#define | __DBL_MIN_EXP__ (-1021) |
#define | __cpp_attributes 200809L |
#define | __cpp_nontype_template_parameter_auto 201606L |
#define | __UINT_LEAST16_MAX__ 0xffff |
#define | __ATOMIC_ACQUIRE 2 |
#define | __FLT128_MAX_10_EXP__ 4932 |
#define | __FLT_MIN__ 1.17549435082228750796873653722224568e-38F |
#define | __GCC_IEC_559_COMPLEX 2 |
#define | __cpp_aggregate_nsdmi 201304L |
#define | __UINT_LEAST8_TYPE__ unsigned char |
#define | __SIZEOF_FLOAT80__ 16 |
#define | __INTMAX_C(c) c ## L |
#define | __CHAR_BIT__ 8 |
#define | __UINT8_MAX__ 0xff |
#define | __SCHAR_WIDTH__ 8 |
#define | __WINT_MAX__ 0xffffffffU |
#define | __FLT32_MIN_EXP__ (-125) |
#define | __cpp_static_assert 201411L |
#define | QT_GUI_LIB 1 |
#define | __ORDER_LITTLE_ENDIAN__ 1234 |
#define | __SIZE_MAX__ 0xffffffffffffffffUL |
#define | __WCHAR_MAX__ 0x7fffffff |
#define | __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1 1 |
#define | __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2 1 |
#define | __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4 1 |
#define | __DBL_DENORM_MIN__ double(4.94065645841246544176568792868221372e-324L) |
#define | __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8 1 |
#define | __GCC_ATOMIC_CHAR_LOCK_FREE 2 |
#define | __GCC_IEC_559 2 |
#define | __FLT32X_DECIMAL_DIG__ 17 |
#define | __FLT_EVAL_METHOD__ 0 |
#define | __cpp_binary_literals 201304L |
#define | __FLT64_DECIMAL_DIG__ 17 |
#define | __cpp_noexcept_function_type 201510L |
#define | __GCC_ATOMIC_CHAR32_T_LOCK_FREE 2 |
#define | __cpp_variadic_templates 200704L |
#define | __UINT_FAST64_MAX__ 0xffffffffffffffffUL |
#define | __SIG_ATOMIC_TYPE__ int |
#define | __DBL_MIN_10_EXP__ (-307) |
#define | __FINITE_MATH_ONLY__ 0 |
#define | __cpp_variable_templates 201304L |
#define | __FLT32X_MAX_EXP__ 1024 |
#define | __FLT32_HAS_DENORM__ 1 |
#define | __UINT_FAST8_MAX__ 0xff |
#define | __cpp_rvalue_reference 200610L |
#define | __cpp_nested_namespace_definitions 201411L |
#define | __DEC64_MAX_EXP__ 385 |
#define | __INT8_C(c) c |
#define | __INT_LEAST8_WIDTH__ 8 |
#define | __cpp_variadic_using 201611L |
#define | __UINT_LEAST64_MAX__ 0xffffffffffffffffUL |
#define | QT_OPENGL_LIB 1 |
#define | __INT_LEAST8_MAX__ 0x7f |
#define | __cpp_capture_star_this 201603L |
#define | __SHRT_MAX__ 0x7fff |
#define | __LDBL_MAX__ 1.18973149535723176502126385303097021e+4932L |
#define | __FLT64X_MAX_10_EXP__ 4932 |
#define | __cpp_if_constexpr 201606L |
#define | __LDBL_IS_IEC_60559__ 2 |
#define | __FLT64X_HAS_QUIET_NAN__ 1 |
#define | __UINT_LEAST8_MAX__ 0xff |
#define | __GCC_ATOMIC_BOOL_LOCK_FREE 2 |
#define | __FLT128_DENORM_MIN__ 6.47517511943802511092443895822764655e-4966F128 |
#define | __UINTMAX_TYPE__ long unsigned int |
#define | __linux 1 |
#define | __DEC32_EPSILON__ 1E-6DF |
#define | __FLT_EVAL_METHOD_TS_18661_3__ 0 |
#define | __unix 1 |
#define | __UINT32_MAX__ 0xffffffffU |
#define | __GXX_EXPERIMENTAL_CXX0X__ 1 |
#define | __FLT128_MIN_EXP__ (-16381) |
#define | __WINT_MIN__ 0U |
#define | __FLT128_MIN_10_EXP__ (-4931) |
#define | __FLT32X_IS_IEC_60559__ 2 |
#define | __INT_LEAST16_WIDTH__ 16 |
#define | __SCHAR_MAX__ 0x7f |
#define | __FLT128_MANT_DIG__ 113 |
#define | __WCHAR_MIN__ (-__WCHAR_MAX__ - 1) |
#define | __INT64_C(c) c ## L |
#define | __GCC_ATOMIC_POINTER_LOCK_FREE 2 |
#define | __FLT32X_MANT_DIG__ 53 |
#define | __GCC_ATOMIC_CHAR16_T_LOCK_FREE 2 |
#define | __cpp_aligned_new 201606L |
#define | __USER_LABEL_PREFIX__ |
#define | __FLT32_MAX_10_EXP__ 38 |
#define | __FLT64X_EPSILON__ 1.08420217248550443400745280086994171e-19F64x |
#define | __STDC_HOSTED__ 1 |
#define | __DEC64_MIN_EXP__ (-382) |
#define | __cpp_decltype_auto 201304L |
#define | __DBL_DIG__ 15 |
#define | __FLT32_DIG__ 6 |
#define | NodeEditor_EXPORTS 1 |
#define | __FLT_EPSILON__ 1.19209289550781250000000000000000000e-7F |
#define | __GXX_WEAK__ 1 |
#define | __SHRT_WIDTH__ 16 |
#define | __FLT32_IS_IEC_60559__ 2 |
#define | __LDBL_MIN__ 3.36210314311209350626267781732175260e-4932L |
#define | __DBL_IS_IEC_60559__ 2 |
#define | __DEC32_MAX__ 9.999999E96DF |
#define | __cpp_threadsafe_static_init 200806L |
#define | __cpp_enumerator_attributes 201411L |
#define | __FLT64X_DENORM_MIN__ 3.64519953188247460252840593361941982e-4951F64x |
#define | __FLT32X_HAS_INFINITY__ 1 |
#define | __INT32_MAX__ 0x7fffffff |
#define | __unix__ 1 |
#define | __INT_WIDTH__ 32 |
#define | __SIZEOF_LONG__ 8 |
#define | __STDC_IEC_559__ 1 |
#define | __STDC_ISO_10646__ 201706L |
#define | __UINT16_C(c) c |
#define | __DECIMAL_DIG__ 21 |
#define | __STDC_IEC_559_COMPLEX__ 1 |
#define | __FLT64_EPSILON__ 2.22044604925031308084726333618164062e-16F64 |
#define | __gnu_linux__ 1 |
#define | __INT16_MAX__ 0x7fff |
#define | __FLT64_MIN_EXP__ (-1021) |
#define | __FLT64X_MIN_10_EXP__ (-4931) |
#define | __LDBL_HAS_QUIET_NAN__ 1 |
#define | __FLT64_MANT_DIG__ 53 |
#define | __FLT64X_MANT_DIG__ 64 |
#define | __GNUC__ 11 |
#define | __GXX_RTTI 1 |
#define | __MMX__ 1 |
#define | __FLT_HAS_DENORM__ 1 |
#define | __SIZEOF_LONG_DOUBLE__ 16 |
#define | __BIGGEST_ALIGNMENT__ 16 |
#define | __STDC_UTF_16__ 1 |
#define | __FLT64_MAX_10_EXP__ 308 |
#define | __cpp_delegating_constructors 200604L |
#define | __FLT32_HAS_INFINITY__ 1 |
#define | __DBL_MAX__ double(1.79769313486231570814527423731704357e+308L) |
#define | __cpp_raw_strings 200710L |
#define | __INT_FAST32_MAX__ 0x7fffffffffffffffL |
#define | __DBL_HAS_INFINITY__ 1 |
#define | __SIZEOF_FLOAT__ 4 |
#define | __HAVE_SPECULATION_SAFE_VALUE 1 |
#define | __cpp_fold_expressions 201603L |
#define | __DEC32_MIN_EXP__ (-94) |
#define | __INTPTR_WIDTH__ 64 |
#define | __FLT64X_HAS_INFINITY__ 1 |
#define | __UINT_LEAST32_MAX__ 0xffffffffU |
#define | __FLT32X_HAS_DENORM__ 1 |
#define | __INT_FAST16_TYPE__ long int |
#define | __MMX_WITH_SSE__ 1 |
#define | __LDBL_HAS_DENORM__ 1 |
#define | QT_WIDGETS_LIB 1 |
#define | __cplusplus 201703L |
#define | __cpp_ref_qualifiers 200710L |
#define | __DEC32_MIN__ 1E-95DF |
#define | __DEPRECATED 1 |
#define | __cpp_rvalue_references 200610L |
#define | __DBL_MAX_EXP__ 1024 |
#define | __WCHAR_WIDTH__ 32 |
#define | __FLT32_MAX__ 3.40282346638528859811704183484516925e+38F32 |
#define | __DEC128_EPSILON__ 1E-33DL |
#define | __SSE2_MATH__ 1 |
#define | __ATOMIC_HLE_RELEASE 131072 |
#define | __PTRDIFF_MAX__ 0x7fffffffffffffffL |
#define | __amd64 1 |
#define | __ATOMIC_HLE_ACQUIRE 65536 |
#define | __GNUG__ 11 |
#define | __LONG_LONG_MAX__ 0x7fffffffffffffffLL |
#define | __SIZEOF_SIZE_T__ 8 |
#define | __cpp_nsdmi 200809L |
#define | __FLT64X_MIN_EXP__ (-16381) |
#define | __SIZEOF_WINT_T__ 4 |
#define | __LONG_LONG_WIDTH__ 64 |
#define | __cpp_initializer_lists 200806L |
#define | __FLT32_MAX_EXP__ 128 |
#define | ABI_ID "ELF" |
#define | __cpp_hex_float 201603L |
#define | __GXX_ABI_VERSION 1016 |
#define | __FLT128_HAS_INFINITY__ 1 |
#define | kiss_fft_scalar double |
#define | __FLT_MIN_EXP__ (-125) |
#define | __GCC_HAVE_DWARF2_CFI_ASM 1 |
#define | __x86_64 1 |
#define | __cpp_lambdas 200907L |
#define | __INT_FAST64_TYPE__ long int |
#define | __FLT64_DENORM_MIN__ 4.94065645841246544176568792868221372e-324F64 |
#define | PROTOBUF_USE_DLLS 1 |
#define | __cpp_template_auto 201606L |
#define | __DBL_MIN__ double(2.22507385850720138309023271733240406e-308L) |
#define | __FLT128_EPSILON__ 1.92592994438723585305597794258492732e-34F128 |
#define | __FLT64X_NORM_MAX__ 1.18973149535723176502126385303097021e+4932F64x |
#define | __SIZEOF_POINTER__ 8 |
#define | __LP64__ 1 |
#define | __DBL_HAS_QUIET_NAN__ 1 |
#define | __FLT32X_EPSILON__ 2.22044604925031308084726333618164062e-16F32x |
#define | __DECIMAL_BID_FORMAT__ 1 |
#define | __FLT64_MIN_10_EXP__ (-307) |
#define | __FLT64X_DECIMAL_DIG__ 21 |
#define | __DEC128_MIN__ 1E-6143DL |
#define | __REGISTER_PREFIX__ |
#define | __UINT16_MAX__ 0xffff |
#define | __LDBL_HAS_INFINITY__ 1 |
#define | __FLT32_MIN__ 1.17549435082228750796873653722224568e-38F32 |
#define | __UINT8_TYPE__ unsigned char |
#define | __FLT_DIG__ 6 |
#define | __NO_INLINE__ 1 |
#define | __DEC_EVAL_METHOD__ 2 |
#define | __DEC128_MAX__ 9.999999999999999999999999999999999E6144DL |
#define | QT_NO_KEYWORDS 1 |
#define | __FLT_MANT_DIG__ 24 |
#define | __LDBL_DECIMAL_DIG__ 21 |
#define | __VERSION__ "11.3.1 20220421 (Red Hat 11.3.1-3)" |
#define | __UINT64_C(c) c ## UL |
#define | __cpp_unicode_characters 201411L |
#define | _STDC_PREDEF_H 1 |
#define | __INT_LEAST32_MAX__ 0x7fffffff |
#define | __GCC_ATOMIC_INT_LOCK_FREE 2 |
#define | __FLT128_MAX_EXP__ 16384 |
#define | __FLT32_MANT_DIG__ 24 |
#define | __FLOAT_WORD_ORDER__ __ORDER_LITTLE_ENDIAN__ |
#define | SIZEOF_DPTR (sizeof(void*)) |
#define | __cpp_aggregate_bases 201603L |
#define | __FLT128_HAS_DENORM__ 1 |
#define | __FLT32_DECIMAL_DIG__ 9 |
#define | __FLT128_DIG__ 33 |
#define | __INT32_C(c) c |
#define | __DEC64_EPSILON__ 1E-15DD |
#define | __ORDER_PDP_ENDIAN__ 3412 |
#define | __DEC128_MIN_EXP__ (-6142) |
#define | __INT_FAST32_TYPE__ long int |
#define | __UINT_LEAST16_TYPE__ short unsigned int |
#define | unix 1 |
#define | __DBL_HAS_DENORM__ 1 |
#define | __cpp_rtti 199711L |
#define | __SIZE_TYPE__ long unsigned int |
#define | __UINT64_MAX__ 0xffffffffffffffffUL |
#define | __FLT_IS_IEC_60559__ 2 |
#define | __GNUC_WIDE_EXECUTION_CHARSET_NAME "UTF-32LE" |
#define | __FLT64X_DIG__ 18 |
#define | __INT8_TYPE__ signed char |
#define | __cpp_digit_separators 201309L |
#define | __ELF__ 1 |
#define | __GCC_ASM_FLAG_OUTPUTS__ 1 |
#define | __UINT32_TYPE__ unsigned int |
#define | __FLT_RADIX__ 2 |
#define | __INT_LEAST16_TYPE__ short int |
#define | __LDBL_EPSILON__ 1.08420217248550443400745280086994171e-19L |
#define | __UINTMAX_C(c) c ## UL |
#define | __GNUC_RH_RELEASE__ 3 |
#define | __GLIBCXX_BITSIZE_INT_N_0 128 |
#define | __k8 1 |
#define | __FLT32X_MIN__ 2.22507385850720138309023271733240406e-308F32x |
#define | __SIG_ATOMIC_MAX__ 0x7fffffff |
#define | __GCC_ATOMIC_WCHAR_T_LOCK_FREE 2 |
#define | __SIZEOF_PTRDIFF_T__ 8 |
#define | __LDBL_DIG__ 18 |
#define | __FLT64_IS_IEC_60559__ 2 |
#define | __x86_64__ 1 |
#define | __FLT32X_MIN_EXP__ (-1021) |
#define | __DEC32_SUBNORMAL_MIN__ 0.000001E-95DF |
#define | __INT_FAST16_MAX__ 0x7fffffffffffffffL |
#define | __FLT64_DIG__ 15 |
#define | __UINT_FAST32_MAX__ 0xffffffffffffffffUL |
#define | __UINT_LEAST64_TYPE__ long unsigned int |
#define | __FLT_HAS_QUIET_NAN__ 1 |
#define | __FLT_MAX_10_EXP__ 38 |
#define | __LONG_MAX__ 0x7fffffffffffffffL |
#define | __FLT64X_HAS_DENORM__ 1 |
#define | __DEC128_SUBNORMAL_MIN__ 0.000000000000000000000000000000001E-6143DL |
#define | __FLT_HAS_INFINITY__ 1 |
#define | __GNUC_EXECUTION_CHARSET_NAME "UTF-8" |
#define | __cpp_unicode_literals 200710L |
#define | __UINT_FAST16_TYPE__ long unsigned int |
#define | __DEC64_MAX__ 9.999999999999999E384DD |
#define | __INT_FAST32_WIDTH__ 64 |
#define | __CHAR16_TYPE__ short unsigned int |
#define | __PRAGMA_REDEFINE_EXTNAME 1 |
#define | __SIZE_WIDTH__ 64 |
#define | __SEG_FS 1 |
#define | __INT_LEAST16_MAX__ 0x7fff |
#define | __DEC64_MANT_DIG__ 16 |
#define | __INT64_MAX__ 0x7fffffffffffffffL |
#define | __SEG_GS 1 |
#define | __FLT32_DENORM_MIN__ 1.40129846432481707092372958328991613e-45F32 |
#define | __SIG_ATOMIC_WIDTH__ 32 |
#define | __INT_LEAST64_TYPE__ long int |
#define | __INT16_TYPE__ short int |
#define | __INT_LEAST8_TYPE__ signed char |
#define | __cpp_structured_bindings 201606L |
#define | __SIZEOF_INT__ 4 |
#define | __DEC32_MAX_EXP__ 97 |
#define | __INT_FAST8_MAX__ 0x7f |
#define | __FLT128_MAX__ 1.18973149535723176508575932662800702e+4932F128 |
#define | __INTPTR_MAX__ 0x7fffffffffffffffL |
#define | __cpp_sized_deallocation 201309L |
#define | __cpp_guaranteed_copy_elision 201606L |
#define | linux 1 |
#define | __FLT64_HAS_QUIET_NAN__ 1 |
#define | __FLT32_MIN_10_EXP__ (-37) |
#define | __EXCEPTIONS 1 |
#define | __PTRDIFF_WIDTH__ 64 |
#define | __LDBL_MANT_DIG__ 64 |
#define | __cpp_range_based_for 201603L |
#define | FMT_SHARED 1 |
#define | __FLT64_HAS_INFINITY__ 1 |
#define | __FLT64X_MAX__ 1.18973149535723176502126385303097021e+4932F64x |
#define | __STDCPP_DEFAULT_NEW_ALIGNMENT__ 16 |
#define | __SIG_ATOMIC_MIN__ (-__SIG_ATOMIC_MAX__ - 1) |
#define | __code_model_small__ 1 |
#define | __GCC_ATOMIC_LONG_LOCK_FREE 2 |
#define | __cpp_nontype_template_args 201411L |
#define | __DEC32_MANT_DIG__ 7 |
#define | __cpp_return_type_deduction 201304L |
#define | __k8__ 1 |
#define | __INTPTR_TYPE__ long int |
#define | __UINT16_TYPE__ short unsigned int |
#define | __WCHAR_TYPE__ int |
#define | __UINTPTR_MAX__ 0xffffffffffffffffUL |
#define | __INT_FAST64_WIDTH__ 64 |
#define | __cpp_decltype 200707L |
#define | __INT_FAST64_MAX__ 0x7fffffffffffffffL |
#define | __GCC_ATOMIC_TEST_AND_SET_TRUEVAL 1 |
#define | __FLT_NORM_MAX__ 3.40282346638528859811704183484516925e+38F |
#define | __FLT64X_MAX_EXP__ 16384 |
#define | __UINT_FAST64_TYPE__ long unsigned int |
#define | __cpp_inline_variables 201606L |
#define | __INT_MAX__ 0x7fffffff |
#define | __linux__ 1 |
#define | __INT64_TYPE__ long int |
#define | __FLT_MAX_EXP__ 128 |
#define | __ORDER_BIG_ENDIAN__ 4321 |
#define | __DBL_MANT_DIG__ 53 |
#define | __cpp_inheriting_constructors 201511L |
#define | QT_CORE_LIB 1 |
#define | __SIZEOF_FLOAT128__ 16 |
#define | __INT_LEAST64_MAX__ 0x7fffffffffffffffL |
#define | __DEC64_MIN__ 1E-383DD |
#define | __WINT_TYPE__ unsigned int |
#define | __UINT_LEAST32_TYPE__ unsigned int |
#define | __SIZEOF_SHORT__ 2 |
#define | __FLT32_NORM_MAX__ 3.40282346638528859811704183484516925e+38F32 |
#define | __SSE__ 1 |
#define | __LDBL_MIN_EXP__ (-16381) |
#define | __FLT64_MAX__ 1.79769313486231570814527423731704357e+308F64 |
#define | __amd64__ 1 |
#define | __WINT_WIDTH__ 32 |
#define | __INT_LEAST64_WIDTH__ 64 |
#define | __LDBL_MAX_EXP__ 16384 |
#define | __FLT32X_MAX_10_EXP__ 308 |
#define | __SIZEOF_INT128__ 16 |
#define | __FLT64X_IS_IEC_60559__ 2 |
#define | __LDBL_MAX_10_EXP__ 4932 |
#define | __ATOMIC_RELAXED 0 |
#define | __DBL_EPSILON__ double(2.22044604925031308084726333618164062e-16L) |
#define | __FLT128_MIN__ 3.36210314311209350626267781732175260e-4932F128 |
#define | _LP64 1 |
#define | __UINT8_C(c) c |
#define | __FLT64_MAX_EXP__ 1024 |
#define | __INT_LEAST32_TYPE__ int |
#define | __SIZEOF_WCHAR_T__ 4 |
#define | __GNUC_PATCHLEVEL__ 1 |
#define | __FLT128_NORM_MAX__ 1.18973149535723176508575932662800702e+4932F128 |
#define | __FLT64_NORM_MAX__ 1.79769313486231570814527423731704357e+308F64 |
#define | __FLT128_HAS_QUIET_NAN__ 1 |
#define | __INTMAX_MAX__ 0x7fffffffffffffffL |
#define | __INT_FAST8_TYPE__ signed char |
#define | __cpp_namespace_attributes 201411L |
#define | __FLT64X_MIN__ 3.36210314311209350626267781732175260e-4932F64x |
#define | __STDCPP_THREADS__ 1 |
#define | __GNUC_STDC_INLINE__ 1 |
#define | __FLT64_HAS_DENORM__ 1 |
#define | __FLT32_EPSILON__ 1.19209289550781250000000000000000000e-7F32 |
#define | __DBL_DECIMAL_DIG__ 17 |
#define | __STDC_UTF_32__ 1 |
#define | __INT_FAST8_WIDTH__ 8 |
#define | __FXSR__ 1 |
#define | __FLT32X_MAX__ 1.79769313486231570814527423731704357e+308F32x |
#define | __DBL_NORM_MAX__ double(1.79769313486231570814527423731704357e+308L) |
#define | __BYTE_ORDER__ __ORDER_LITTLE_ENDIAN__ |
#define | __INTMAX_WIDTH__ 64 |
#define | __cpp_runtime_arrays 198712L |
#define | __UINT64_TYPE__ long unsigned int |
#define | __UINT32_C(c) c ## U |
#define | __cpp_alias_templates 200704L |
#define | __FLT_DENORM_MIN__ 1.40129846432481707092372958328991613e-45F |
#define | __FLT128_IS_IEC_60559__ 2 |
#define | __INT8_MAX__ 0x7f |
#define | __LONG_WIDTH__ 64 |
#define | __UINT_FAST32_TYPE__ long unsigned int |
#define | __FLT32X_NORM_MAX__ 1.79769313486231570814527423731704357e+308F32x |
#define | __CHAR32_TYPE__ unsigned int |
#define | __FLT_MAX__ 3.40282346638528859811704183484516925e+38F |
#define | __cpp_constexpr 201603L |
#define | __SSE2__ 1 |
#define | __cpp_deduction_guides 201703L |
#define | __INT32_TYPE__ int |
#define | __SIZEOF_DOUBLE__ 8 |
#define | __cpp_exceptions 199711L |
#define | __FLT_MIN_10_EXP__ (-37) |
#define | __FLT64_MIN__ 2.22507385850720138309023271733240406e-308F64 |
#define | __INT_LEAST32_WIDTH__ 32 |
#define | __INTMAX_TYPE__ long int |
#define | __DEC128_MAX_EXP__ 6145 |
#define | __FLT32X_HAS_QUIET_NAN__ 1 |
#define | __ATOMIC_CONSUME 1 |
#define | __GNUC_MINOR__ 3 |
#define | __GLIBCXX_TYPE_INT_N_0 __int128 |
#define | __INT_FAST16_WIDTH__ 64 |
#define | __UINTMAX_MAX__ 0xffffffffffffffffUL |
#define | __FLT32X_DENORM_MIN__ 4.94065645841246544176568792868221372e-324F32x |
#define | __cpp_template_template_args 201611L |
#define | __DBL_MAX_10_EXP__ 308 |
#define | __LDBL_DENORM_MIN__ 3.64519953188247460252840593361941982e-4951L |
#define | __INT16_C(c) c |
#define | __STDC__ 1 |
#define | __FLT32X_DIG__ 15 |
#define | __PTRDIFF_TYPE__ long int |
#define | __ATOMIC_SEQ_CST 5 |
#define | __FLT32X_MIN_10_EXP__ (-307) |
#define | __UINTPTR_TYPE__ long unsigned int |
#define | __DEC64_SUBNORMAL_MIN__ 0.000000000000001E-383DD |
#define | __DEC128_MANT_DIG__ 34 |
#define | __LDBL_MIN_10_EXP__ (-4931) |
#define | __cpp_generic_lambdas 201304L |
#define | __SSE_MATH__ 1 |
#define | __SIZEOF_LONG_LONG__ 8 |
#define | __cpp_user_defined_literals 200809L |
#define | __FLT128_DECIMAL_DIG__ 36 |
#define | __GCC_ATOMIC_LLONG_LOCK_FREE 2 |
#define | __FLT32_HAS_QUIET_NAN__ 1 |
#define | __FLT_DECIMAL_DIG__ 9 |
#define | __UINT_FAST16_MAX__ 0xffffffffffffffffUL |
#define | __LDBL_NORM_MAX__ 1.18973149535723176502126385303097021e+4932L |
#define | __GCC_ATOMIC_SHORT_LOCK_FREE 2 |
#define | __UINT_FAST8_TYPE__ unsigned char |
#define | _GNU_SOURCE 1 |
#define | __cpp_init_captures 201304L |
#define | __ATOMIC_ACQ_REL 4 |
#define | __ATOMIC_RELEASE 3 |
#define __DBL_MIN_EXP__ (-1021) |
Definition at line 1 of file moc_predefs.h.
#define __cpp_attributes 200809L |
Definition at line 2 of file moc_predefs.h.
#define __cpp_nontype_template_parameter_auto 201606L |
Definition at line 3 of file moc_predefs.h.
#define __UINT_LEAST16_MAX__ 0xffff |
Definition at line 4 of file moc_predefs.h.
#define __ATOMIC_ACQUIRE 2 |
Definition at line 5 of file moc_predefs.h.
#define __FLT128_MAX_10_EXP__ 4932 |
Definition at line 6 of file moc_predefs.h.
#define __FLT_MIN__ 1.17549435082228750796873653722224568e-38F |
Definition at line 7 of file moc_predefs.h.
#define __GCC_IEC_559_COMPLEX 2 |
Definition at line 8 of file moc_predefs.h.
#define __cpp_aggregate_nsdmi 201304L |
Definition at line 9 of file moc_predefs.h.
#define __UINT_LEAST8_TYPE__ unsigned char |
Definition at line 10 of file moc_predefs.h.
#define __SIZEOF_FLOAT80__ 16 |
Definition at line 11 of file moc_predefs.h.
#define __INTMAX_C | ( | c | ) | c ## L |
Definition at line 12 of file moc_predefs.h.
#define __CHAR_BIT__ 8 |
Definition at line 13 of file moc_predefs.h.
#define __UINT8_MAX__ 0xff |
Definition at line 14 of file moc_predefs.h.
#define __SCHAR_WIDTH__ 8 |
Definition at line 15 of file moc_predefs.h.
#define __WINT_MAX__ 0xffffffffU |
Definition at line 16 of file moc_predefs.h.
#define __FLT32_MIN_EXP__ (-125) |
Definition at line 17 of file moc_predefs.h.
#define __cpp_static_assert 201411L |
Definition at line 18 of file moc_predefs.h.
#define QT_GUI_LIB 1 |
Definition at line 19 of file moc_predefs.h.
#define __ORDER_LITTLE_ENDIAN__ 1234 |
Definition at line 20 of file moc_predefs.h.
#define __SIZE_MAX__ 0xffffffffffffffffUL |
Definition at line 21 of file moc_predefs.h.
#define __WCHAR_MAX__ 0x7fffffff |
Definition at line 22 of file moc_predefs.h.
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1 1 |
Definition at line 23 of file moc_predefs.h.
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2 1 |
Definition at line 24 of file moc_predefs.h.
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4 1 |
Definition at line 25 of file moc_predefs.h.
#define __DBL_DENORM_MIN__ double(4.94065645841246544176568792868221372e-324L) |
Definition at line 26 of file moc_predefs.h.
#define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8 1 |
Definition at line 27 of file moc_predefs.h.
#define __GCC_ATOMIC_CHAR_LOCK_FREE 2 |
Definition at line 28 of file moc_predefs.h.
#define __GCC_IEC_559 2 |
Definition at line 29 of file moc_predefs.h.
#define __FLT32X_DECIMAL_DIG__ 17 |
Definition at line 30 of file moc_predefs.h.
#define __FLT_EVAL_METHOD__ 0 |
Definition at line 31 of file moc_predefs.h.
#define __cpp_binary_literals 201304L |
Definition at line 32 of file moc_predefs.h.
#define __FLT64_DECIMAL_DIG__ 17 |
Definition at line 33 of file moc_predefs.h.
#define __cpp_noexcept_function_type 201510L |
Definition at line 34 of file moc_predefs.h.
#define __GCC_ATOMIC_CHAR32_T_LOCK_FREE 2 |
Definition at line 35 of file moc_predefs.h.
#define __cpp_variadic_templates 200704L |
Definition at line 36 of file moc_predefs.h.
#define __UINT_FAST64_MAX__ 0xffffffffffffffffUL |
Definition at line 37 of file moc_predefs.h.
#define __SIG_ATOMIC_TYPE__ int |
Definition at line 38 of file moc_predefs.h.
#define __DBL_MIN_10_EXP__ (-307) |
Definition at line 39 of file moc_predefs.h.
#define __FINITE_MATH_ONLY__ 0 |
Definition at line 40 of file moc_predefs.h.
#define __cpp_variable_templates 201304L |
Definition at line 41 of file moc_predefs.h.
#define __FLT32X_MAX_EXP__ 1024 |
Definition at line 42 of file moc_predefs.h.
#define __FLT32_HAS_DENORM__ 1 |
Definition at line 43 of file moc_predefs.h.
#define __UINT_FAST8_MAX__ 0xff |
Definition at line 44 of file moc_predefs.h.
#define __cpp_rvalue_reference 200610L |
Definition at line 45 of file moc_predefs.h.
#define __cpp_nested_namespace_definitions 201411L |
Definition at line 46 of file moc_predefs.h.
#define __DEC64_MAX_EXP__ 385 |
Definition at line 47 of file moc_predefs.h.
#define __INT8_C | ( | c | ) | c |
Definition at line 48 of file moc_predefs.h.
#define __INT_LEAST8_WIDTH__ 8 |
Definition at line 49 of file moc_predefs.h.
#define __cpp_variadic_using 201611L |
Definition at line 50 of file moc_predefs.h.
#define __UINT_LEAST64_MAX__ 0xffffffffffffffffUL |
Definition at line 51 of file moc_predefs.h.
#define QT_OPENGL_LIB 1 |
Definition at line 52 of file moc_predefs.h.
#define __INT_LEAST8_MAX__ 0x7f |
Definition at line 53 of file moc_predefs.h.
#define __cpp_capture_star_this 201603L |
Definition at line 54 of file moc_predefs.h.
#define __SHRT_MAX__ 0x7fff |
Definition at line 55 of file moc_predefs.h.
#define __LDBL_MAX__ 1.18973149535723176502126385303097021e+4932L |
Definition at line 56 of file moc_predefs.h.
#define __FLT64X_MAX_10_EXP__ 4932 |
Definition at line 57 of file moc_predefs.h.
#define __cpp_if_constexpr 201606L |
Definition at line 58 of file moc_predefs.h.
#define __LDBL_IS_IEC_60559__ 2 |
Definition at line 59 of file moc_predefs.h.
#define __FLT64X_HAS_QUIET_NAN__ 1 |
Definition at line 60 of file moc_predefs.h.
#define __UINT_LEAST8_MAX__ 0xff |
Definition at line 61 of file moc_predefs.h.
#define __GCC_ATOMIC_BOOL_LOCK_FREE 2 |
Definition at line 62 of file moc_predefs.h.
#define __FLT128_DENORM_MIN__ 6.47517511943802511092443895822764655e-4966F128 |
Definition at line 63 of file moc_predefs.h.
#define __UINTMAX_TYPE__ long unsigned int |
Definition at line 64 of file moc_predefs.h.
#define __linux 1 |
Definition at line 65 of file moc_predefs.h.
#define __DEC32_EPSILON__ 1E-6DF |
Definition at line 66 of file moc_predefs.h.
#define __FLT_EVAL_METHOD_TS_18661_3__ 0 |
Definition at line 67 of file moc_predefs.h.
#define __unix 1 |
Definition at line 68 of file moc_predefs.h.
#define __UINT32_MAX__ 0xffffffffU |
Definition at line 69 of file moc_predefs.h.
#define __GXX_EXPERIMENTAL_CXX0X__ 1 |
Definition at line 70 of file moc_predefs.h.
#define __FLT128_MIN_EXP__ (-16381) |
Definition at line 71 of file moc_predefs.h.
#define __WINT_MIN__ 0U |
Definition at line 72 of file moc_predefs.h.
#define __FLT128_MIN_10_EXP__ (-4931) |
Definition at line 73 of file moc_predefs.h.
#define __FLT32X_IS_IEC_60559__ 2 |
Definition at line 74 of file moc_predefs.h.
#define __INT_LEAST16_WIDTH__ 16 |
Definition at line 75 of file moc_predefs.h.
#define __SCHAR_MAX__ 0x7f |
Definition at line 76 of file moc_predefs.h.
#define __FLT128_MANT_DIG__ 113 |
Definition at line 77 of file moc_predefs.h.
#define __WCHAR_MIN__ (-__WCHAR_MAX__ - 1) |
Definition at line 78 of file moc_predefs.h.
#define __INT64_C | ( | c | ) | c ## L |
Definition at line 79 of file moc_predefs.h.
#define __GCC_ATOMIC_POINTER_LOCK_FREE 2 |
Definition at line 80 of file moc_predefs.h.
#define __FLT32X_MANT_DIG__ 53 |
Definition at line 81 of file moc_predefs.h.
#define __GCC_ATOMIC_CHAR16_T_LOCK_FREE 2 |
Definition at line 82 of file moc_predefs.h.
#define __cpp_aligned_new 201606L |
Definition at line 83 of file moc_predefs.h.
#define __USER_LABEL_PREFIX__ |
Definition at line 84 of file moc_predefs.h.
#define __FLT32_MAX_10_EXP__ 38 |
Definition at line 85 of file moc_predefs.h.
#define __FLT64X_EPSILON__ 1.08420217248550443400745280086994171e-19F64x |
Definition at line 86 of file moc_predefs.h.
#define __STDC_HOSTED__ 1 |
Definition at line 87 of file moc_predefs.h.
#define __DEC64_MIN_EXP__ (-382) |
Definition at line 88 of file moc_predefs.h.
#define __cpp_decltype_auto 201304L |
Definition at line 89 of file moc_predefs.h.
#define __DBL_DIG__ 15 |
Definition at line 90 of file moc_predefs.h.
#define __FLT32_DIG__ 6 |
Definition at line 91 of file moc_predefs.h.
#define NodeEditor_EXPORTS 1 |
Definition at line 92 of file moc_predefs.h.
#define __FLT_EPSILON__ 1.19209289550781250000000000000000000e-7F |
Definition at line 93 of file moc_predefs.h.
#define __GXX_WEAK__ 1 |
Definition at line 94 of file moc_predefs.h.
#define __SHRT_WIDTH__ 16 |
Definition at line 95 of file moc_predefs.h.
#define __FLT32_IS_IEC_60559__ 2 |
Definition at line 96 of file moc_predefs.h.
#define __LDBL_MIN__ 3.36210314311209350626267781732175260e-4932L |
Definition at line 97 of file moc_predefs.h.
#define __DBL_IS_IEC_60559__ 2 |
Definition at line 98 of file moc_predefs.h.
#define __DEC32_MAX__ 9.999999E96DF |
Definition at line 99 of file moc_predefs.h.
#define __cpp_threadsafe_static_init 200806L |
Definition at line 100 of file moc_predefs.h.
#define __cpp_enumerator_attributes 201411L |
Definition at line 101 of file moc_predefs.h.
#define __FLT64X_DENORM_MIN__ 3.64519953188247460252840593361941982e-4951F64x |
Definition at line 102 of file moc_predefs.h.
#define __FLT32X_HAS_INFINITY__ 1 |
Definition at line 103 of file moc_predefs.h.
#define __INT32_MAX__ 0x7fffffff |
Definition at line 104 of file moc_predefs.h.
#define __unix__ 1 |
Definition at line 105 of file moc_predefs.h.
#define __INT_WIDTH__ 32 |
Definition at line 106 of file moc_predefs.h.
#define __SIZEOF_LONG__ 8 |
Definition at line 107 of file moc_predefs.h.
#define __STDC_IEC_559__ 1 |
Definition at line 108 of file moc_predefs.h.
#define __STDC_ISO_10646__ 201706L |
Definition at line 109 of file moc_predefs.h.
#define __UINT16_C | ( | c | ) | c |
Definition at line 110 of file moc_predefs.h.
#define __DECIMAL_DIG__ 21 |
Definition at line 111 of file moc_predefs.h.
#define __STDC_IEC_559_COMPLEX__ 1 |
Definition at line 112 of file moc_predefs.h.
#define __FLT64_EPSILON__ 2.22044604925031308084726333618164062e-16F64 |
Definition at line 113 of file moc_predefs.h.
#define __gnu_linux__ 1 |
Definition at line 114 of file moc_predefs.h.
#define __INT16_MAX__ 0x7fff |
Definition at line 115 of file moc_predefs.h.
#define __FLT64_MIN_EXP__ (-1021) |
Definition at line 116 of file moc_predefs.h.
#define __FLT64X_MIN_10_EXP__ (-4931) |
Definition at line 117 of file moc_predefs.h.
#define __LDBL_HAS_QUIET_NAN__ 1 |
Definition at line 118 of file moc_predefs.h.
#define __FLT64_MANT_DIG__ 53 |
Definition at line 119 of file moc_predefs.h.
#define __FLT64X_MANT_DIG__ 64 |
Definition at line 120 of file moc_predefs.h.
#define __GNUC__ 11 |
Definition at line 121 of file moc_predefs.h.
#define __GXX_RTTI 1 |
Definition at line 122 of file moc_predefs.h.
#define __MMX__ 1 |
Definition at line 123 of file moc_predefs.h.
#define __FLT_HAS_DENORM__ 1 |
Definition at line 124 of file moc_predefs.h.
#define __SIZEOF_LONG_DOUBLE__ 16 |
Definition at line 125 of file moc_predefs.h.
#define __BIGGEST_ALIGNMENT__ 16 |
Definition at line 126 of file moc_predefs.h.
#define __STDC_UTF_16__ 1 |
Definition at line 127 of file moc_predefs.h.
#define __FLT64_MAX_10_EXP__ 308 |
Definition at line 128 of file moc_predefs.h.
#define __cpp_delegating_constructors 200604L |
Definition at line 129 of file moc_predefs.h.
#define __FLT32_HAS_INFINITY__ 1 |
Definition at line 130 of file moc_predefs.h.
#define __DBL_MAX__ double(1.79769313486231570814527423731704357e+308L) |
Definition at line 131 of file moc_predefs.h.
#define __cpp_raw_strings 200710L |
Definition at line 132 of file moc_predefs.h.
#define __INT_FAST32_MAX__ 0x7fffffffffffffffL |
Definition at line 133 of file moc_predefs.h.
#define __DBL_HAS_INFINITY__ 1 |
Definition at line 134 of file moc_predefs.h.
#define __SIZEOF_FLOAT__ 4 |
Definition at line 135 of file moc_predefs.h.
#define __HAVE_SPECULATION_SAFE_VALUE 1 |
Definition at line 136 of file moc_predefs.h.
#define __cpp_fold_expressions 201603L |
Definition at line 137 of file moc_predefs.h.
#define __DEC32_MIN_EXP__ (-94) |
Definition at line 138 of file moc_predefs.h.
#define __INTPTR_WIDTH__ 64 |
Definition at line 139 of file moc_predefs.h.
#define __FLT64X_HAS_INFINITY__ 1 |
Definition at line 140 of file moc_predefs.h.
#define __UINT_LEAST32_MAX__ 0xffffffffU |
Definition at line 141 of file moc_predefs.h.
#define __FLT32X_HAS_DENORM__ 1 |
Definition at line 142 of file moc_predefs.h.
#define __INT_FAST16_TYPE__ long int |
Definition at line 143 of file moc_predefs.h.
#define __MMX_WITH_SSE__ 1 |
Definition at line 144 of file moc_predefs.h.
#define __LDBL_HAS_DENORM__ 1 |
Definition at line 145 of file moc_predefs.h.
#define QT_WIDGETS_LIB 1 |
Definition at line 146 of file moc_predefs.h.
#define __cplusplus 201703L |
Definition at line 147 of file moc_predefs.h.
#define __cpp_ref_qualifiers 200710L |
Definition at line 148 of file moc_predefs.h.
#define __DEC32_MIN__ 1E-95DF |
Definition at line 149 of file moc_predefs.h.
#define __DEPRECATED 1 |
Definition at line 150 of file moc_predefs.h.
#define __cpp_rvalue_references 200610L |
Definition at line 151 of file moc_predefs.h.
#define __DBL_MAX_EXP__ 1024 |
Definition at line 152 of file moc_predefs.h.
#define __WCHAR_WIDTH__ 32 |
Definition at line 153 of file moc_predefs.h.
#define __FLT32_MAX__ 3.40282346638528859811704183484516925e+38F32 |
Definition at line 154 of file moc_predefs.h.
#define __DEC128_EPSILON__ 1E-33DL |
Definition at line 155 of file moc_predefs.h.
#define __SSE2_MATH__ 1 |
Definition at line 156 of file moc_predefs.h.
#define __ATOMIC_HLE_RELEASE 131072 |
Definition at line 157 of file moc_predefs.h.
#define __PTRDIFF_MAX__ 0x7fffffffffffffffL |
Definition at line 158 of file moc_predefs.h.
#define __amd64 1 |
Definition at line 159 of file moc_predefs.h.
#define __ATOMIC_HLE_ACQUIRE 65536 |
Definition at line 160 of file moc_predefs.h.
#define __GNUG__ 11 |
Definition at line 161 of file moc_predefs.h.
#define __LONG_LONG_MAX__ 0x7fffffffffffffffLL |
Definition at line 162 of file moc_predefs.h.
#define __SIZEOF_SIZE_T__ 8 |
Definition at line 163 of file moc_predefs.h.
#define __cpp_nsdmi 200809L |
Definition at line 164 of file moc_predefs.h.
#define __FLT64X_MIN_EXP__ (-16381) |
Definition at line 165 of file moc_predefs.h.
#define __SIZEOF_WINT_T__ 4 |
Definition at line 166 of file moc_predefs.h.
#define __LONG_LONG_WIDTH__ 64 |
Definition at line 167 of file moc_predefs.h.
#define __cpp_initializer_lists 200806L |
Definition at line 168 of file moc_predefs.h.
#define __FLT32_MAX_EXP__ 128 |
Definition at line 169 of file moc_predefs.h.
#define ABI_ID "ELF" |
Definition at line 170 of file moc_predefs.h.
#define __cpp_hex_float 201603L |
Definition at line 171 of file moc_predefs.h.
#define __GXX_ABI_VERSION 1016 |
Definition at line 172 of file moc_predefs.h.
#define __FLT128_HAS_INFINITY__ 1 |
Definition at line 173 of file moc_predefs.h.
#define kiss_fft_scalar double |
Definition at line 174 of file moc_predefs.h.
#define __FLT_MIN_EXP__ (-125) |
Definition at line 175 of file moc_predefs.h.
#define __GCC_HAVE_DWARF2_CFI_ASM 1 |
Definition at line 176 of file moc_predefs.h.
#define __x86_64 1 |
Definition at line 177 of file moc_predefs.h.
#define __cpp_lambdas 200907L |
Definition at line 178 of file moc_predefs.h.
#define __INT_FAST64_TYPE__ long int |
Definition at line 179 of file moc_predefs.h.
#define __FLT64_DENORM_MIN__ 4.94065645841246544176568792868221372e-324F64 |
Definition at line 180 of file moc_predefs.h.
#define PROTOBUF_USE_DLLS 1 |
Definition at line 181 of file moc_predefs.h.
#define __cpp_template_auto 201606L |
Definition at line 182 of file moc_predefs.h.
#define __DBL_MIN__ double(2.22507385850720138309023271733240406e-308L) |
Definition at line 183 of file moc_predefs.h.
#define __FLT128_EPSILON__ 1.92592994438723585305597794258492732e-34F128 |
Definition at line 184 of file moc_predefs.h.
#define __FLT64X_NORM_MAX__ 1.18973149535723176502126385303097021e+4932F64x |
Definition at line 185 of file moc_predefs.h.
#define __SIZEOF_POINTER__ 8 |
Definition at line 186 of file moc_predefs.h.
#define __LP64__ 1 |
Definition at line 187 of file moc_predefs.h.
#define __DBL_HAS_QUIET_NAN__ 1 |
Definition at line 188 of file moc_predefs.h.
#define __FLT32X_EPSILON__ 2.22044604925031308084726333618164062e-16F32x |
Definition at line 189 of file moc_predefs.h.
#define __DECIMAL_BID_FORMAT__ 1 |
Definition at line 190 of file moc_predefs.h.
#define __FLT64_MIN_10_EXP__ (-307) |
Definition at line 191 of file moc_predefs.h.
#define __FLT64X_DECIMAL_DIG__ 21 |
Definition at line 192 of file moc_predefs.h.
#define __DEC128_MIN__ 1E-6143DL |
Definition at line 193 of file moc_predefs.h.
#define __REGISTER_PREFIX__ |
Definition at line 194 of file moc_predefs.h.
#define __UINT16_MAX__ 0xffff |
Definition at line 195 of file moc_predefs.h.
#define __LDBL_HAS_INFINITY__ 1 |
Definition at line 196 of file moc_predefs.h.
#define __FLT32_MIN__ 1.17549435082228750796873653722224568e-38F32 |
Definition at line 197 of file moc_predefs.h.
#define __UINT8_TYPE__ unsigned char |
Definition at line 198 of file moc_predefs.h.
#define __FLT_DIG__ 6 |
Definition at line 199 of file moc_predefs.h.
#define __NO_INLINE__ 1 |
Definition at line 200 of file moc_predefs.h.
#define __DEC_EVAL_METHOD__ 2 |
Definition at line 201 of file moc_predefs.h.
#define __DEC128_MAX__ 9.999999999999999999999999999999999E6144DL |
Definition at line 202 of file moc_predefs.h.
#define QT_NO_KEYWORDS 1 |
Definition at line 203 of file moc_predefs.h.
#define __FLT_MANT_DIG__ 24 |
Definition at line 204 of file moc_predefs.h.
#define __LDBL_DECIMAL_DIG__ 21 |
Definition at line 205 of file moc_predefs.h.
#define __VERSION__ "11.3.1 20220421 (Red Hat 11.3.1-3)" |
Definition at line 206 of file moc_predefs.h.
#define __UINT64_C | ( | c | ) | c ## UL |
Definition at line 207 of file moc_predefs.h.
#define __cpp_unicode_characters 201411L |
Definition at line 208 of file moc_predefs.h.
#define _STDC_PREDEF_H 1 |
Definition at line 209 of file moc_predefs.h.
#define __INT_LEAST32_MAX__ 0x7fffffff |
Definition at line 210 of file moc_predefs.h.
#define __GCC_ATOMIC_INT_LOCK_FREE 2 |
Definition at line 211 of file moc_predefs.h.
#define __FLT128_MAX_EXP__ 16384 |
Definition at line 212 of file moc_predefs.h.
#define __FLT32_MANT_DIG__ 24 |
Definition at line 213 of file moc_predefs.h.
#define __FLOAT_WORD_ORDER__ __ORDER_LITTLE_ENDIAN__ |
Definition at line 214 of file moc_predefs.h.
#define SIZEOF_DPTR (sizeof(void*)) |
Definition at line 215 of file moc_predefs.h.
#define __cpp_aggregate_bases 201603L |
Definition at line 216 of file moc_predefs.h.
#define __FLT128_HAS_DENORM__ 1 |
Definition at line 217 of file moc_predefs.h.
#define __FLT32_DECIMAL_DIG__ 9 |
Definition at line 218 of file moc_predefs.h.
#define __FLT128_DIG__ 33 |
Definition at line 219 of file moc_predefs.h.
#define __INT32_C | ( | c | ) | c |
Definition at line 220 of file moc_predefs.h.
#define __DEC64_EPSILON__ 1E-15DD |
Definition at line 221 of file moc_predefs.h.
#define __ORDER_PDP_ENDIAN__ 3412 |
Definition at line 222 of file moc_predefs.h.
#define __DEC128_MIN_EXP__ (-6142) |
Definition at line 223 of file moc_predefs.h.
#define __INT_FAST32_TYPE__ long int |
Definition at line 224 of file moc_predefs.h.
#define __UINT_LEAST16_TYPE__ short unsigned int |
Definition at line 225 of file moc_predefs.h.
#define unix 1 |
Definition at line 226 of file moc_predefs.h.
#define __DBL_HAS_DENORM__ 1 |
Definition at line 227 of file moc_predefs.h.
#define __cpp_rtti 199711L |
Definition at line 228 of file moc_predefs.h.
#define __SIZE_TYPE__ long unsigned int |
Definition at line 229 of file moc_predefs.h.
#define __UINT64_MAX__ 0xffffffffffffffffUL |
Definition at line 230 of file moc_predefs.h.
#define __FLT_IS_IEC_60559__ 2 |
Definition at line 231 of file moc_predefs.h.
#define __GNUC_WIDE_EXECUTION_CHARSET_NAME "UTF-32LE" |
Definition at line 232 of file moc_predefs.h.
#define __FLT64X_DIG__ 18 |
Definition at line 233 of file moc_predefs.h.
#define __INT8_TYPE__ signed char |
Definition at line 234 of file moc_predefs.h.
#define __cpp_digit_separators 201309L |
Definition at line 235 of file moc_predefs.h.
#define __ELF__ 1 |
Definition at line 236 of file moc_predefs.h.
#define __GCC_ASM_FLAG_OUTPUTS__ 1 |
Definition at line 237 of file moc_predefs.h.
#define __UINT32_TYPE__ unsigned int |
Definition at line 238 of file moc_predefs.h.
#define __FLT_RADIX__ 2 |
Definition at line 239 of file moc_predefs.h.
#define __INT_LEAST16_TYPE__ short int |
Definition at line 240 of file moc_predefs.h.
#define __LDBL_EPSILON__ 1.08420217248550443400745280086994171e-19L |
Definition at line 241 of file moc_predefs.h.
#define __UINTMAX_C | ( | c | ) | c ## UL |
Definition at line 242 of file moc_predefs.h.
#define __GNUC_RH_RELEASE__ 3 |
Definition at line 243 of file moc_predefs.h.
#define __GLIBCXX_BITSIZE_INT_N_0 128 |
Definition at line 244 of file moc_predefs.h.
#define __k8 1 |
Definition at line 245 of file moc_predefs.h.
#define __FLT32X_MIN__ 2.22507385850720138309023271733240406e-308F32x |
Definition at line 246 of file moc_predefs.h.
#define __SIG_ATOMIC_MAX__ 0x7fffffff |
Definition at line 247 of file moc_predefs.h.
#define __GCC_ATOMIC_WCHAR_T_LOCK_FREE 2 |
Definition at line 248 of file moc_predefs.h.
#define __SIZEOF_PTRDIFF_T__ 8 |
Definition at line 249 of file moc_predefs.h.
#define __LDBL_DIG__ 18 |
Definition at line 250 of file moc_predefs.h.
#define __FLT64_IS_IEC_60559__ 2 |
Definition at line 251 of file moc_predefs.h.
#define __x86_64__ 1 |
Definition at line 252 of file moc_predefs.h.
#define __FLT32X_MIN_EXP__ (-1021) |
Definition at line 253 of file moc_predefs.h.
#define __DEC32_SUBNORMAL_MIN__ 0.000001E-95DF |
Definition at line 254 of file moc_predefs.h.
#define __INT_FAST16_MAX__ 0x7fffffffffffffffL |
Definition at line 255 of file moc_predefs.h.
#define __FLT64_DIG__ 15 |
Definition at line 256 of file moc_predefs.h.
#define __UINT_FAST32_MAX__ 0xffffffffffffffffUL |
Definition at line 257 of file moc_predefs.h.
#define __UINT_LEAST64_TYPE__ long unsigned int |
Definition at line 258 of file moc_predefs.h.
#define __FLT_HAS_QUIET_NAN__ 1 |
Definition at line 259 of file moc_predefs.h.
#define __FLT_MAX_10_EXP__ 38 |
Definition at line 260 of file moc_predefs.h.
#define __LONG_MAX__ 0x7fffffffffffffffL |
Definition at line 261 of file moc_predefs.h.
#define __FLT64X_HAS_DENORM__ 1 |
Definition at line 262 of file moc_predefs.h.
#define __DEC128_SUBNORMAL_MIN__ 0.000000000000000000000000000000001E-6143DL |
Definition at line 263 of file moc_predefs.h.
#define __FLT_HAS_INFINITY__ 1 |
Definition at line 264 of file moc_predefs.h.
#define __GNUC_EXECUTION_CHARSET_NAME "UTF-8" |
Definition at line 265 of file moc_predefs.h.
#define __cpp_unicode_literals 200710L |
Definition at line 266 of file moc_predefs.h.
#define __UINT_FAST16_TYPE__ long unsigned int |
Definition at line 267 of file moc_predefs.h.
#define __DEC64_MAX__ 9.999999999999999E384DD |
Definition at line 268 of file moc_predefs.h.
#define __INT_FAST32_WIDTH__ 64 |
Definition at line 269 of file moc_predefs.h.
#define __CHAR16_TYPE__ short unsigned int |
Definition at line 270 of file moc_predefs.h.
#define __PRAGMA_REDEFINE_EXTNAME 1 |
Definition at line 271 of file moc_predefs.h.
#define __SIZE_WIDTH__ 64 |
Definition at line 272 of file moc_predefs.h.
#define __SEG_FS 1 |
Definition at line 273 of file moc_predefs.h.
#define __INT_LEAST16_MAX__ 0x7fff |
Definition at line 274 of file moc_predefs.h.
#define __DEC64_MANT_DIG__ 16 |
Definition at line 275 of file moc_predefs.h.
#define __INT64_MAX__ 0x7fffffffffffffffL |
Definition at line 276 of file moc_predefs.h.
#define __SEG_GS 1 |
Definition at line 277 of file moc_predefs.h.
#define __FLT32_DENORM_MIN__ 1.40129846432481707092372958328991613e-45F32 |
Definition at line 278 of file moc_predefs.h.
#define __SIG_ATOMIC_WIDTH__ 32 |
Definition at line 279 of file moc_predefs.h.
#define __INT_LEAST64_TYPE__ long int |
Definition at line 280 of file moc_predefs.h.
#define __INT16_TYPE__ short int |
Definition at line 281 of file moc_predefs.h.
#define __INT_LEAST8_TYPE__ signed char |
Definition at line 282 of file moc_predefs.h.
#define __cpp_structured_bindings 201606L |
Definition at line 283 of file moc_predefs.h.
#define __SIZEOF_INT__ 4 |
Definition at line 284 of file moc_predefs.h.
#define __DEC32_MAX_EXP__ 97 |
Definition at line 285 of file moc_predefs.h.
#define __INT_FAST8_MAX__ 0x7f |
Definition at line 286 of file moc_predefs.h.
#define __FLT128_MAX__ 1.18973149535723176508575932662800702e+4932F128 |
Definition at line 287 of file moc_predefs.h.
#define __INTPTR_MAX__ 0x7fffffffffffffffL |
Definition at line 288 of file moc_predefs.h.
#define __cpp_sized_deallocation 201309L |
Definition at line 289 of file moc_predefs.h.
#define __cpp_guaranteed_copy_elision 201606L |
Definition at line 290 of file moc_predefs.h.
#define linux 1 |
Definition at line 291 of file moc_predefs.h.
#define __FLT64_HAS_QUIET_NAN__ 1 |
Definition at line 292 of file moc_predefs.h.
#define __FLT32_MIN_10_EXP__ (-37) |
Definition at line 293 of file moc_predefs.h.
#define __EXCEPTIONS 1 |
Definition at line 294 of file moc_predefs.h.
#define __PTRDIFF_WIDTH__ 64 |
Definition at line 295 of file moc_predefs.h.
#define __LDBL_MANT_DIG__ 64 |
Definition at line 296 of file moc_predefs.h.
#define __cpp_range_based_for 201603L |
Definition at line 297 of file moc_predefs.h.
#define FMT_SHARED 1 |
Definition at line 298 of file moc_predefs.h.
#define __FLT64_HAS_INFINITY__ 1 |
Definition at line 299 of file moc_predefs.h.
#define __FLT64X_MAX__ 1.18973149535723176502126385303097021e+4932F64x |
Definition at line 300 of file moc_predefs.h.
#define __STDCPP_DEFAULT_NEW_ALIGNMENT__ 16 |
Definition at line 301 of file moc_predefs.h.
#define __SIG_ATOMIC_MIN__ (-__SIG_ATOMIC_MAX__ - 1) |
Definition at line 302 of file moc_predefs.h.
#define __code_model_small__ 1 |
Definition at line 303 of file moc_predefs.h.
#define __GCC_ATOMIC_LONG_LOCK_FREE 2 |
Definition at line 304 of file moc_predefs.h.
#define __cpp_nontype_template_args 201411L |
Definition at line 305 of file moc_predefs.h.
#define __DEC32_MANT_DIG__ 7 |
Definition at line 306 of file moc_predefs.h.
#define __cpp_return_type_deduction 201304L |
Definition at line 307 of file moc_predefs.h.
#define __k8__ 1 |
Definition at line 308 of file moc_predefs.h.
#define __INTPTR_TYPE__ long int |
Definition at line 309 of file moc_predefs.h.
#define __UINT16_TYPE__ short unsigned int |
Definition at line 310 of file moc_predefs.h.
#define __WCHAR_TYPE__ int |
Definition at line 311 of file moc_predefs.h.
#define __UINTPTR_MAX__ 0xffffffffffffffffUL |
Definition at line 312 of file moc_predefs.h.
#define __INT_FAST64_WIDTH__ 64 |
Definition at line 313 of file moc_predefs.h.
#define __cpp_decltype 200707L |
Definition at line 314 of file moc_predefs.h.
#define __INT_FAST64_MAX__ 0x7fffffffffffffffL |
Definition at line 315 of file moc_predefs.h.
#define __GCC_ATOMIC_TEST_AND_SET_TRUEVAL 1 |
Definition at line 316 of file moc_predefs.h.
#define __FLT_NORM_MAX__ 3.40282346638528859811704183484516925e+38F |
Definition at line 317 of file moc_predefs.h.
#define __FLT64X_MAX_EXP__ 16384 |
Definition at line 318 of file moc_predefs.h.
#define __UINT_FAST64_TYPE__ long unsigned int |
Definition at line 319 of file moc_predefs.h.
#define __cpp_inline_variables 201606L |
Definition at line 320 of file moc_predefs.h.
#define __INT_MAX__ 0x7fffffff |
Definition at line 321 of file moc_predefs.h.
#define __linux__ 1 |
Definition at line 322 of file moc_predefs.h.
#define __INT64_TYPE__ long int |
Definition at line 323 of file moc_predefs.h.
#define __FLT_MAX_EXP__ 128 |
Definition at line 324 of file moc_predefs.h.
#define __ORDER_BIG_ENDIAN__ 4321 |
Definition at line 325 of file moc_predefs.h.
#define __DBL_MANT_DIG__ 53 |
Definition at line 326 of file moc_predefs.h.
#define __cpp_inheriting_constructors 201511L |
Definition at line 327 of file moc_predefs.h.
#define QT_CORE_LIB 1 |
Definition at line 328 of file moc_predefs.h.
#define __SIZEOF_FLOAT128__ 16 |
Definition at line 329 of file moc_predefs.h.
#define __INT_LEAST64_MAX__ 0x7fffffffffffffffL |
Definition at line 330 of file moc_predefs.h.
#define __DEC64_MIN__ 1E-383DD |
Definition at line 331 of file moc_predefs.h.
#define __WINT_TYPE__ unsigned int |
Definition at line 332 of file moc_predefs.h.
#define __UINT_LEAST32_TYPE__ unsigned int |
Definition at line 333 of file moc_predefs.h.
#define __SIZEOF_SHORT__ 2 |
Definition at line 334 of file moc_predefs.h.
#define __FLT32_NORM_MAX__ 3.40282346638528859811704183484516925e+38F32 |
Definition at line 335 of file moc_predefs.h.
#define __SSE__ 1 |
Definition at line 336 of file moc_predefs.h.
#define __LDBL_MIN_EXP__ (-16381) |
Definition at line 337 of file moc_predefs.h.
#define __FLT64_MAX__ 1.79769313486231570814527423731704357e+308F64 |
Definition at line 338 of file moc_predefs.h.
#define __amd64__ 1 |
Definition at line 339 of file moc_predefs.h.
#define __WINT_WIDTH__ 32 |
Definition at line 340 of file moc_predefs.h.
#define __INT_LEAST64_WIDTH__ 64 |
Definition at line 341 of file moc_predefs.h.
#define __LDBL_MAX_EXP__ 16384 |
Definition at line 342 of file moc_predefs.h.
#define __FLT32X_MAX_10_EXP__ 308 |
Definition at line 343 of file moc_predefs.h.
#define __SIZEOF_INT128__ 16 |
Definition at line 344 of file moc_predefs.h.
#define __FLT64X_IS_IEC_60559__ 2 |
Definition at line 345 of file moc_predefs.h.
#define __LDBL_MAX_10_EXP__ 4932 |
Definition at line 346 of file moc_predefs.h.
#define __ATOMIC_RELAXED 0 |
Definition at line 347 of file moc_predefs.h.
#define __DBL_EPSILON__ double(2.22044604925031308084726333618164062e-16L) |
Definition at line 348 of file moc_predefs.h.
#define __FLT128_MIN__ 3.36210314311209350626267781732175260e-4932F128 |
Definition at line 349 of file moc_predefs.h.
#define _LP64 1 |
Definition at line 350 of file moc_predefs.h.
#define __UINT8_C | ( | c | ) | c |
Definition at line 351 of file moc_predefs.h.
#define __FLT64_MAX_EXP__ 1024 |
Definition at line 352 of file moc_predefs.h.
#define __INT_LEAST32_TYPE__ int |
Definition at line 353 of file moc_predefs.h.
#define __SIZEOF_WCHAR_T__ 4 |
Definition at line 354 of file moc_predefs.h.
#define __GNUC_PATCHLEVEL__ 1 |
Definition at line 355 of file moc_predefs.h.
#define __FLT128_NORM_MAX__ 1.18973149535723176508575932662800702e+4932F128 |
Definition at line 356 of file moc_predefs.h.
#define __FLT64_NORM_MAX__ 1.79769313486231570814527423731704357e+308F64 |
Definition at line 357 of file moc_predefs.h.
#define __FLT128_HAS_QUIET_NAN__ 1 |
Definition at line 358 of file moc_predefs.h.
#define __INTMAX_MAX__ 0x7fffffffffffffffL |
Definition at line 359 of file moc_predefs.h.
#define __INT_FAST8_TYPE__ signed char |
Definition at line 360 of file moc_predefs.h.
#define __cpp_namespace_attributes 201411L |
Definition at line 361 of file moc_predefs.h.
#define __FLT64X_MIN__ 3.36210314311209350626267781732175260e-4932F64x |
Definition at line 362 of file moc_predefs.h.
#define __STDCPP_THREADS__ 1 |
Definition at line 363 of file moc_predefs.h.
#define __GNUC_STDC_INLINE__ 1 |
Definition at line 364 of file moc_predefs.h.
#define __FLT64_HAS_DENORM__ 1 |
Definition at line 365 of file moc_predefs.h.
#define __FLT32_EPSILON__ 1.19209289550781250000000000000000000e-7F32 |
Definition at line 366 of file moc_predefs.h.
#define __DBL_DECIMAL_DIG__ 17 |
Definition at line 367 of file moc_predefs.h.
#define __STDC_UTF_32__ 1 |
Definition at line 368 of file moc_predefs.h.
#define __INT_FAST8_WIDTH__ 8 |
Definition at line 369 of file moc_predefs.h.
#define __FXSR__ 1 |
Definition at line 370 of file moc_predefs.h.
#define __FLT32X_MAX__ 1.79769313486231570814527423731704357e+308F32x |
Definition at line 371 of file moc_predefs.h.
#define __DBL_NORM_MAX__ double(1.79769313486231570814527423731704357e+308L) |
Definition at line 372 of file moc_predefs.h.
#define __BYTE_ORDER__ __ORDER_LITTLE_ENDIAN__ |
Definition at line 373 of file moc_predefs.h.
#define __INTMAX_WIDTH__ 64 |
Definition at line 374 of file moc_predefs.h.
#define __cpp_runtime_arrays 198712L |
Definition at line 375 of file moc_predefs.h.
#define __UINT64_TYPE__ long unsigned int |
Definition at line 376 of file moc_predefs.h.
#define __UINT32_C | ( | c | ) | c ## U |
Definition at line 377 of file moc_predefs.h.
#define __cpp_alias_templates 200704L |
Definition at line 378 of file moc_predefs.h.
#define __FLT_DENORM_MIN__ 1.40129846432481707092372958328991613e-45F |
Definition at line 379 of file moc_predefs.h.
#define __FLT128_IS_IEC_60559__ 2 |
Definition at line 380 of file moc_predefs.h.
#define __INT8_MAX__ 0x7f |
Definition at line 381 of file moc_predefs.h.
#define __LONG_WIDTH__ 64 |
Definition at line 382 of file moc_predefs.h.
#define __UINT_FAST32_TYPE__ long unsigned int |
Definition at line 383 of file moc_predefs.h.
#define __FLT32X_NORM_MAX__ 1.79769313486231570814527423731704357e+308F32x |
Definition at line 384 of file moc_predefs.h.
#define __CHAR32_TYPE__ unsigned int |
Definition at line 385 of file moc_predefs.h.
#define __FLT_MAX__ 3.40282346638528859811704183484516925e+38F |
Definition at line 386 of file moc_predefs.h.
#define __cpp_constexpr 201603L |
Definition at line 387 of file moc_predefs.h.
#define __SSE2__ 1 |
Definition at line 388 of file moc_predefs.h.
#define __cpp_deduction_guides 201703L |
Definition at line 389 of file moc_predefs.h.
#define __INT32_TYPE__ int |
Definition at line 390 of file moc_predefs.h.
#define __SIZEOF_DOUBLE__ 8 |
Definition at line 391 of file moc_predefs.h.
#define __cpp_exceptions 199711L |
Definition at line 392 of file moc_predefs.h.
#define __FLT_MIN_10_EXP__ (-37) |
Definition at line 393 of file moc_predefs.h.
#define __FLT64_MIN__ 2.22507385850720138309023271733240406e-308F64 |
Definition at line 394 of file moc_predefs.h.
#define __INT_LEAST32_WIDTH__ 32 |
Definition at line 395 of file moc_predefs.h.
#define __INTMAX_TYPE__ long int |
Definition at line 396 of file moc_predefs.h.
#define __DEC128_MAX_EXP__ 6145 |
Definition at line 397 of file moc_predefs.h.
#define __FLT32X_HAS_QUIET_NAN__ 1 |
Definition at line 398 of file moc_predefs.h.
#define __ATOMIC_CONSUME 1 |
Definition at line 399 of file moc_predefs.h.
#define __GNUC_MINOR__ 3 |
Definition at line 400 of file moc_predefs.h.
#define __GLIBCXX_TYPE_INT_N_0 __int128 |
Definition at line 401 of file moc_predefs.h.
#define __INT_FAST16_WIDTH__ 64 |
Definition at line 402 of file moc_predefs.h.
#define __UINTMAX_MAX__ 0xffffffffffffffffUL |
Definition at line 403 of file moc_predefs.h.
#define __FLT32X_DENORM_MIN__ 4.94065645841246544176568792868221372e-324F32x |
Definition at line 404 of file moc_predefs.h.
#define __cpp_template_template_args 201611L |
Definition at line 405 of file moc_predefs.h.
#define __DBL_MAX_10_EXP__ 308 |
Definition at line 406 of file moc_predefs.h.
#define __LDBL_DENORM_MIN__ 3.64519953188247460252840593361941982e-4951L |
Definition at line 407 of file moc_predefs.h.
#define __INT16_C | ( | c | ) | c |
Definition at line 408 of file moc_predefs.h.
#define __STDC__ 1 |
Definition at line 409 of file moc_predefs.h.
#define __FLT32X_DIG__ 15 |
Definition at line 410 of file moc_predefs.h.
#define __PTRDIFF_TYPE__ long int |
Definition at line 411 of file moc_predefs.h.
#define __ATOMIC_SEQ_CST 5 |
Definition at line 412 of file moc_predefs.h.
#define __FLT32X_MIN_10_EXP__ (-307) |
Definition at line 413 of file moc_predefs.h.
#define __UINTPTR_TYPE__ long unsigned int |
Definition at line 414 of file moc_predefs.h.
#define __DEC64_SUBNORMAL_MIN__ 0.000000000000001E-383DD |
Definition at line 415 of file moc_predefs.h.
#define __DEC128_MANT_DIG__ 34 |
Definition at line 416 of file moc_predefs.h.
#define __LDBL_MIN_10_EXP__ (-4931) |
Definition at line 417 of file moc_predefs.h.
#define __cpp_generic_lambdas 201304L |
Definition at line 418 of file moc_predefs.h.
#define __SSE_MATH__ 1 |
Definition at line 419 of file moc_predefs.h.
#define __SIZEOF_LONG_LONG__ 8 |
Definition at line 420 of file moc_predefs.h.
#define __cpp_user_defined_literals 200809L |
Definition at line 421 of file moc_predefs.h.
#define __FLT128_DECIMAL_DIG__ 36 |
Definition at line 422 of file moc_predefs.h.
#define __GCC_ATOMIC_LLONG_LOCK_FREE 2 |
Definition at line 423 of file moc_predefs.h.
#define __FLT32_HAS_QUIET_NAN__ 1 |
Definition at line 424 of file moc_predefs.h.
#define __FLT_DECIMAL_DIG__ 9 |
Definition at line 425 of file moc_predefs.h.
#define __UINT_FAST16_MAX__ 0xffffffffffffffffUL |
Definition at line 426 of file moc_predefs.h.
#define __LDBL_NORM_MAX__ 1.18973149535723176502126385303097021e+4932L |
Definition at line 427 of file moc_predefs.h.
#define __GCC_ATOMIC_SHORT_LOCK_FREE 2 |
Definition at line 428 of file moc_predefs.h.
#define __UINT_FAST8_TYPE__ unsigned char |
Definition at line 429 of file moc_predefs.h.
#define _GNU_SOURCE 1 |
Definition at line 430 of file moc_predefs.h.
#define __cpp_init_captures 201304L |
Definition at line 431 of file moc_predefs.h.
#define __ATOMIC_ACQ_REL 4 |
Definition at line 432 of file moc_predefs.h.
#define __ATOMIC_RELEASE 3 |
Definition at line 433 of file moc_predefs.h.
