0015535VTK(No Category)public2015-06-11 13:212016-07-06 11:21
Reporterdkuegler
Assigned To
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version6.0.0
Summary0015535: Visual Studio 2015 Compilation Errors
DescriptionSimilar to 0015534
I encountered the error
Severity Code Description Project File Line
Error C2375 'lfind': redefinition; different linkage vtktiff C:\Program Files (x86)\Windows Kits\10\Include\10.0.10056.0\ucrt\corecrt_search.h 191
From tiffiop.h of Project vtktiff (ThirdParty/tiff/vtktiff/)
#ifdef HAVE_SEARCH_H
# include <search.h>
#else
extern void *lfind(const void *, const void *, size_t *, size_t,
                   int (*)(const void *, const void *));
#endif
Solution according to the header of corecrt_search.h:
Define HAVE_SEARCH_H
Why is this an issue?
Because search.h included through stdlib.h before.
This would be the only reference to HAVE_SEARCH_H, that I could find.
TagsNo tags attached.
ProjectTBD
Typeincorrect functionality
 Relationships
related to 0015534closedSean McBride Visual Studio 2015 Compilation Errors
  Notes
(0034537)
dkuegler (reporter)
2015-06-11 13:48
Another similar issue is found according to
Error C1189 #error: Macro definition of snprintf conflicts with Standard Library function declaration vtklibxml2 C:\Program Files (x86)\Windows Kits\10\Include\10.0.10056.0\ucrt\stdio.h 1927
VS claims the definitio in stdio.h collides with the definition in condig.h
From config.h
/* Win32 Std C name mangling work-around */
#if defined(_MSC_VER)
# define snprintf _snprintf
#endif
I do not quite understand this, but I expect it has changed somewhere similar to
#if defined(_MSC_VER) && (_MSC_VER < 1500)
# define vsnprintf _vsnprintf
#endif
and thus it should really be (_MSC_VER is 1900 for me)
#if defined(_MSC_VER) && (_MSC_VER < 1900)
#endif
That would be in (ThirdParty/libxml2/vtklibxml2/config_cmake.h.in)
(0034690)
dkuegler (reporter)
2015-07-08 05:48
See https://gitlab.kitware.com/vtk/vtk/merge_requests/311 [^]
(0036177)
Sean McBride (developer)
2016-07-06 11:21
Looks like this was fixed and merged. Setting to closed.
 Issue History
2015-06-11 13:21 dkuegler New Issue
2015-06-11 13:48 dkuegler Note Added: 0034537
2015-07-08 05:48 dkuegler Note Added: 0034690
2015-08-28 08:28 T.J. Corona Relationship added related to 0015534
2016-07-06 11:21 Sean McBride Note Added: 0036177
2016-07-06 11:21 Sean McBride Status backlog => closed
2016-07-06 11:21 Sean McBride Resolution open => fixed
