0006785 | ParaView | (No Category) | public | 2008-04-10 04:10 | 2009-05-13 13:59 | ||||
Reporter | Jean M. Favre | ||||||||
Summary | 0006785: Comparative views cameras are not linked if parallel projection is ON | ||||||||
Description | when using comparative views, the cameras are not in synch. tried with ParaView3 cvs version of April 10, 2008 | ||||||||
Relationships | ||||||
(0012059) Alan Scott (manager) 2008-05-21 22:37 |
Strange. The cameras are now correct from a rotation standpoint, but not from a scale standpoint. * Open disk_out_ref.exo. * Split window horizontally. * Make the right object parallel projection. * Split the left AND right window vertically. * Make disk_out_ref visible in all, using the eyeball. * link all the windows. * Use the right mouse button. The parallel objects move closer/further apart together, the orthogonal ones also move together. The parallel and orthogonal do not. Tested client/server. |
(0012067) Utkarsh Ayachit (administrator) 2008-05-22 07:40 |
Linking parallel and perspective views is not supported. All linked view must have same projection type. If I am not mistaken, the bug was referring to the linking within the views that comprise the comparative view itself, in other words no explicit linking needed to be done by the user. |
(0012073) Alan Scott (manager) 2008-05-22 20:23 |
Thanks. Closed. Tested client/server. |
2008-04-10 04:10 | Jean M. Favre | New Issue | |
2008-04-10 11:23 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-10 11:23 | Berk Geveci | Status | backlog => tabled |
2008-05-16 16:57 | Utkarsh Ayachit | Relationship added | related to 0006452 |
2008-05-16 16:57 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-16 16:57 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-21 22:37 | Alan Scott | Status | @80@ => @20@ |
2008-05-21 22:37 | Alan Scott | Resolution | fixed => reopened |
2008-05-21 22:37 | Alan Scott | Note Added: 0012059 | |
2008-05-22 07:40 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-05-22 07:40 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-05-22 07:40 | Utkarsh Ayachit | Note Added: 0012067 | |
2008-05-22 20:23 | Alan Scott | Status | @80@ => closed |
2008-05-22 20:23 | Alan Scott | Note Added: 0012073 | |
