0013834 | ParaView | (No Category) | public | 2013-01-29 19:43 | 2016-08-12 09:59 | ||||
Summary | 0013834: ProgressHandler needs fixing, error checking, consistency and COMMENTS. | ||||||||
Description | The progress handler needs to have it's throttle fixe. File vtkPVProgressHandler.cxx, member function vtkPVProgressHandler::ReportProgress(). Progress should NEVER be outside of the range of 0 to 1, so don't send MPI calls for out of range progress. Also, make sure to throttle progress for 0.0, since many functions in the code incorrectly send this billions of times. I changed if (progress <= 0.0 || progress >= 1.0 || this->Internals->ProgressTimer->GetElapsedTime() > this->ProgressFrequency) to if (progress >= 0.0 && progress <= 1.0 && this->Internals->ProgressTimer->GetElapsedTime() > this->ProgressFrequency) The Progress Report code needs a way to find error cases with progress. I suggest adding the following at the top of the vtkPVProgressHandler::ReportProgress() function, which I assume only is printed for debug builds: if (progress < 0.0 || progress > 1.0 ) vtkWarningMacro(<< "vtkPVProgressHandler::ReportProgress - "<< " progress out of range [0.0-1.0] " << progress); The Progress Handler code needs to have progress be consistent throughout. In most functions, progress goes from 0.0 to 1.0. In the call to SetLocalProgress(), progress becomes a range of 0 to 100, and inside this code makes a call that requires it to be divided by 100! Keep 0.0 to 1.0 throughout. Be sure to change LastProgress = progress*100.0 (assuming it even gets used, which I couldn't find). Last, please document the range for progress and change the variable for progress if it has a different range. It was confusing what it should be. (progress100?) | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0030274) Alan Scott (manager) 2013-01-29 21:23 edited on: 2013-01-29 21:24 |
In vtkPVProgressHandler.cxx, where this->ProgressFrequency is set, please set it to something like 1 second. 2 is a bit long, and is probably just trying to mask errors. |
(0030275) Alan Scott (manager) 2013-01-29 21:29 |
Please add a print statement to the code, which is normally commented out, which will tell a developer if the ProgressHandler is working. For instance, in SendProgressToClient, below all of the if() tests, do a StopTime() then print out GetElapsedTime and progress. Then, test with multiple servers, multiple files. Make sure that progress increments as it should, and doesn't put too many lines out. If a developer doesn't want to page through the output, there are too many lines written out (and ReportProgess is sending MPI calls between processes). |
(0030283) Alan Scott (manager) 2013-01-30 16:58 |
As an idea, how about have this print statement start printing status if some environment variable, or CMake flag is on? That way we could easily test when wanted, but otherwise we wouldn't get flooded with output. |
(0030629) Alan Scott (manager) 2013-04-29 15:24 |
I believe this one has been fixed. It was fixed by removing the MPI code, and only using process 0 for the updates. This removed a hang and slowdown due to flooding the network with update data. |
(0038325) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-01-29 19:43 | Alan Scott | New Issue | |
2013-01-29 21:23 | Alan Scott | Note Added: 0030274 | |
2013-01-29 21:24 | Alan Scott | Note Edited: 0030274 | |
2013-01-29 21:29 | Alan Scott | Note Added: 0030275 | |
2013-01-29 21:50 | Alan Scott | Relationship added | child of 0013831 |
2013-01-30 16:58 | Alan Scott | Note Added: 0030283 | |
2013-04-29 15:24 | Alan Scott | Note Added: 0030629 | |
2013-05-01 13:55 | Nikhil Shetty | Assigned To | => Nikhil Shetty |
2013-06-05 15:59 | Nikhil Shetty | Assigned To | Nikhil Shetty => |
2013-06-05 16:00 | Nikhil Shetty | Assigned To | => Nikhil Shetty |
2013-06-05 16:37 | Nikhil Shetty | Assigned To | Nikhil Shetty => |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038325 | |
