0013794ParaView(No Category)public2013-01-16 16:482015-01-11 08:19
ReporterAlan Scott
Assigned ToDavid C. Lonie
StatusclosedResolutionfixed
PlatformOSOS Version
Product Versiongit-master
Target Version4.2Fixed in Version4.2
Summary0013794: Remote server, find max error
DescriptionWhen running remote server, find data/ max fails with a python error.
Linux, remote server, master.
Open can.exo. All vars on. Apply.
Edit/ Find Data. Change GlobalId to EQPS. Change "is" to "is max".
Run Selection Query.
It will hang for a while, then the following gets written out:
Traceback (most recent call last):
  File "<string>", line 5, in <module>
  File "/projects/viz/paraview/ParaView/3.98.1-Mesa/Linux-redsky-x86_64/lib/paraview-3.98/site-packages/paraview/extract_selection.py", line 147, in Exec
    ds = ExecData(self, iterCD.GetCurrentDataObject(), selection)
  File "/projects/viz/paraview/ParaView/3.98.1-Mesa/Linux-redsky-x86_64/lib/paraview-3.98/site-packages/paraview/extract_selection.py", line 122, in ExecData
    mask = eval(selection_node.GetQueryString(), globals(), new_locals)
  File "<string>", line 1, in <module>
  File "/projects/viz/paraview/ParaView/3.98.1-Mesa/Linux-redsky-x86_64/lib/paraview-3.98/site-packages/paraview/vtk/algorithms.py", line 304, in global_max
    MPI.COMM_WORLD.Allreduce(None, [M, MPI.DOUBLE], MPI.MAX)
  File "Comm.pyx", line 544, in mpi4py.MPI.Comm.Allreduce (/projects/viz/paraview/src/ParaView/3.98.1/ParaView3/Utilities/mpi4py/src/mpi4py.MPI.c:63736)
  File "message.pxi", line 585, in mpi4py.MPI._p_msg_cco.for_allreduce (/projects/viz/paraview/src/ParaView/3.98.1/ParaView3/Utilities/mpi4py/src/mpi4py.MPI.c:23520)
  File "message.pxi", line 523, in mpi4py.MPI._p_msg_cco.for_cro_send (/projects/viz/paraview/src/ParaView/3.98.1/ParaView3/Utilities/mpi4py/src/mpi4py.MPI.c:23007)
  File "message.pxi", line 106, in mpi4py.MPI.message_simple (/projects/viz/paraview/src/ParaView/3.98.1/ParaView3/Utilities/mpi4py/src/mpi4py.MPI.c:19218)
TypeError: message: expecting buffer or list/tuple
This is a bug.
TagsNo tags attached.
ProjectSandia
Topic Name13794_fix_mp4py
Typeincorrect functionality
 Relationships
related to 0010958closedUtkarsh Ayachit Edit/Find data command - find and calculate min and max variable for each time step of an animation
parent of 0014565closedDavid C. Lonie Python Calculator and Extract Selection broken for composite datasets
  Notes
(0030153)
2013-01-16 17:41
commit e1114c112528cfea3cdc0e62e4afc14382c38635
Date: Wed Jan 16 17:39:46 2013 -0500
    BUG 0013794: Fix mpi4py API change issue.
    Since we recently updated to mpi4py 1.3, looks like MPI.Reduceall(..) with empty
    send buffer no longer works. We need to create a send and receive buffer to use.
    Updated the algorithms.py file to reflect the API change.
    Change-Id: I9a58d698dd3df3678d97ae6f969807e65522d0d7
(0030154)
2013-01-16 17:51
DEVELOPER NOTE:
The next bug to fix to address this issue is that vtkPythonExtractSelection doesn't correctly handle composite datasets that may have non-aligned null blocks between processes e.g. when can.ex2 is opened in parallel.
(0030178)
2013-01-17 17:10
DEVELOPER NOTE:
We have the following issues with min/max.
1) Currently, the min/max/mean are computing per-block. That's not what users would expect.
To fix this, we need to update the algorithms.py file in ParaView to handle composite datasets better. The user does foo(array), we should pass array as a custom array which itself comprises of arrays from all the blocks in the composite dataset.
2) Min/Max/Mean across processes has issues when any process has no data.
The collective MPI calls deadlock. We'll need to address that by ensuring that all processes participate in the collective operations even if they don't have the requested arrays. That may require us to share information about arrays on all processes with everyone.
(0032182)
2014-01-16 13:58
DEVELOPER NOTE:
"max" is currently not available in the UI. To reproduce this issue you can use the following "Query" instead:
EQPS == global_max(EQPS)
(0032444)
David C. Lonie (developer)
2014-03-03 14:42
Applying Utkarsh's patch to change the mpi4py API fixes the issue.
(0032462)
2014-03-09 13:24
SUMMARY
Topics merged into master:
        13794_fix_mp4py
        14572-search-series-parameter-widget
        14620_FixRulerCrash
        disabled-multiblock-pieces
        fix_example_qt5
        optimize_amrconnectivity
        point-sprite-plugin-crash
        pvweb-visualizer
        remove-extra-resources
(VTK) update-vtk-20140303
(0032529)
Alan Scott (manager)
2014-03-21 16:26
The query above is hanging (not crashing) remote server. Be sure to check before closing this bug.
(0032531)
2014-03-21 20:09
"is max" no longer exists, since it was incorrect in parallel. Thus, I am closing this bug. The meat of this bug (give us the ability to find min and max) will be fixed in one of the related bugs off this one, currently under development. I will also test it then.
 Issue History
2013-01-16 16:48 Alan Scott New Issue
2013-01-16 17:41 Utkarsh Ayachit Note Added: 0030153
2013-01-16 17:51 Utkarsh Ayachit Note Added: 0030154
2013-01-17 17:10 Utkarsh Ayachit Note Added: 0030178
2013-01-24 22:34 Utkarsh Ayachit Target Version => 4.0
2013-02-11 18:32 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2013-02-13 12:51 Alan Scott Relationship added related to 0010958
2014-01-16 13:47 Utkarsh Ayachit Assigned To Utkarsh Ayachit => David C. Lonie
2014-01-16 13:58 Utkarsh Ayachit Note Added: 0032182
2014-01-16 16:59 Utkarsh Ayachit Target Version 4.0 => 4.2
2014-02-11 12:26 David C. Lonie Relationship added parent of 0014565
2014-03-03 14:42 David C. Lonie Topic Name => 13794_fix_mp4py
2014-03-03 14:42 David C. Lonie Note Added: 0032444
2014-03-03 14:42 David C. Lonie Status backlog => gatekeeper review
2014-03-03 14:42 David C. Lonie Resolution open => fixed
2014-03-09 13:24 Utkarsh Ayachit Fixed in Version => git-master
2014-03-09 13:24 Utkarsh Ayachit Status gatekeeper review => customer review
2014-03-09 13:24 Utkarsh Ayachit Note Added: 0032462
2014-03-21 16:26 Alan Scott Note Added: 0032529
2014-03-21 16:28 Utkarsh Ayachit Status customer review => todo
2014-03-21 20:09 Alan Scott Note Added: 0032531
2014-03-21 20:09 Alan Scott Status todo => closed
2014-08-29 11:00 Utkarsh Ayachit Fixed in Version git-master => 4.2
2015-01-11 08:19 Utkarsh Ayachit Source_changeset_attached => ParaView master 392223ec
2015-01-11 08:19 David C. Lonie Source_changeset_attached => ParaView master 10d058a4
