5 #ifndef Moments_server_manager_modules_data_h 6 #define Moments_server_manager_modules_data_h 15 "<ServerManagerConfiguration>\n" 16 " <ProxyGroup name=\"filters\">\n" 18 " <SourceProxy name=\"MomentVectors\" class=\"vtkMomentVectors\"\n" 19 " label=\"Moment Vectors\">\n" 20 " <Documentation short_help=\"Create flux or circulation vectors.\"\n" 21 " long_help=\"Convert scalars to flux or circulation vectors.\">\n" 22 " Often times a simulation that computes circulation or flux in a\n" 23 " mesh will simply write out the scalar that represents the amount of\n" 24 " movement and the direction is implied by the normal of the surface\n" 25 " cell (for flux) or the direction of the line cell (for\n" 26 " circulation). The array values associated with the 2D and 1D\n" 27 " geometric elements will be converted to a vector pointing in the\n" 28 " direction of the flow.\n" 31 " <InputProperty name=\"Input\" command=\"SetInputConnection\">\n" 32 " <ProxyGroupDomain name=\"groups\">\n" 33 " <Group name=\"sources\" />\n" 34 " <Group name=\"filters\" />\n" 35 " </ProxyGroupDomain>\n" 36 " <DataTypeDomain name=\"input_type\">\n" 37 " <DataType value=\"vtkDataSet\" />\n" 38 " </DataTypeDomain>\n" 39 " <InputArrayDomain name=\"input_array\"\n" 40 " attribute_type=\"cell\"\n" 41 " number_of_components=\"1\">\n" 42 " </InputArrayDomain>\n" 44 " The input to the filter.\n" 48 " <StringVectorProperty name=\"SelectInputScalars\"\n" 49 " command=\"SetInputArrayToProcess\"\n" 50 " number_of_elements=\"5\"\n" 51 " element_types=\"0 0 0 0 2\"\n" 52 " label=\"Flux/Circulation Array\">\n" 53 " <ArrayListDomain name=\"array_list\" attribute_type=\"Scalars\">\n" 54 " <RequiredProperties>\n" 55 " <Property name=\"Input\" function=\"Input\" />\n" 56 " </RequiredProperties>\n" 57 " </ArrayListDomain>\n" 59 " The name of the scalar array that represents flux through a 2D\n" 60 " element or circulation along a 1D element. This array will be\n" 61 " converted to a vector pointing in the direction the flow or\n" 62 " circulation is moving.\n" 64 " </StringVectorProperty>\n" 66 " <IntVectorProperty name=\"InputMomentIsDensity\"\n" 67 " command=\"SetInputMomentIsDensity\"\n" 68 " number_of_elements=\"1\"\n" 69 " default_values=\"0\"\n" 70 " label=\"Input Moment Is Density\">\n" 71 " <BooleanDomain name=\"bool\" />\n" 73 " If off, then the input array is taken to be the total flux\n" 74 " through or circulation along each element. If on, then the input\n" 75 " array is taken to be the density of the flux or circulation.\n" 77 " </IntVectorProperty>\n" 78 " </SourceProxy> <!-- Moment Vectors -->\n" 80 " <SourceProxy name=\"MomentGlyphs\" class=\"vtkMomentGlyphs\"\n" 81 " label=\"Moment Glyphs\">\n" 82 " <Documentation short_help=\"Create flux or circulation glyphs.\"\n" 83 " long_help=\"Create glyphs pointing in the direction of flux or circulation.\">\n" 84 " Circulation is a vector field on 1D cells that represents flow\n" 85 " along the path of the cell. Flux is a vector field on 2D cells\n" 86 " that represents flow through the area of the cell. This filter\n" 87 " creates arrow glyphs in the direction of the flow. The array\n" 88 " values associated with the 2D and 1D geometric elements will be\n" 89 " converted to a vector pointing in the direction of the flow.\n" 92 " <InputProperty name=\"Input\" command=\"SetInputConnection\">\n" 93 " <ProxyGroupDomain name=\"groups\">\n" 94 " <Group name=\"sources\" />\n" 95 " <Group name=\"filters\" />\n" 96 " </ProxyGroupDomain>\n" 97 " <DataTypeDomain name=\"input_type\">\n" 98 " <DataType value=\"vtkDataSet\" />\n" 99 " </DataTypeDomain>\n" 100 " <InputArrayDomain name=\"input_array\"\n" 101 " attribute_type=\"cell\">\n" 102 " </InputArrayDomain>\n" 104 " The input to the filter.\n" 105 " </Documentation>\n" 106 " </InputProperty>\n" 108 " <StringVectorProperty name=\"SelectInputScalars\"\n" 109 " command=\"SetInputArrayToProcess\"\n" 110 " number_of_elements=\"5\"\n" 111 " element_types=\"0 0 0 0 2\"\n" 112 " label=\"Flux/Circulation Array\">\n" 113 " <ArrayListDomain name=\"array_list\" attribute_type=\"Scalars\">\n" 114 " <RequiredProperties>\n" 115 " <Property name=\"Input\" function=\"Input\" />\n" 116 " </RequiredProperties>\n" 117 " </ArrayListDomain>\n" 119 " The name of the scalar or vector array that represents flux\n" 120 " through a 2D element or circulation along a 1D element. If\n" 121 " necessary, this array will be converted to a vector pointing in\n" 122 " the direction the flow or circulation is moving.\n" 123 " </Documentation>\n" 124 " </StringVectorProperty>\n" 126 " <IntVectorProperty name=\"InputMomentIsDensity\"\n" 127 " command=\"SetInputMomentIsDensity\"\n" 128 " number_of_elements=\"1\"\n" 129 " default_values=\"0\"\n" 130 " label=\"Input Moment Is Density\">\n" 131 " <BooleanDomain name=\"bool\" />\n" 133 " If off, then the input array is taken to be the total flux\n" 134 " through or circulation along each element. If on, then the input\n" 135 " array is taken to be the density of the flux or circulation.\n" 136 " </Documentation>\n" 137 " </IntVectorProperty>\n" 139 " <IntVectorProperty name=\"ScaleByDenisty\"\n" 140 " command=\"SetScaleByDensity\"\n" 141 " number_of_elements=\"1\"\n" 142 " default_values=\"0\"\n" 143 " label=\"Scale By Density\">\n" 144 " <BooleanDomain name=\"bool\" />\n" 146 " If off, then the glyphs are scaled by the total flux through or\n" 147 " circulation along each element. If on, then the glyphs are\n" 148 " scaled by the flux or circulation density.\n" 149 " </Documentation>\n" 150 " </IntVectorProperty>\n" 151 " </SourceProxy> <!-- Moment Glyphs -->\n" 154 "</ServerManagerConfiguration>\n" 163 char* res =
new char[ len + 1];
166 assert(offset == len);
static const char *const Moments_server_manager_modulesMomentsInterface0
char * Moments_server_manager_modulesMomentsGetInterfaces()
