NonOrthogonalSource_server_manager_modules_data.h
1 // Loadable modules
2 //
3 // Generated by /builds/gitlab-kitware-sciviz-ci/build/bin/vtkProcessXML-pv5.13
4 //
5 #ifndef NonOrthogonalSource_server_manager_modules_data_h
6 #define NonOrthogonalSource_server_manager_modules_data_h
7
8 #include <cstring>
9 #include <cassert>
10 #include <algorithm>
11
12
13 // From file /builds/gitlab-kitware-sciviz-ci/Plugins/NonOrthogonalSource/Sources/vtkNonOrthogonalSource.xml
15 "<ServerManagerConfiguration>\n"
16 " <ProxyGroup name=\"sources\">\n"
17 " <SourceProxy name=\"ShearedWavelet\" label=\"Sheared Wavelet\" class=\"vtkShearedWaveletSource\">\n"
18 " <DoubleVectorProperty\n"
19 " name=\"U\"\n"
20 " command=\"SetBasisU\"\n"
21 " number_of_elements=\"3\"\n"
22 " default_values=\"1.0 0.0 0.0\"\n"
23 " panel_visibility=\"default\" >\n"
24 " <DoubleRangeDomain name=\"range\"/>\n"
25 " <Documentation>\n"
26 " The values of this property set the corresponding X axis direction.\n"
27 " </Documentation>\n"
28 " </DoubleVectorProperty>\n"
29 "\n"
30 " <DoubleVectorProperty\n"
31 " name=\"V\"\n"
32 " command=\"SetBasisV\"\n"
33 " number_of_elements=\"3\"\n"
34 " default_values=\"0.0 1.0 0.0\"\n"
35 " panel_visibility=\"default\" >\n"
36 " <DoubleRangeDomain name=\"range\"/>\n"
37 " <Documentation>\n"
38 " The values of this property set the corresponding Y axis direction.\n"
39 " </Documentation>\n"
40 " </DoubleVectorProperty>\n"
41 "\n"
42 " <DoubleVectorProperty\n"
43 " name=\"W\"\n"
44 " command=\"SetBasisW\"\n"
45 " number_of_elements=\"3\"\n"
46 " default_values=\"0.0 0.0 1.0\"\n"
47 " panel_visibility=\"default\" >\n"
48 " <DoubleRangeDomain name=\"range\"/>\n"
49 " <Documentation>\n"
50 " The values of this property set the corresponding Z axis direction.\n"
51 " </Documentation>\n"
52 " </DoubleVectorProperty>\n"
53 "\n"
54 " <StringVectorProperty\n"
55 " name=\"UTitle\"\n"
56 " command=\"SetAxisUTitle\"\n"
57 " number_of_elements=\"1\"\n"
58 " default_values=\"Base U\"\n"
59 " panel_visibility=\"default\">\n"
60 " <Documentation>\n"
61 " This property specifies the text to display for the X axis.\n"
62 " </Documentation>\n"
63 " </StringVectorProperty>\n"
64 "\n"
65 " <StringVectorProperty\n"
66 " name=\"VTitle\"\n"
67 " command=\"SetAxisVTitle\"\n"
68 " number_of_elements=\"1\"\n"
69 " default_values=\"Base V\"\n"
70 " panel_visibility=\"default\">\n"
71 " <Documentation>\n"
72 " This property specifies the text to display for the Y axis.\n"
73 " </Documentation>\n"
74 " </StringVectorProperty>\n"
75 "\n"
76 " <StringVectorProperty\n"
77 " name=\"WTitle\"\n"
78 " command=\"SetAxisWTitle\"\n"
79 " number_of_elements=\"1\"\n"
80 " default_values=\"Base W\"\n"
81 " panel_visibility=\"default\">\n"
82 " <Documentation>\n"
83 " This property specifies the text to display for the Z axis.\n"
84 " </Documentation>\n"
85 " </StringVectorProperty>\n"
86 "\n"
87 " <IntVectorProperty name=\"EnableAxisTitles\"\n"
88 " command=\"SetEnableAxisTitles\"\n"
89 " number_of_elements=\"1\"\n"
90 " default_values=\"0\"\n"
91 " panel_visibility=\"default\">\n"
92 " <BooleanDomain name=\"bool\"/>\n"
93 " </IntVectorProperty>\n"
94 "\n"
95 " <IntVectorProperty name=\"EnableTimeLabel\"\n"
96 " command=\"SetEnableTimeLabel\"\n"
97 " number_of_elements=\"1\"\n"
98 " default_values=\"0\"\n"
99 " panel_visibility=\"default\">\n"
100 " <BooleanDomain name=\"bool\"/>\n"
101 " </IntVectorProperty>\n"
102 " <DoubleVectorProperty name=\"ModelBoundingBox\"\n"
103 " command=\"SetModelBoundingBox\"\n"
104 " number_of_elements=\"6\"\n"
105 " default_values=\"0 1 0 1 0 1\">\n"
106 " <DoubleRangeDomain name=\"range\" />\n"
107 " </DoubleVectorProperty>\n"
108 " <StringVectorProperty name=\"TimeLabel\"\n"
109 " command=\"SetTimeLabel\"\n"
110 " number_of_elements=\"1\"\n"
111 " default_values=\"Time\"\n"
112 " panel_visibility=\"default\">\n"
113 " <Documentation>\n"
114 " This property specifies the text to use for time label.\n"
115 " </Documentation>\n"
116 " </StringVectorProperty>\n"
117 " <StringVectorProperty name=\"TimeLabelAnnotation\"\n"
118 " command=\"GetTimeLabelAnnotation\"\n"
119 " information_only=\"1\">\n"
120 " </StringVectorProperty>\n"
121 " </SourceProxy>\n"
122 " </ProxyGroup>\n"
123 "</ServerManagerConfiguration>\n"
124 "\n";
125 // Get single string
127 {
128
130  size_t len = ( 0
131  + len0 );
132  char* res = new char[ len + 1];
133  size_t offset = 0;
135  assert(offset == len);
136  res[offset] = 0;
137  return res;
138 }
139
140
141
142 #endif
char * NonOrthogonalSource_server_manager_modulesvtkNonOrthogonalSourceGetInterfaces()
offset
static const char *const NonOrthogonalSource_server_manager_modulesvtkNonOrthogonalSourceInterface0
