| 0006773 | ParaView | (No Category) | public | 2008-04-08 13:00 | 2011-01-13 17:00 | ||||
| Reporter | Ken Moreland | ||||||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0006773: Use Broadcast to propagate commands from root sever node to other server nodes | ||||||||
| Description | As we all know, the PV client connects to node 0 of servers and sends commands to that node. That node propagates commands to the other server nodes (as appropriate). This is implemented using the ProcessRMIs method in vtkMultiProcessController. This means that each node waits in a MPI_Recv from any command. Node 0 then iteratively sends a message to each of the other nodes. This is not a very efficient way to broadcast messages. Instead, everyone should use the Broadcast method to propagate the requests. (Broadcast is now part of vtkMultiProcessController.) | ||||||||
| Additional Information | When working correctly, the current method isn't a huge deal. However, there is a bug in the buffer management code of OpenMPI that is causing node 0 to eat up a bunch of memory. This is a killer for one of our important uses and the main driver for this bug. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0012672) Utkarsh Ayachit (administrator) 2008-07-09 10:34 |
Add global "use-ssend-for-trigger-RMI" and then set it in paraview since there are complications with broadcast. We should investigate using broadcast after 3.4. |
(0012723) Utkarsh Ayachit (administrator) 2008-07-16 12:56 |
ParaView now uses Ssend for all TriggerRMI requests. /cvsroot/ParaView3/ParaView3/Servers/Common/vtkProcessModule.cxx,v <-- Servers /Common/vtkProcessModule.cxx new revision: 1.85; previous revision: 1.84 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkMPICommunicator.cxx,v <-- VTK/Par allel/vtkMPICommunicator.cxx new revision: 1.48; previous revision: 1.47 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkMPICommunicator.h,v <-- VTK/Paral lel/vtkMPICommunicator.h new revision: 1.37; previous revision: 1.36 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkMPIController.cxx,v <-- VTK/Paral lel/vtkMPIController.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkMPIController.h,v <-- VTK/Paralle l/vtkMPIController.h new revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkMultiProcessController.cxx,v <-- VTK/Parallel/vtkMultiProcessController.cxx new revision: 1.30; previous revision: 1.29 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkMultiProcessController.h,v <-- VT K/Parallel/vtkMultiProcessController.h new revision: 1.37; previous revision: 1.36 |
(0012832) Alan Scott (manager) 2008-07-25 13:40 |
Accepting utkarsh's word for it... |
| Notes |
| Issue History | |||
| 2008-04-08 13:00 | Ken Moreland | New Issue | |
| 2008-04-08 13:01 | Ken Moreland | Relationship added | has duplicate 0006035 |
| 2008-04-10 18:21 | Ken Moreland | Status | backlog => tabled |
| 2008-04-10 18:21 | Ken Moreland | Assigned To | => Berk Geveci |
| 2008-07-09 10:23 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
| 2008-07-09 10:34 | Utkarsh Ayachit | Note Added: 0012672 | |
| 2008-07-16 12:56 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-07-16 12:56 | Utkarsh Ayachit | Resolution | open => fixed |
| 2008-07-16 12:56 | Utkarsh Ayachit | Note Added: 0012723 | |
| 2008-07-25 13:40 | Alan Scott | Status | @80@ => closed |
| 2008-07-25 13:40 | Alan Scott | Note Added: 0012832 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
