2 set(_vtk_testing_python_exe
"$<TARGET_FILE:ParaView::pvpython>")
3 set(_vtk_test_python_args --dr ${paraview_python_args})
4 vtk_add_test_python(${ARGN})
8 set(_vtk_testing_python_exe
"$<TARGET_FILE:ParaView::pvbatch>")
9 set(_vtk_test_python_args --dr ${paraview_pvbatch_args})
10 set(vtk_test_prefix
"Batch-${vtk_test_prefix}")
11 vtk_add_test_python(${ARGN})
15 set(_vtk_testing_python_exe "$<TARGET_FILE:ParaView::pvbatch>")
16 set(_vtk_test_python_args --dr ${paraview_pvbatch_args})
17 set(vtk_test_prefix
18 vtk_add_test_python_mpi(${ARGN})
22 if (NOT (TARGET pvserver AND TARGET pvpython))
25 set(_vtk_testing_python_exe "$<TARGET_FILE:ParaView::smTestDriver>")
26 set(_vtk_test_python_args
27 --server $<TARGET_FILE:ParaView::pvserver>
28 --client $<TARGET_FILE:ParaView::pvpython> --dr)
29 vtk_add_test_python(${ARGN})
34 "FORCE_SERIAL;FORCE_LOCK;SMTESTING_ALLOW_ERRORS" 35 "LOAD_PLUGIN;PLUGIN_PATH;CLIENT;TEST_DIRECTORY;TEST_DATA_TARGET;PREFIX;SUFFIX;_ENABLE_SUFFIX;_DISABLE_SUFFIX;BASELINE_DIR;DATA_DIRECTORY;NUMPROCS;NUMSERVERS" 36 "_COMMAND_PATTERN;LOAD_PLUGINS;PLUGIN_PATHS;TEST_SCRIPTS;TEST_NAME;ENVIRONMENT;ARGS;CLIENT_ARGS" 39 # It is kept here to avoid filtering it out from ARGN in the caller.
40 # If it were not present here, nor filtered out in the caller, then it would be considered
41 # as part of
"TEST_SCRIPTS" multivalue argument.
43 if (_paraview_add_tests_UNPARSED_ARGUMENTS)
45 "Unparsed arguments for ${function}: " 46 "${_paraview_add_tests_UNPARSED_ARGUMENTS}")
49 if (NOT DEFINED _paraview_add_tests__COMMAND_PATTERN)
51 "The `_COMMAND_PATTERN` argument is required.")
54 if (NOT DEFINED _paraview_add_tests_CLIENT)
55 if (
"__paraview_client__" IN_LIST _paraview_add_tests__COMMAND_PATTERN #
do we care?
56 AND NOT TARGET ParaView::paraview # For external testing.
57 AND NOT paraview_will_be_built) # For use within ParaView itself.
61 set(_paraview_add_tests_CLIENT
62 "$<TARGET_FILE:ParaView::paraview>")
65 if (NOT DEFINED _paraview_add_tests_PREFIX)
66 set(_paraview_add_tests_PREFIX
"pv")
69 if (NOT DEFINED _paraview_add_tests_TEST_DIRECTORY)
70 if (NOT DEFINED PARAVIEW_TEST_DIR)
71 set(_paraview_add_tests_TEST_DIRECTORY
72 "${CMAKE_BINARY_DIR}/Testing/Temporary")
74 set(_paraview_add_tests_TEST_DIRECTORY
75 "${PARAVIEW_TEST_DIR}")
76 set(_vtk_build_TEST_OUTPUT_DIRECTORY
80 if (NOT DEFINED _paraview_add_tests_DATA_DIRECTORY AND DEFINED _paraview_add_tests_default_data_directory)
81 set(_paraview_add_tests_DATA_DIRECTORY
82 "${_paraview_add_tests_default_data_directory}")
85 if (DEFINED _paraview_add_tests_TEST_SCRIPTS AND DEFINED _paraview_add_tests_TEST_NAME)
87 "Only one of `TEST_NAME` or `TEST_SCRIPTS` must be specified.")
88 elseif (NOT DEFINED _paraview_add_tests_TEST_SCRIPTS AND NOT DEFINED _paraview_add_tests_TEST_NAME)
90 "Either `TEST_SCRIPTS` or `TEST_NAME` must be specified.")
93 set(_paraview_add_tests_args
94 ${_paraview_add_tests_ARGS})
96 if (DEFINED _paraview_add_tests_PLUGIN_PATH)
97 list(APPEND _paraview_add_tests_args
98 "--plugin-search-paths=${_paraview_add_tests_PLUGIN_PATH}")
101 if (DEFINED _paraview_add_tests_PLUGIN_PATHS)
102 string(REPLACE
";" "," _plugin_paths
"${_paraview_add_tests_PLUGIN_PATHS}")
103 list(APPEND _paraview_add_tests_args
104 "--plugin-search-paths=${_plugin_paths}")
107 if (DEFINED _paraview_add_tests_LOAD_PLUGIN)
108 list(APPEND _paraview_add_tests_args
109 "--plugins=${_paraview_add_tests_LOAD_PLUGIN}")
112 if (DEFINED _paraview_add_tests_LOAD_PLUGINS)
113 string(REPLACE
";" "," _load_plugins
"${_paraview_add_tests_LOAD_PLUGINS}")
114 list(APPEND _paraview_add_tests_args
115 "--plugins=${_load_plugins}")
118 string(REPLACE
"__paraview_args__" "${_paraview_add_tests_args}" 119 _paraview_add_tests__COMMAND_PATTERN
120 "${_paraview_add_tests__COMMAND_PATTERN}")
121 string(REPLACE
"__paraview_client__" "${_paraview_add_tests_CLIENT}" 122 _paraview_add_tests__COMMAND_PATTERN
123 "${_paraview_add_tests__COMMAND_PATTERN}")
125 foreach (_paraview_add_tests_script IN LISTS _paraview_add_tests_TEST_SCRIPTS _paraview_add_tests_TEST_NAME)
126 if (DEFINED _paraview_add_tests_TEST_NAME)
127 set(_paraview_add_tests_name
"${_paraview_add_tests_script}")
128 set(_paraview_add_tests_name_base
"${_paraview_add_tests_name}")
129 set(_paraview_add_tests_script)
131 if (NOT IS_ABSOLUTE
132 set(_paraview_add_tests_script
133 "${CMAKE_CURRENT_SOURCE_DIR}/${_paraview_add_tests_script}")
135 get_filename_component(_paraview_add_tests_name
"${_paraview_add_tests_script}" NAME_WE)
136 set(_paraview_add_tests_name_base
139 string(APPEND _paraview_add_tests_name
"${_paraview_add_tests_SUFFIX}")
141 if (DEFINED _paraview_add_tests__DISABLE_SUFFIX AND ${_paraview_add_tests_name}${_paraview_add_tests__DISABLE_SUFFIX})
145 if (DEFINED _paraview_add_tests__ENABLE_SUFFIX AND NOT ${_paraview_add_tests_name}${_paraview_add_tests__ENABLE_SUFFIX})
149 if (NOT DEFINED _paraview_add_tests_TEST_DATA_TARGET)
150 if (DEFINED _paraview_add_tests_default_test_data_target)
151 set(_paraview_add_tests_TEST_DATA_TARGET
152 "${_paraview_add_tests_default_test_data_target}")
154 if (NOT DEFINED
"${_paraview_add_tests_name}_USES_DIRECT_DATA")
155 message(FATAL_ERROR
"The `TEST_DATA_TARGET` argument is required.")
160 # Build arguments to pass to smTestDriver 161 set(_paraview_add_tests_smtesting_args
162 if (_paraview_add_tests_SMTESTING_ALLOW_ERRORS)
163 list(APPEND _paraview_add_tests_smtesting_args
"--allow-errors")
166 # Build arguments to pass to the clients. 167 set(_paraview_add_tests_client_args
168 "--test-directory=${_paraview_add_tests_TEST_DIRECTORY}" 169 ${_paraview_add_tests_CLIENT_ARGS})
170 if (DEFINED _paraview_add_tests_BASELINE_DIR)
171 if (DEFINED
"${_paraview_add_tests_name}_BASELINE")
172 if (DEFINED
173 list(APPEND _paraview_add_tests_client_args
174 "--test-baseline=${_paraview_add_tests_BASELINE_DIR}/${${_paraview_add_tests_name_base}_BASELINE}")
176 list(APPEND _paraview_add_tests_client_args
177 "--test-baseline=DATA{${_paraview_add_tests_BASELINE_DIR}/${${_paraview_add_tests_name_base}_BASELINE}}")
180 if (DEFINED
181 list(APPEND _paraview_add_tests_client_args
182 "--test-baseline=${_paraview_add_tests_BASELINE_DIR}/${_paraview_add_tests_name_base}.png")
184 list(APPEND _paraview_add_tests_client_args
185 "--test-baseline=DATA{${_paraview_add_tests_BASELINE_DIR}/${_paraview_add_tests_name_base}.png}")
188 if (NOT DEFINED
189 ExternalData_Expand_Arguments(
"${_paraview_add_tests_TEST_DATA_TARGET}" _
190 "DATA{${_paraview_add_tests_BASELINE_DIR}/,REGEX:${_paraview_add_tests_name_base}(-.*)?(_[0-9]+)?.png}")
193 if (DEFINED
"${_paraview_add_tests_name}_THRESHOLD")
194 list(APPEND _paraview_add_tests_client_args
195 "--test-threshold=${${_paraview_add_tests_name}_THRESHOLD}")
197 if (DEFINED _paraview_add_tests_DATA_DIRECTORY)
198 list(APPEND _paraview_add_tests_client_args
199 "--data-directory=${_paraview_add_tests_DATA_DIRECTORY}")
202 if (DEFINED _paraview_add_tests_TEST_NAME)
203 string(REPLACE
"__paraview_script__" "" 204 _paraview_add_tests_script_args
205 "${_paraview_add_tests__COMMAND_PATTERN}")
206 string(REPLACE
"__paraview_scriptpath__" "" 207 _paraview_add_tests_script_args
208 "${_paraview_add_tests_script_args}")
210 string(REPLACE
"__paraview_script__" "--test-script=${_paraview_add_tests_script}" 211 _paraview_add_tests_script_args
212 "${_paraview_add_tests__COMMAND_PATTERN}")
213 string(REPLACE
"__paraview_scriptpath__" "${_paraview_add_tests_script}" 214 _paraview_add_tests_script_args
215 "${_paraview_add_tests_script_args}")
218 string(REPLACE
"__paraview_client_args__" "${_paraview_add_tests_client_args}" 219 _paraview_add_tests_script_args
220 "${_paraview_add_tests_script_args}")
221 string(REPLACE
"__paraview_test_name__" "${_paraview_add_tests_name_base}" 222 _paraview_add_tests_script_args
223 "${_paraview_add_tests_script_args}")
224 string(REPLACE
"__paraview_smtesting_args__" "${_paraview_add_tests_smtesting_args}" 225 _paraview_add_tests_script_args
226 "${_paraview_add_tests_script_args}")
229 NAME "${_paraview_add_tests_PREFIX}.${_paraview_add_tests_name}" 230 COMMAND ParaView::smTestDriver
232 ${_paraview_add_tests_script_args})
233 if (DEFINED
234 add_test(${testArgs})
236 ExternalData_add_test(
"${_paraview_add_tests_TEST_DATA_TARGET}" ${testArgs})
239 set_property(TEST
"${_paraview_add_tests_PREFIX}.${_paraview_add_tests_name}" 242 set_property(TEST
"${_paraview_add_tests_PREFIX}.${_paraview_add_tests_name}" 244 ENVIRONMENT
"${_paraview_add_tests_ENVIRONMENT}")
245 if (DEFINED
"${_paraview_add_tests_name}_TIMEOUT")
246 set_property(TEST
"${_paraview_add_tests_PREFIX}.${_paraview_add_tests_name}" 248 TIMEOUT ${${_paraview_add_tests_name}_TIMEOUT}
251 if (DEFINED _paraview_add_tests_NUMPROCS)
252 set_property(TEST
"${_paraview_add_tests_PREFIX}.${_paraview_add_tests_name}" 254 PROCESSORS
"${_paraview_add_tests_NUMPROCS}")
256 if (${_paraview_add_tests_name}_FORCE_SERIAL OR _paraview_add_tests_FORCE_SERIAL)
257 set_property(TEST
"${_paraview_add_tests_PREFIX}.${_paraview_add_tests_name}" 260 elseif (NOT DEFINED _paraview_add_tests_TEST_NAME AND EXISTS
261 # if the XML test contains PARAVIEW_TEST_ROOT we assume that we may be writing 262 # to that file and reading it back in so we add a resource lock on the XML 263 # file so that the pv.X, pvcx.X and pvcrs.X tests don't run simultaneously. 264 # we only need to do this if the test isn't forced to be serial already. 265 if (NOT IS_DIRECTORY
"${_paraview_add_tests_script}" AND NOT ${_paraview_add_tests_name}_FORCE_LOCK)
266 file(STRINGS
"${_paraview_add_tests_script}" _paraview_add_tests_paraview_test_root REGEX PARAVIEW_TEST_ROOT)
268 if (${_paraview_add_tests_name}_FORCE_LOCK OR _paraview_add_tests_paraview_test_root)
269 set_property(TEST
"${_paraview_add_tests_PREFIX}.${_paraview_add_tests_name}" 271 RESOURCE_LOCK
275 # XXX(gitlab-ci): Prevent tests from timing out after a long time. As to 276 # why the tests hang in this situation is not yet known. May be related to 277 # https://gitlab.kitware.com/paraview/paraview/-/issues/20697 278 set_property(TEST
"${_paraview_add_tests_PREFIX}.${_paraview_add_tests_name}" 280 TIMEOUT_AFTER_MATCH
"5" "Couldn't find object")
290 if (_get_prefix_PREFIX)
291 set(${varname}
"${_get_prefix_PREFIX}" PARENT_SCOPE)
293 set(${varname}
"${default}" PARENT_SCOPE)
297 # If NUMSERVERS is specified in ${ARGN} then returns in varname the number of servers to use for the test, 298 # otherwise returns the "NOT_FOUND" value. 305 if (_get_num_servers_NUMSERVERS)
306 set(${varname}
"${_get_num_servers_NUMSERVERS}" PARENT_SCOPE)
308 set(${varname}
"NOT_FOUND" PARENT_SCOPE)
315 PREFIX
"${chosen_prefix}" 316 _DISABLE_SUFFIX
"_DISABLE_C" 318 __paraview_smtesting_args__
319 --client __paraview_client__
323 __paraview_client_args__
331 set(_paraview_add_tests_args
332 PREFIX
"${chosen_prefix}" 333 _DISABLE_SUFFIX
"_DISABLE_CS" 335 __paraview_smtesting_args__
336 --server
"$<TARGET_FILE:ParaView::pvserver>" 339 --client __paraview_client__
343 __paraview_client_args__
350 if (NOT num_servers STREQUAL
"NOT_FOUND")
351 set(_paraview_add_tests_args ${_paraview_add_tests_args};
352 # Set the number of pvservers through the SMTESTDRIVER_MPI_NUMPROCS environment variable. 354 SMTESTDRIVER_MPI_NUMPROCS=${num_servers}
355 # Requires CTest to reserve NUMPROCS among the available processors 356 NUMPROCS
"${num_servers}" 365 set(_paraview_add_tests_args
366 PREFIX
"${chosen_prefix}" 367 _DISABLE_SUFFIX
"_DISABLE_CRS" 369 __paraview_smtesting_args__
370 --
data-server
"$<TARGET_FILE:ParaView::pvdataserver>" 373 --render-server
"$<TARGET_FILE:ParaView::pvrenderserver>" 376 --client __paraview_client__
380 __paraview_client_args__
386 if (NOT num_servers STREQUAL
"NOT_FOUND")
387 set(_paraview_add_tests_args ${_paraview_add_tests_args};
388 # Set the number of pvservers through the SMTESTDRIVER_MPI_NUMPROCS environment variable. 390 SMTESTDRIVER_MPI_NUMPROCS=${num_servers}
391 # Requires CTest to reserve NUMPROCS among the available processors 392 NUMPROCS
"${num_servers}" 400 _get_prefix(chosen_prefix "pvcs-multi-servers" ${ARGN})
402 PREFIX
"${chosen_prefix}" 405 __paraview_smtesting_args__
406 --test-multi-servers
"${count}" 407 --server
"$<TARGET_FILE:ParaView::pvserver>" 409 --client __paraview_client__
413 __paraview_client_args__
420 math(EXPR _paraview_add_tile_display_cpu_count
"${width} * ${height}")
422 if (_paraview_add_tile_display_cpu_count GREATER 1 AND NOT PARAVIEW_USE_MPI)
423 # we can run 1x1 tile display tests on non MPI builds. 427 _get_prefix(chosen_prefix "pvcs-tile-display" ${ARGN})
429 PREFIX
"${chosen_prefix}" 430 SUFFIX
"-${width}x${height}" 432 PV_SHARED_WINDOW_SIZE=800x600
433 SMTESTDRIVER_MPI_NUMPROCS=${_paraview_add_tile_display_cpu_count}
434 NUMPROCS
"${_paraview_add_tile_display_cpu_count}" 436 __paraview_smtesting_args__
437 --server
"$<TARGET_FILE:ParaView::pvserver>" 441 # using offscreen to avoid clobbering display (although should not be 442 # necessary) when running tests in parallel. 443 --force-offscreen-rendering
444 --client __paraview_client__
448 __paraview_client_args__
455 if (num_ranks GREATER 1 AND NOT PARAVIEW_USE_MPI)
459 get_filename_component(_config_name "${config}
" NAME_WE) 461 _get_prefix(chosen_prefix "pvcs-cave-${_config_name}
" ${ARGN}) 463 PREFIX "${chosen_prefix}
" 464 SUFFIX "-${num_ranks}
" 466 PV_SHARED_WINDOW_SIZE=400x300 467 SMTESTDRIVER_MPI_NUMPROCS=${num_ranks} 468 NUMPROCS "${num_ranks}
" 470 __paraview_smtesting_args__ 471 --server "$<TARGET_FILE:ParaView::pvserver>
" 473 # using offscreen to avoid clobbering display (although should not be 474 # necessary) when running tests in parallel. 475 --force-offscreen-rendering 478 --client __paraview_client__ 482 __paraview_client_args__ 488 # This is a catch-all function to run any custom command as the "client
" 489 # using th smTestDriver. Note, the command must print "Process started
" for 490 # smTestDriver to treat it as started otherwise the test will fail. 491 # The command to execute is passed as {ARGN} and is suffixed by each of the 492 # TEST_SCRIPTS provided, one at at time. 493 function (paraview_add_test) 494 _get_prefix(chosen_prefix "paraview
" ${ARGN}) 496 PREFIX "${chosen_prefix}
" 498 __paraview_smtesting_args__ 501 __paraview_scriptpath__ 505 # Same as `paraview_add_test` except makes smTestDriver run the command using 506 # mpi. If `PARAVIEW_USE_MPI` if not defined, this does not add any test. 507 function (paraview_add_test_mpi) 508 if (PARAVIEW_USE_MPI) 509 _get_prefix(chosen_prefix "paraview-mpi
" ${ARGN}) 511 PREFIX "${chosen_prefix}
" 512 NUMPROCS 2 # See Utilities/TestDriver/CMakeLists.txt (PARAVIEW_MPI_MAX_NUMPROCS) 514 __paraview_smtesting_args__ 517 __paraview_scriptpath__ 523 # if PARAVIEW_USE_MPI, calls paraview_add_test_mpi(), else calls 524 # paraview_add_test() 525 function (paraview_add_test_mpi_optional) 526 if (PARAVIEW_USE_MPI) 527 paraview_add_test_mpi(${ARGN}) 529 paraview_add_test(${ARGN})
function paraview_add_client_server_render_tests()
function paraview_add_test_pvbatch()
function paraview_add_client_server_tests()
function paraview_add_cave_tests(num_ranks, config)
function paraview_add_test_pvbatch_mpi()
function paraview_add_test_driven()
function paraview_add_test()
function paraview_add_tile_display_tests(width, height)
function _get_num_servers(varname)
function paraview_add_test_python()
function _paraview_add_tests(function)
function paraview_add_multi_server_tests(count)
function paraview_add_client_tests()
function paraview_add_test_mpi()
function _get_prefix(varname, default)
