0002703ParaView(No Category)public2006-01-09 18:292010-01-19 12:35
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PrioritylowSeverityfeatureReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Summary0002703: SNL: enhancement: Hidden line removal for backface surfaces
DescriptionA request has been made for another mode under the display tab, Display Style, Representation:. It would be nice to have "Wireframe, remove hidden lines" or somesuch. Basically, glPolymode lines, backface cull.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
related to 0009881closedKitware Robot Feature - cleaner backface cull with wireframe
  Notes
(0004360)
Berk Geveci (administrator)
2006-06-26 16:27
If this can be done quickly, do it. Otherwise defer.
(0005267)
2006-10-05 15:03
OpenGL guys will be very busy with volume rendering and depth peeling before the release. I am deferring this until later.
(0005429)
Alan Scott (manager)
2006-10-16 14:51
This is an important feature requestbut is probably not critical It is one of the major differences between ParaView and EnSight (i.e., ParaView weaknesses). Lack of this feature causes a major performance hit, and can make wire frame meshes a mess.
(0018774)
2009-12-09 21:31
VisIt does this too. We should figure out whether it can be done without using fancy GLSL stuff. Otherwise, let's use the code from VTKEdge.
(0018786)
2009-12-09 22:21
Code from VTKEdge is already available as a Example plugin. The only reason why it's not standard plugin is because it doesn't work in parallel. That needs some work.
(0018801)
Ken Moreland (manager)
2009-12-10 12:44
This is not exactly the same thing, but there is an option to cull back (or front) faces. Thus, you could turn on wireframe and cull back faces. IF your data is manifold you get a result that is close to what you describe. You should check to see if this satisfies the point of this request.
(0019194)
2010-01-19 12:34
Closing since the current Backface Style controls are good enough.
 Issue History
2009-12-09 14:51 Berk Geveci Project @3@ => ParaView
2009-12-09 21:30 Berk Geveci Assigned To Berk Geveci => Utkarsh Ayachit
2009-12-09 21:31 Berk Geveci Note Added: 0018774
2009-12-09 22:21 Utkarsh Ayachit Note Added: 0018786
2009-12-10 12:44 Ken Moreland Note Added: 0018801
2010-01-18 22:36 Alan Scott Relationship added duplicate of 0009881
2010-01-19 12:34 Alan Scott Note Added: 0019194
2010-01-19 12:34 Alan Scott Status tabled => closed
2010-01-19 12:35 Alan Scott Resolution open => fixed
2010-01-19 12:35 Alan Scott Relationship deleted 0009881
2010-01-19 12:35 Alan Scott Relationship added related to 0009881
2011-06-16 13:09 Zack Galbreath Category => (No Category)
