| 0004297 | ParaView | (No Category) | public | 2007-01-10 15:59 | 2009-05-13 13:59 | ||||
| Reporter | Clinton Stimpson | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0004297: solid color should be inherited | ||||||||
| Description | read in a data set with data to color by change representation to outline change solid color to blue or something add a clip filter hit apply change representation to outline the outline is white when it should be blue or whatever. If you the above steps with a sphere source, or in PV 2, the color is inherited. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0011119) Berk Geveci (administrator) 2008-04-07 16:31 |
This is also true for other display properties. |
(0013170) Utkarsh Ayachit (administrator) 2008-08-25 09:15 |
Added new hint <InheritRepresentationProperties /> which when present in a representation proxy XML, results in the listed properties being inherited from a representation for the input in the same view if any. /cvsroot/ParaView3/ParaView3/Qt/Core/pqDataRepresentation.cxx,v <-- Qt/Core/pqDataRepresentation.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDataRepresentation.h,v <-- Qt/Core/pqDataRepresentation.h new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Core/pqObjectBuilder.cxx,v <-- Qt/Core/pqObjectBuilder.cxx new revision: 1.31; previous revision: 1.30 /cvsroot/ParaView3/ParaView3/Qt/Core/pqObjectBuilder.h,v <-- Qt/Core/pqObjectBuilder.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx new revision: 1.33; previous revision: 1.32 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.309; previous revision: 1.308 |
(0013262) Alan Scott (manager) 2008-09-02 21:18 |
Tested client/server. |
| Notes |
| Issue History | |||
| 2007-08-14 12:35 | Ken Moreland | Relationship added | has duplicate 0005494 |
| 2008-04-07 16:31 | Berk Geveci | Note Added: 0011119 | |
| 2008-04-07 16:32 | Berk Geveci | Assigned To | Berk Geveci => Clinton Stimpson |
| 2008-04-07 16:32 | Berk Geveci | Priority | low => normal |
| 2008-04-07 16:32 | Berk Geveci | Category | => 3.4 |
| 2008-08-07 13:20 | Utkarsh Ayachit | Assigned To | Clinton Stimpson => Utkarsh Ayachit |
| 2008-08-25 09:15 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-08-25 09:15 | Utkarsh Ayachit | Resolution | open => fixed |
| 2008-08-25 09:15 | Utkarsh Ayachit | Note Added: 0013170 | |
| 2008-09-02 21:18 | Alan Scott | Status | @80@ => closed |
| 2008-09-02 21:18 | Alan Scott | Note Added: 0013262 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
