07-04 11:39 | 2016-08-12 09:55 | ||||
Reporter | klaus triendl | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 5.8.0 | ||||||||
Summary | 0013294: string arrays may cause vtkXMLUnstructuredGridWriter to produce corrupt vtu-files, which are unreadable or cause crash | ||||||||
Description | When a string array is appended to the cell data of an unstructured grid, vtkXMLUnstructuredGridWriter may produce a corrupt vtu-file, depending on how long the strings are. I cannot tell at what length the issue shows up, but the longer the strings the sooner it happens. Even very simple models with just 304 cells can be affected. It doesn't matter whether the cell data is compressed or not and whether the data is binary or appended. Only ascii works. Please see attached zip file, which contains: * a test cpp file displaying how I produce the vtu-files * a test msvc2010 project * the source and resulting vtu files Notes worth to be mentioned: * When loading the compressed vtu-files the following error is reported: <error> - ERROR: In ..\..\..\..\src\VTK\IO\vtkZLibDataCompressor.cxx, line 83 vtkZLibDataCompressor (00000000139D63E0): Decompression produced incorrect size. Expected 27728 and got 27529 ERROR: In ..\..\..\..\src\VTK\IO\vtkXMLDataReader.cxx, line 545 vtkXMLUnstructuredGridReader (000000000B2F7ED0): Cannot read cell data array "strings" from PointData in piece 0. The data array in the element may be too short. </error> * when loading the uncompressed vtu-files then the reading application crashes in the template function vtkXMLDataReaderReadArrayValues<vtkArrayIteratorTemplate<vtkStdString>> I detected the issue already in version 5.8.0, it's still active in 5.10.0 and in 6.0 (git #02aef09). | ||||||||
Project | Release | ||||||||
Type | crash | ||||||||
Attached Files | ![]() ![]() ![]() | ||||||||
Relationships | ||||||||||||||||
(0031491) Emmanuel (reporter) 2013-08-22 04:34 |
Hi It seems to be the same problem I have with vtkXMLPolyDataWriter. For some string attached to cells, if I use the Zlib compression, it produces a corrupted file, which gives this error when reading with paraview: " ERROR: In /builddir/build/BUILD/ParaView-3.98.1-source/VTK/IO/Core/vtkZLibDataCompressor.cxx, line 85 vtkZLibDataCompressor (0x4459a90): Decompression produced incorrect size. Expected 2696 and got 2693 ERROR: In /builddir/build/BUILD/ParaView-3.98.1-source/VTK/IO/XML/vtkXMLDataReader.cxx, line 545 vtkXMLPolyDataReader (0x4457860): Cannot read cell data array "Names" from PointData in piece 0. The data array in the element may be too short. " Most of the time it works without problem. It depends on the string attached. In my case if I associate the string "5" it works fine, if I put a character or string (like "5s") it fails. Both works when not using Zlib compression. Files using and not using compression are attached. (Zlib.vtp and None.vtp) vtkSmartPointer<vtkXMLPolyDataWriter> writer = vtkSmartPointer<vtkXMLPolyDataWriter>::New(); writer->SetCompressorTypeToZLib();// using this generates Zlib.vtp writer->SetCompressorTypeToNone();// using this generates None.vtp thank you ;-) |
(0035013) T.J. Corona (developer) 2015-08-18 10:25 |
I cannot reproduce this problem in VTK6.3. |
(0035573) Cory Quammen (developer) 2015-12-16 09:23 |
I believe this is still a bug in VTK 7.0. I will follow up later. |
(0037286) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2012-07-04 11:39 | klaus triendl | New Issue | |
2012-07-04 11:39 | klaus triendl | File Added: vtk-xmlwriter-bug.zip | |
2013-06-25 14:22 | Dave DeMarle | Relationship added | child of 0013860 |
2013-06-25 14:22 | Dave DeMarle | Relationship deleted | child of 0013860 |
2013-06-25 14:22 | Dave DeMarle | Relationship added | related to 0013860 |
2013-06-25 14:23 | Dave DeMarle | Relationship added | related to 0013295 |
2013-06-25 14:24 | Dave DeMarle | Relationship added | related to 0013382 |
2013-08-22 04:34 | Emmanuel | Note Added: 0031491 | |
2013-08-22 04:35 | Emmanuel | File Added: None.vtp | |
2013-08-22 04:35 | Emmanuel | File Added: Zlib.vtp | |
2015-08-18 10:25 | T.J. Corona | Note Added: 0035013 | |
2015-08-18 10:25 | T.J. Corona | Status | backlog => closed |
2015-08-18 10:25 | T.J. Corona | Assigned To | => T.J. Corona |
2015-08-18 10:25 | T.J. Corona | Resolution | open => unable to reproduce |
2015-08-18 10:25 | T.J. Corona | Fixed in Version | => 6.3.0 |
2015-12-16 09:23 | Cory Quammen | Assigned To | T.J. Corona => Cory Quammen |
2015-12-16 09:23 | Cory Quammen | Note Added: 0035573 | |
2015-12-16 09:23 | Cory Quammen | Status | closed => backlog |
2015-12-16 09:23 | Cory Quammen | Resolution | unable to reproduce => reopened |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037286 | |
2016-08-12 09:55 | Kitware Robot | Status | backlog => closed |
2016-08-12 09:55 | Kitware Robot | Fixed in Version | 6.3.0 => |
2016-08-12 09:55 | Kitware Robot | Resolution | reopened => moved |
